Originally Posted by
JohnathanAvant
How long has it been since the pcv in the photos was last checked/changed? Do you have sludge issues?
Tbh, I have never checked the PCV valve in four year ownership of my car. I think this is the factory fitted PCV valve as I have almost every single record of work done on this car from the beginning(Thanks to the two previous owners). Car now has 250k miles
Even though I never inspected the valve visibly, I have been checking the PCV system regularly(say every 3 months or so)with the help of
Walky_talky and this video below.
The reason why I replaced the PCV valve now is because car is having some idle fluctuations lately and this was considered to be a cheap fix to throw a new PCV valve. But I found out yesterday that the the PCV bleeder valve housing has got a crack in the middle and is probably causing the idle fluctuations and slight increase in oil consumption. So I am gonna replace everything there under the intake manifold considering they are 16+ years old and has 250k miles. Car has no sludge issues, runs normal and quite.. thankfully!
I found this video and the guy very helpful in explaining how to diagnose the PCV system..
And this is how the original PCV valve looked after 250k miles, the diaphragm was still holding the vacuum but I think it sticks too much to the rear cover..probably because of age..
