Page 1 of 8 123 ... LastLast
Results 1 to 40 of 285
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Mr. QuickFist: The 0-60 Thread
    So we are all pretty familiar with our sluggish 7.2 second 0-60mph stock time. Throughout my build I've wanted to check how much faster I was going by adding each piece, however, between my short shifter misalignment, the clutch slave poorly bled, an engine failure, and my methanol never working, I've never had a proper moment when I could do 0-60 at this car's fullest.
    Well finally I replaced my boost manager plus, had a fantastic turnaround thanks to Eurodyne's quick shipping, My methanol is good to go, my engine is as healthy as ever,the clutch is fully bled, running some MT90 in my transmission, the shifter is aligned perfectly....so I guess I have no more excuses LETS DO THIS!
    Well I went out and did a few runs. Pulled up to a flat empty road, parking brake on, music off, clutch in, first gear in, rev to 4k RPM, release the handbrake, instantly lift off the clutch....womp womp womp...forgot to remove traction...6.3 seconds...almost a full second better than stock....hmm that kind of performance isn't validated by the amount of sweat blood and tears that have gone into this car.
    Take 2, parking brake on, music off, clutch in, first gear, rev to 4k, release brake...wait wait wait...traction control off....ok release brake lifto ff the clutch.....HOOOLY SHIIIIIITTTT look down quickly, 6000 RPM, quick shift to 2nd, wow 40mph never came on so fast, there goes 50....60...70....okkkk......6.1....hmm not terribly better.
    Take 3...lets add more gas even when the clutch is dropped.... brake. music. clutch. first gear. traction. rev to 4k. yada yada. DROP THE CLUTCH FLOOR THE ACCELERATOR!!!! waaaaaaaaaaaa psh 7000 RPM, shift into 2nd, whole car rocks like the titanic hitting an iceberg, waaaaaaaaaaaapsh 80MPH whoa slow down cowboy.....5.5s 0-60...well it felt fast as shit....5.5 isn't crazy but alright...we're working on improvement
    Take 4....lets check meth, get off the clutch even faster and go harder on the accelerator. brake yada yada.... rev to 4k, sidestep off the clutch.....floor the accelerator...wow....car did not bog....from 4k where I was revving it instantly just flew up from there....never dipped down, just went 4k to 7k in the blink of an eye...totally wasn't expecting that...miss the shift into second from my astonishment at what I would call a perfect launch. 0-60 inconclusive....
    Take 5....well you get the gist...been seeing 5.6 to 5.7, not sure if I was heat soaked but I could not replicate that 5.5 number or that perfect launch....would have been perfect if I could, probably could have made it to 5.2 or 5.3.
    Anyway thought you guys would enjoy a story of someone who is finally enjoying the performance of a build that took 2 years to complete.
    If anyone else has some good stories or wants to share their 0-60 times for discussion feel free to do so!
    -Martin
    Veteran Member Four Rings jsandor91's Avatar
    Jun 10 2011
    dead hookers
    South Jersey
    What were you using to measure 0-60??
    Sent from my Nexus 4 using Tapatalk
    Quartz Grey B7 A4 Quattro 6MT
    Maestro + Epy Tuned / GTX2867r / S3's / Spintech Non-Resonated 3 Inch Exhaust / Cold Side Synapse DV / TR18 + 2.5" Piping / Hpfp S1 Pump
    Bi-Xenon retrofit + Fly's leds / ST Coils + Rsb / 18x9.5 Miro 111's
    Dat Der Build Thread
    Coming Soon: Boost Manager +, Drakes Performance Stage V Clutch
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by jsandor91 View Post
    the STE Performance Parameters Display. You set it to performance mode, and it automatically starts when you move. so I use the parking brake to keep it from starting while I am just revving the car up.
    I'll try to get a video or two next time.
    Jun 10 2011
    dead hookers
    South Jersey
    I wonder if torque or vagcom would yield the same results
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    probably its just a timer. Jake@Jhm seems to think i can break into 4 second territory, I am hoping once I get better at launching and 1-2 shift I can get there
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    P3 gauge- 5.8 first run and 5.6 a little later in the year.
    No new runs yet as I still waiting on the car from tuning
    Sent from my Nexus 7 using Tapatalk
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Sep 29 2009
    B7 A4 6spd quattro
    New England
    0-30mph times for a few faster cars
    E92 M3 6m - 1.7
    SRT-8 6a - 1.7
    335i 8a - 1.8
    G37 7a - 1.8
    A4 8a - 1.8
    A4 6m - 2.1
    I have a Quattro b7 2.0t with 6mt and APR K04 S3 and here you go. This was using the torque app.
