Results 1 to 2 of 2
    Established Member Two Rings MatZo's Avatar
    Oct 26 2012
    Tampa
    Brake Light Issue
    I started getting intermittent bulb out errors with my car a few weeks back and finally got around to get my HEXCAN cable to see what what was wrong with my car. At first I thought it was the bulb but I realized that when I go to unlock my car the bulb actually comes on but when I turn on my taillights or use my brakes the bulb doesn't come on and I get an error.
    I also replaced the bulb a couple of months ago, I wasn't sure if there is something I needed to reset within the VCDS settings.
    Here is what I scanned from my car.
    Saturday,22,March,2014,14:07:44:43071
    VCDS Version: Release 12.12.0 (x64)
    Address 46: Central Conv. Labels: 8K0-907-064-46.clb
    Control Module Part Number: 8K0 907 064 CF HW: 8K0 907 064 CF
    Component and/or Version: BCM2 2.0 H04 0430
    Software Coding: 0106023A00FA400480B0013200000000
    Work Shop Code: WSC 06325 000 00000
    VCID: 76E3299BC16F02AEBEF-8023
    3 Faults Found:
    01565 - Luggage Compartment Light (W3)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 35238 km
    Time Indication: 0
    Date: 2013.07.02
    Time: 14:06:02
    02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 111
    Mileage: 43880 km
    Time Indication: 0
    Date: 2014.03.12
    Time: 08:19:24
    01503 - Bulb for 3rd Brake Light (M25)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 14
    Reset counter: 110
    Mileage: 42825 km
    Time Indication: 0
    Date: 2014.02.16
    Time: 15:32:26
    I found a thread for the S6 that many have found a grounding issue with their tail lights which I thought was my issue but if this is a grounding issue the bulb shouldn't come on at all which wouldn't be the case because the bulb is still coming on when I unlock my car.
    I wasn't sure if anyone has had anything like this happen, I tried finding something more A4 related but most issues are in other models.
    Thank you.
    Oct 26 2012
    Tampa
    http://www.audizine.com/forum/showth...aillight+issue Here is the thread I was referring to earlier.
