Results 1 to 9 of 9
    Mar 18 2014
    Los angeles
    Are motor mounts interchangeable from left to right?
    I just purchased an audi a4 2003 1.8 turbo and im going to change the motor mounts, transmission mounts, and snub mount.
    I went to autozone and they only had one motor mount model number in stock and I assumed that this meant it either had 1 motor mount period or I can buy two of them and use both on the audi, meaning interchangeable.
    This is the autozone Part Number: 8997 Alternate Part Number: A6926
    Am I missing something here or are they in fact different and I have to buy to separate looking motor mounts?
    Also do I have one or two transmission mounts?
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    If you have a manual there is a single center transmission mount. If you are an auto you have two of the same mounts, but one on either side, they are both the same. The two motor mounts and snub mount are the same for auto and manual and they are the same for the left and right motor mount as well.
    Costco 92 Octane Gas - MANN Air Filter - 235/35/19 Tires w/ 36 PSI (cold) Tire Pressure - Grey Plastic Valve Stem Caps - 0° Front Toe - Rotella T6 5W-40 - 2 OEM B6 Keys - 18x8" Spare - Coin & Pen Filled Center Console - Rain-X on all 8 windows & Napa Cold Temp Washer Fluid - Bosch Wiper Blades (Valeo wipers suck big time!) - S4 Trunk Latch - Craftsman Tire Pump w/ Automatic PSI Shutoff - Belly Pan Delete (Weight Savings) - 3D Printed Rear Warning Triangle latch - 174,000 Miles & Counting
    Mar 18 2014
    Los angeles
    Sorry didn't mention I have an automatic and thank you very much.
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by evo_ski View Post
    untrue, the stock left and right engine mounts are different part #s due to the unequal weight distribution /angling of the 1.8T engine. It's not a huge difference though, and almost all aftermarket mounts use the same part for both sides
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Mar 15 2010
    Bothell
    Quote Originally Posted by Matt Devo View Post
    Hmm, well then. I stand corrected. I didn't know that since I ordered 034 street ones, so they were the same for both sides. Good info!
    Mar 18 2014
    Los angeles
    So a little confused.
    I'm not buying the original audi motor mounts, just the autozone ones, so this means that they are the same for both sides as long as they are not oem right?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by AudiAlans View Post
    Yep.
    Mar 18 2014
    Los angeles
    Ok thanks.
    Mar 18 2014
    Los angeles
    Can anybody double check this