    I'm sure a better driver could crack off better numbers because my 1-2 shift is fairly slow and I got a lot of wheel spin. Conditions: slightly uphill road, 28 degrees F, and about 200' above sea level. All four tires spun and left black marks for a good 15-20'. ESP off, hold revs to 3000 rpms, mash throttle and dump clutch at 5000 rpms. Only launch I have done since installing the K04, don't want to break anything.
    0-10 MPH: 0.53 sec
    0-20 MPH: 1.05 sec
    0-30 MPH: 1.62 sec
    0-40 MPH: 3.05 sec
    0-50 MPH: 3.99 sec
    0-60 MPH: 4.89 sec
    60' 2.00 s @ 34.1 mph
    Veteran Member Four Rings RoguesGambit's Avatar
    Dec 19 2012
    Eatontown, NJ
    Since I had my P3, did it twice but was on a slight incline with a car on my ass, so I didn't get the best launch
    1st time was 6.25, 2nd was 6.18. Gonna find a relatively flat area to try it again, but definitely not a bad start
    JHM St2 w/HPFP, JHM HFC+B7 S4 FI Catback, JHM St1 Clutch/Flywheel, S4 Recaros, JHM Shift-Trio+Cross Rod, Bi-xenon Headlights, JOM Smoked Tail Lights, Enkei PF01, Conti DWS, Solo-werks S1 Coilovers
    More to come
    Also, my story: https://www.amazon.com/Sage-Mike-Fra...7646774&sr=1-1
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    damn y'all are fast as F. carguy - those are great numbers!! k04 is a great 0-30mph turbo.
    GTX28 not so much haha. lets do 40-100 runs instead :P :P
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by carguy138 View Post
    E92 M3 6m - 1.7
    SRT-8 6a - 1.7
    335i 8a - 1.8
    G37 7a - 1.8
    A4 8a - 1.8
    A4 6m - 2.1
    0-10 MPH: 0.53 sec
    0-20 MPH: 1.05 sec
    0-30 MPH: 1.62 sec
    0-40 MPH: 3.05 sec
    0-50 MPH: 3.99 sec
    0-60 MPH: 4.89 sec
    wow that is really impressive...sub 5 seconds on a k04! Do you have any good tips for launching?
    Veteran Member Four Rings FraggyA4's Avatar
    Mar 03 2012
    Jeep Comanche
    Thief River Falls, MN
    I wonder what I can expect from the Frankenturbo since it's a hybrid K04. This makes me excited to do runs a year or more from now lol.
    -Chadwick
    FULLY BUILT ENGINE!
    Senior Member Three Rings SPB.2127's Avatar
    Nov 28 2010
    Michigan
    E92 M3 6m - 1.7
    SRT-8 6a - 1.7
    335i 8a - 1.8
    G37 7a - 1.8
    A4 8a - 1.8
    A4 6m - 2.1
    0-10 MPH: 0.53 sec
    0-20 MPH: 1.05 sec
    0-30 MPH: 1.62 sec
    0-40 MPH: 3.05 sec
    0-50 MPH: 3.99 sec
    0-60 MPH: 4.89 sec
    What clutch are you running?
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    also what tires do you have lol. martin's on snow tires still...
    Sep 29 2009
    B7 A4 6spd quattro
    New England
    OEM clutch and bridgestone BlizzakWS70 snow tires. I imagine with my summers (pilot supersports) and hot asphalt it would be much harder to break free and probably just cause the clutch to slip. My run was done on the 93 APR fyi.
    Best advice I can give is that you need to get wheelspin. On that launch the RPMs never dropped below 4.5/5k.
    Mar 24 2013
    Oakdale, CT
    I really want to try launching my car, but it's probably a bad idea to do it on a bad tranny mount (at least that's what I think it is). As soon as I get my box from JHM though, it should be on in a manner resembling a popular 1980s video game starring a large gorilla.
    -Adam
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    if you launch and don't get wheelspin all that force from the motor is put directly into your trans and clutch until the motor dies. so yeah, wheel spin would be a good idea haha...
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Ebrake!?
    Remember, you ideally want to do this on a road with ZERO incline and ZERO decline. If you are going to roll when not using an Ebrake you are definitely not on a road worth testing any performance data.
    Even 1% incline can have a big negative affect on acceleration data.
    However, glad to hear the JHM Clutch/flywheel setup is doing its job!
    Nov 28 2010
    Michigan
    Im going to be purchasing a stage 3 south bend clutch soon. Maybe ill try blowing up my clutch with a crazy launch like that before I swap it.
