Need some help here.. So yesterday i changed my air filter from OEM to AFe pro Dry. Did the switch, started car and no issues. Today, while driving the car the check engine light came on. Later on when i parked my car i toggled around with the air intake box and just to see if everything was okay. (when installing my filter yesterday and trying to put the air box back on and a clip fell off but the box fit back in) I tried starting my car and the car wouldn't start. The starter would go off but the car wouldn't pick up. Tried again a few minutes later and car started, took it home.
I took the Afe filter out thinking i might have installed it wrong. I decided to put the OEM filter back in ( Car is under warranty don't want dealership blaming me for the problem) Tried starting car, car would't start again. Went inside, had a beer came back and tried again and the car started but the check engine light was still on. The air box isn't fitting as snug as it should, probably because of the clip breaking off when i tried to put it back together but it is on. Maybe the air box is sucking in enough air for the car to start? I don't know if the car will start tomorrow. But does anyone know what the problem could be?
I need to drive the car tomorrow and dealership isn't open till Monday. Would you guys say it is okay now? I am not sure why the check engine light would come on or why my car wouldn't start. All i did was change the air filter!
Thanks so much for any input.
Vinsta13
