Results 1 to 31 of 31
    Dec 03 2013
    us
    ko3 vs ko4 17psi. whats faster?
    So I bought my car with bw ko4s on giac stage 3- tune and all supporting mods. I see some cats with ko3s pushin like 21. I would think they'd spool faster and inherently be faster. Can anyone fill me in?
    Veteran Member Four Rings 2.7taudi's Avatar
    Sep 08 2011
    Houston, Texas
    They spool faster but run out of "breath" at higher RPMs.
    Sent from my LGMS769 using Tapatalk
    Garage: 2001 A6 2.8 FWD 5AT & 2002 A6 2.7T 5AT
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    K04 car will be much faster.
    Stock RS4 spikes 16psi and makes 380hp. Of course that's conservative stock tune too. Also at equal PSI the K04 is moving more air for two reasons. 1) K04 air is cooler, more dense. 2)Flows more air due to larger turbine wheel.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    K04s will move more volume. X psi is not the same on all turbos.
    Dec 03 2013
    us
    If the air flow is more shouldn't the boost be higher?
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by cvharps11 View Post
    Volume and pressure are two different things laddy.
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by CELison View Post
    Questin, Jesse (or for anyone else). Assuming the intake temperatures are the same, both turbos are cramming the same air mass into the intake manifold at 10psi.
    Now, aside from the temperature difference due to the increased efficiency of the K04, the main increase of power from a larger turbo is because more air is able to escape the engine on each stroke due to the increased turbine wheel size, correct? Thus allowing more air to be taken in even though the pressure at the TB is the same.
    -Hayden
    Dec 03 2013
    us
    Help this young grass hopper understand
    Veteran Member Three Rings sjmelling's Avatar
    Jan 06 2010
    Winchester -> Centreville, VA
    K03 manual car 17psi vs K04 TIP car on 15 psi. K03 car had intercoolers and exhaust. K04 car has stock intercoolers and stock exhaust. Start vid at 4:05 or so. Red car is K04 TIP, silver car is K03.
    Stephen J Melling
    2001.5 Audi S4
    ~~Laser Red Stage 3, Rods, F21's, other stuff and things
    2000 Audi S4
    ~~Hibiscus Red, Silver Interior, 01E, stock AF
    Aug 05 2011
    Memphis, TN for now!
    K03 will make power earlier in the rev range but run out up top. K04 will make power a little later but won't run out of power at the top. That is the basic comparison between the two turbos. The term faster...not sure what that means to you. Does it mean 0-60....does it mean 1/4 mile....does it mean on a twisty track...does it mean racing from a roll?
    Jan 06 2010
    Quote Originally Posted by airjawed View Post
    Exactly. On the highway, K04 car will win every time. On an Auto-X course, K03 car will pull out of the tight corners better and post better times. I like my K04's much more than my K03's. The difference in spool is barely noticeable and the pull up top is MUCH better even on mild boost.
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    Think of two tubes with air flowing through them at the same rate. One tube has a larger diameter than the other. Which tube has a greater airflow? The bigger tube. Same thing with turbos. K04s are larger, so at the same psi, they flow more air than K03s (and hence make more power).
    2005 Ferrari F430
    2007 RS4 Daytona Grey | 2008 RS4 Mugello w/Ti Package | 2007 RS4 Avus Silver (ex-Audi Corporate) | 2008 RS4 Avus Silver w/Exclusive Package
    B6 S4 Avant 6MT Dolphin Grey
    B5 S4 Avant 6MT Laser Red Stage 3+
    B5 S4 Sedan 6MT Silver Stage 1
    Dec 03 2013
    us
    Ahh I get it now. Thanks guys.
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by Fourplay View Post
    What happens when that airflow has to pass through an intake manifold of the same volume in both cases, at the same pressure, same temperature, and same rpm?
    Sent from my PC36100 using Tapatalk 2
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Just a thought here... if the air is flowing at the same rate, then they have the same airflow. For the same volumetric air flow rate (units such as CFM), the smaller tube will have a higher air velocity and a larger pressure lss over the length of the tube compared to a larger tube.
    Perhaps you mean "with air flowing through them at the same velocity"? Because then the larger tube will have a greater air flow rate. But then why does the air velocity need to be the same between two different size tubes?
    Not the same comparison IMO. A fan impeller has a characteristic curve that is far more complex than the pressure drop due to diameter change of a tube.
    I work with/design fans for my job, and I'm a mechanical engineer by degree. Just needed some clarification.
    2001 Corvette (C5) Z06
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    Whats your point, why stop at the intake manifold? What about through the engine and into the exhaust path?
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Aug 05 2011
    From an ECU perspective it does not see what is happening at the turbo itself. So, even though K04 is larger and flowing more volume it doesn't care or see it that way. It sees the air mass going past the MAF sensor....then it sees the temperature and psi at the intake manifold.