    Aug 31 2011
    Lathrop
    Quote Originally Posted by drumnjuny View Post
    Slight wheel spin = good
    However,
    Wheel hop = broken axles
    lol
    Aug 31 2011
    Lathrop
    Quote Originally Posted by SPB.2127 View Post
    Save your time and money:
    http://jhmotorsports.com/shop/catalo...0t-p-1257.html
    Mar 03 2012
    Jeep Comanche
    Quote Originally Posted by Jake@JHM View Post
    You are a whore!
    -Chadwick
    FULLY BUILT ENGINE!
    Aug 31 2011
    Lathrop
    Quote Originally Posted by FraggyA4 View Post
    You are a whore!
    If being a whore is what it takes for people to have quality parts, I am game
    Mar 03 2012
    Jeep Comanche
    I will say the parts are high end, carry on wench
    -Chadwick
    FULLY BUILT ENGINE!
    Nov 28 2010
    Michigan
    I was interested in that kit..but I can get the south bend kit w/flywheel from a friend for less actually
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    hes right though. southbend is a waste compared to JHM's kit
    Aug 31 2011
    Lathrop
    It may be for less, but it won't be as awesome. Our Stage 1 can handle more power than most 2.0Ts are producing and features 100% OEM drive-ability. It truly is the best of both worlds. I Have well over 100 launches on my B7 and around 50 1/4 mile passes and my clutch setup hasn't even flinched.
    Senior Member Three Rings Rastboostin's Avatar
    Feb 21 2012
    Chicago
    I have the Stage 3 DXD Daily clutch with the 12lb flywheel and its pretty much exactly OEM. Only difference is that my revs whip up and drop down faster so I have to adjust my shifting
    2004 VW R32 - United Motorsports Stage 1 ECU, Forge CAI, USP 2.5" Test Pipe, APR Cat-back Exhaust.
    PAST: 2008 A4 Quattro S-Line 6-speed - APR 93 II+ ECU, APR Carbonio CAI, APR HPFP, JHM 3" Catless Test Pipe, APR Cat-back Exhaust, Southbend DXD Stage 3 Daily Clutch w/ LW FlyWheel, CXR FMIC, GoFastBits DV+, RAI Catch Can, RS4 Rear Sway Bar, 034 RS4 "Street Density" Motor Mounts, Koni FSD/Eibach Pro Kit, ECS Snub Mount, ECS X-Drilled/Slotted Rotors.
    Jun 17 2013
    jersey city nj
    Bent Rods ......lol... Only Jokin...... Wanna see it can do also...
    Mar 03 2012
    Jeep Comanche
    Quote Originally Posted by vce1232000 View Post
    I hope my IE rods don't bend, if they do then fuck that's an awesome turbo.
    -Chadwick
    FULLY BUILT ENGINE!
    Aug 31 2011
    Lathrop
    Or really bad tuning
    Mar 03 2012
    Jeep Comanche
    Still aren't the drop ins rated for like 700hp
    -Chadwick
    FULLY BUILT ENGINE!
    Dec 19 2012
    Eatontown, NJ
    How's much different is stage 3?
    More to come
    Aug 31 2011
    Lathrop
    Quote Originally Posted by RoguesGambit View Post
    In price or feel?
    Price is an additional $250 and the feel won't really be noticeable in regards to drive-ability. However, the stage three will be able to take a ton more abuse than the stage 1 (which seems like a crazy amount based on how much I abuse my stage 1).
    Jake
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Ebrake!?
    just wanted to be sure the car didnt move while i revved.
    orrr you can get the next best thing to a jhm setup. a clutch masters flywheel. singlemass of course, a custom rs4 pressure plate that retains the SAC so you will get perfect engagement everytime, no adjustment, and an rs4 clutcg disk...all for $500
    Dec 19 2012
    Eatontown, NJ
    In price or feel?
    Jake
    So any reason I shouldn't just jump into 3 or no
    More to come
    Aug 31 2011
    Lathrop
    Well, if you plan on going full on BT and really beating on your car, then nope!
    Dec 19 2012
    Eatontown, NJ
    Might as well go 3 anyway, always prefer to reinforce my stuff
    More to come
    Aug 31 2011
    Lathrop
    Good deal!
    Jun 10 2011
    dead hookers
    South Jersey
    i really wanna try to do a 0-60 but i'm afraid my stock clutch will explode. can we get some 20-80 or 40-100 data in here
    Dec 19 2012
    Eatontown, NJ
    Get a Stage 3/4 JHM clutch man, problem solved
    More to come
