Results 1 to 6 of 6
    Feb 19 2014
    RVA
    intake manifold gasket - does it need to be replaced?
    I'm going to manually clean the carbon buildup this weekend and will not have a new gasket in time. Is it ok to reuse the gasket assuming its not torn or damaged? The DIY I found didn't comment on the gasket and the only comment I could find was someone claiming the gasket was made from a liquid gasket maker.
    Senior Member Two Rings A4BGP's Avatar
    Oct 18 2005
    Dirt and Street bikes, '09 A4Q
    Moncton, NB
    Always a good idea to replace gaskets while you're in there. However, you'll likely be ok reusing them if you clean them meticulously. Consider that the injectors will come off with the manifold; those have items you WILL want to replace. You know, do it right the first time or replace a bunch of crap later kind of deal.
    Hold your horses and get this first: http://www.ecstuning.com/Audi-B8_A4-...uel/ES2588762/
    Established Member Two Rings holyShred24's Avatar
    Oct 28 2013
    Norfolk, VA
    Ive reused everything when i cleaned my intake valves at 61k+ miles. My injectors came off with the manifold except one. Inspected the retaining springs, clips and orings, manifold gasket and all were in good condition. Its been at least 1500 miles and i havent had any problems or ecl codes.
    Veteran Member Three Rings Fburg A4's Avatar
    Oct 06 2012
    Fredericksburg, VA
    The intake has a rubber gasket. The liquid gasket comment might be referring to the valve cover gasket.
    Feb 19 2014
    RVA
    Quote Originally Posted by Fburg A4 View Post
    I think your right...
    Ordered a gasket set for Friday delivery. Gonna be a long couple days ☺
    Veteran Member Three Rings wabbit23's Avatar
    Mar 20 2011
    2011 Avant Quattro & 2010 Jetta TDI
    San Diego, Ca
    Go get a bead blaster and some walnut media from harbor freight and speed up those couple of days to a few hours. Going that route next time and it should make life a whole lot easier.
    Mine- 2011 Avant Quattro- Premium Plus w/ Sport Package- APR Stage 2/ SPM Downpipe/ AFE Prodry S/ R8 Coilpacks/ ECode HFIP/ ECode Intercooler Piping kit/ 20% F & 15% R tint/ Dipped Parts & Vagcom stuff
    Hers- MKV Jetta TDI- Matte Black VMR V710's / H&R OE Sports/ Koni FSD's/ Dipped parts everywhere
