Results 1 to 14 of 14
    Aug 16 2007
    San Jose, CA
    Strange 'metallic' jiggle / rattle coming from front driver wheel and back pass wheel
    The first sound is coming from the back passenger side/wheel. I first noticed this noise when I have my passenger side windows open, and I'm driving on a street with cars parked on the passenger side or a dividing wall. I think only then the noise gets bounced back and I can hear it. It's coming from the back passenger wheel well (I've had a friend drive the car while I sat on the back passenger side peering out the window), and it sounds like a jiggle / light rattle, as if you had tinfoil being crumpled, or maybe a light mesh chain grill shaking. It only happens when I go over bumps on the road.
    The second sound is coming from the front wheel well, and that one I can hear with the windows closed, and in the cabin. It's more of a rattle, with a slight metallic tone; I thought it could be the belly pan that isn't fully attached - the oil change guys may not have put it back properly, but at the same time the slight metallic sound doesn't seem like it would be from that plastic part.
    Any ideas?
    __________________________
    02 1.8TQ Denim Blue (was 50k) 150k miles
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    I'll put money on a loose brake pad. Either the pad has come apart or the little tabs need to put pulled apart a little more where it locks into the caliper piston.
    Sent from my SCH-I645
    Daniel J
    @gtg_drives
    Veteran Member Three Rings strtdrms's Avatar
    Apr 03 2012
    Noblesville, IN
    As far as the rear noise, check the suspension components. I had a similar issue where the pinch bolt for my rear shocks became loose and started making a noise
    2003 A4 1.8T Avant 5MTQ My Progress Thread
    2003 A4 1.8T Avant TIP - Daily Driver
    Instagram: mr_avant
    Veteran Member Three Rings adioman6000's Avatar
    Jan 12 2011
    SLC
    Could be a wheel bearing.
    Veteran Member Three Rings Coors's Avatar
    Aug 21 2008
    04 A4 USP 6MT
    Philly
    Front noise: loose heat shield over cat or axle?
    Rear noise: loose exhaust hanger or brake dust shield for bent is rubbing on something?
    Jun 27 2011
    Quote Originally Posted by 87supraman View Post
    That was my first thought too. I would double check the brake pads are snug and apply some CRC Brake Quiet to the backs of the pads just in case.
    It could also be a caliper retaining bolt or slider pin that is loose in which case you want to sort that out ASAP!
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Aug 27 2013
    Philly
    I think my caliper bolt is worn down...I get a random vibration from time to time when I let off the gas.
    Aug 16 2007
    San Jose, CA
    Thanks fellas, I'm dedicating some time tomorrow to do some work on my car (window regulator replacement) and I'll put the car up and check things out.
    Aug 16 2007
    San Jose, CA
    Welllllllll..... As it turned out, it rained today so I couldn't look at the car like I had hoped.
    I had to drive on the freeway and I'm hearing the front wheel noise louder until I hear a clunk and I look on my mirror and I see a piece flying off the car. I'm 8 miles from my destination thinking I can check it when I arrive, when my ABS light goes on. I step on the brakes and realize I need to step on them all the way down to get grip, luckily traffic is light and nobody in front of me. I merge out of the freeway and pull over. You guessed: my front driver caliper is hanging dangling behind the wheel. I'm typing this as I'm waiting on a tow truck to get me to my destination.
    Quick question, should I assume the brake line may be damaged and leaking brake fluid since the caliper is dangling?
    Would I be able to get new pads and clips and put the whole thing together back (and triple check shit is tightened up) so at least I can drive it to my usual mechanic or it's just unsafe to drive at this point?
    Shit got lucky.
    Jan 06 2009
    I would definitely assume the line to be damaged.
    So was it the caliper slide bolts that came loose or the caliper carrier bolts? Have you done any work on your brakes recently? If that happened after you recently did something to your brakes than for your safety (and the rest of us) I advise you have the car towed to a shop...No offence.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Aug 16 2007
    San Jose, CA
    It is being towed as I type this. And there is leakage, I'm just going to have it taken care by a professional come Monday.
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    for the rear metallic noise press your brake slightly and see if it still makes it, it is probably the backing of the pad not glued to the caliper. For the front check the bushing on the sway bar link to rule that out. Get under your car to be sure it's not the belly pan.
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    Aug 16 2007
    San Jose, CA
    So I replaced the back rotors and brakes and the noise is gone, so I'm thinking it was the shims on the brake pads. Thanks everybody.
    Junior Member Two Rings
    Feb 20 2021
    Trinidad
    Coming in on this thread 10 years later. I had a metallic jingling sound that could only be heard at low speeds and it was not constant and could not be reproduced. Changed front and rear wheel bearings and brakes. Luckily these needed to be done anyway but they were not the cause. It turns out that the backup nut from the valve stem had come loose and was rolling around inside the wheel between the rim and tyre. Took it to a tyre shop when we realized that the noise was in the wheel itself. They removed the tyre, found the nut and reinstalled it. Noise gone.
