Part
Washer fluid level sensor Part Number: 7M0-919-376
Tools required
Flat tip screw driver
17mm socket and ratchet or lug nut tool from trunk
jack and jack-stand
First start by removing the driver side front wheel and these tabs
Next pull back the cover to show everything
This is where I made my mistake, if you pull the bottom pump there is no valve so it drains everywhere, so be prepared with a slender funnel if you want to save the fluid, as I had the bad Rain-X I did not want to save the fluid, but made a huge mess lol.
Next pry out the sensor taking care to not damage the rubber seal on the washer fluid reservoir.
To disconnect the sensor from the wiring squeeze the sides like so
Once everything is done, simply install the new sensor and/or pump then reconnect the wiring as it can be a pain to push the sensor into the hole. Then just follow in reverse order to finish.
