Originally Posted by
B00sted20VUSP
Yea that makes sense. The o-ring looked ok. One thing i noticed is all the paint audi used on that valley cover gasket was peeling off on the old one in big flakes, cant believe they did that. Those flakes can easily clog up an oilpickup tube...
I've attached some photos of the original job on mine. The valley pan gasket is a piece of metal sandwiched between two pieces of thin plastic. The plastic looked to have gone hard over time - clearly visible are the flakes in this picture.
The funny thing is that the main reason we pulled mine apart was to fix a significant valley pan leak. At the time I thought I'd look at the check valves as I had read that they were a common problem on the B5 S4 2.7TT's. I then researched the oil flow diagram from the RS4 FSI study guide and found the tensioners keep tension only because of the check valves. Another member here indicated that they are a ratchet type tensioner though so maybe it's not the ultimate solution but for the moment it certainly fixed mine.
Oil in valley pan before:
After clean up:
New oil filter housing O rings installed - note the 'Double D' is the pressure side (one half of the D feeds the front check valve, one the other half) and the single O is the pick up side (from the sump):
Old valley pan gasket cracks! Clear why there was a leak...
And finally...valley pan removed and cleaned. The two check valves have the crosses on top. The valley pan itself acts as an oil distribution plate - it delivers oil to the front check valve (RHS head) via the clearly visible moulded pipe section (see two photos prior). The back check valve has a distribution area that feeds both the LHS head and the chain tensioners.
Oh and one more thing - for anyone doing the job - Bentley says torque down the valley pan to 10NM. This leaked on us straight away as soon as the system was pressurised (our torque wrench isn't good at low settings). Give it 20NM. We had to redo the whole job.
Good luck