    ECU perspective:
    K03- more psi earlier in rpm, less psi up top and more temps up top.
    K04 - psi take a little longer to develop, psi stays up top and temps do not increase as much up top.
    May 01 2010
    Atlanta
    Quote Originally Posted by MetalMan View Post
    Facepalm. It was a (gross) oversimplification because the guy wasn't understanding how one turbo could have a greater flow rate than the other at the same PSI.
    That's great that you're an engineer. I'm also one. The point of my post was to educate someone who is not an engineer and was having trouble with the concept. We can get into compressor maps, impeller size/design, housing size and design, and other higher level stuff, but the purpose of my post was to provide understanding on an elementary level.
    Quote Originally Posted by FlyboyS4 View Post
    Velocity increases? You're the one with the flowbench, you tell me.
    2005 Ferrari F430
    Jan 06 2007
    Mk7 Golf R
    FL
    If the conditions are as I posed then nothing happens, the K03 and K04 'flow' the same amount of air into the engine, the exhaust side causes any differences. But to be clear, there are rpm regions where a K03 cannot supply enough air to match the boost level that a K04 can reach and the scenario I gave can no longer exist.
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Beyond the ridiculousness of the question, I can't believe so many of you tards actually fed the troll... And Fourplay, Flyboy: I swear you guys love to argue just for the sake of arguing
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    Quote Originally Posted by LINDW4LL View Post
    Questin, Jesse (or for anyone else). Assuming the intake temperatures are the same, both turbos are cramming the same air mass into the intake manifold at 10psi..
    No. Not true. Mass flow and manifold pressure are not the same thing.
    RIP Daz, you will be missed.
    May 01 2010
    Atlanta
    Quote Originally Posted by BITRBO View Post
    Comes with the territory of being an engineer. Every engineer thinks they're right 100% of the time when speaking to non-technical people, haha.
    2005 Ferrari F430
    Oct 27 2011
    TOYS
    Philly Suburbs
    Active Member Four Rings
    Nov 12 2013
    '01 S4 Tip '91 200 20VTQA, '01 A6 2.7TA, VW Rabbit GTI truck.
    SanHo, CA
    ^^LOL...
    Here's the question I have about slapping K04s or larger turbos onto our mere S4 engines: The K04 turbo was originally on the RS4 which has larger airbox, MAF housing, hose, y-pipe, inlets, SMIC's, intake manifold and heads. So when we put these bigger turbos onto the little intake tracts of the S4 are we shortchanging the potential of the mod? I've read the results of many of these builds with K04s, F21s, etc and see bigger numbers pretty much across the board but if the S4 intake was designed by Audi for the K03 it would seem to me that ANY larger turbo would need the rest of the intake components to perform at full potential.
    Oct 27 2011
    TOYS
    Philly Suburbs
    ^^^ performance/$ my friend.
    Mar 08 2012
    MI
    Jan 06 2007
    Mk7 Golf R
    FL
    These threads would get pretty boring if we all agreed all of the time. I've yet to hear a convincing argument for the other viewpoint so I keep giving my opinion.
    Mar 08 2007
    Mr. Worl-Wye
    I see what you're both saying - it's just funny to see the usual suspects scrapping it out all the time
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Jan 06 2007
    Mk7 Golf R
    FL
    Here's a K04 compressor map with red filled in the region where the K03 compressor map shows greater or equal compressor efficiency to a K04.
    A blanket statement like K04 air is cooler is incorrect, it depends entirely upon where on the map the turbo is operating. At an airflow seen around 3500 rpm and 20 psi the K03 is operating at 70% efficiency while a K04 around 63%; it's unlikely the K04 is discharging cooler air at that point.
    More correctly, at equal manifold pressure a K04 has the potential to flow more air if the engine rpm and VE can support the additional capacity, if not, such as at lower rpm's, the K04 will 'flow' the same amount of air as a K03.
    Yes. Imagine filling a bicycle tire to 35 psi, if you add or subtract some air what happens to the pressure? You don't stuff more matter into a fixed volume at constant temperature and not alter the pressure in the container.
    You're on the right track, except for the part about the increased efficiency of the K04, that depends upon the rpm you are evaluating at. Engine VE change due to the different turbines is probably the largest contributor so long as the K03 is operating in a region where the efficiency doesn't suffer.
    May 13 2011
    2015 BMW F30
    I must be going crazy, Fourplay I thought you were in law school? I just learned you are an engineer.
    back to your regularly scheduled program...
    | Autospeed | JHM | Pure MS
    May 01 2010
    Atlanta
    Quote Originally Posted by S4 00 2.7 View Post
    Undergrad was in engineering, got my J.D. last spring with a focus on IP law (patent stuff).
    2005 Ferrari F430
