Results 1 to 40 of 47
    Account Terminated Four Rings
    Mar 08 2010
    San Francisco, CA
    high flow catalytic converter
    I've read the information on this board about catalysts, and the information on the B7, B6 and B5 boards. I'm not sure what to make of it all. In theory and aftermarket downpipe could have a high end catalyst and exceed stock performance for both flow and cleaning the air that passes through it. It practice it may not be as reliable for as long. I would want to see +14 wheel horsepower to think this was worthwhile (from 371 HP at last dyno to 385 HP). The extra sound is great but not necessarily a plus nor a minus. My car is already flirting with the sound restriction at certain tracks.
    Aftermarket, high end 300 cell catalytic converter for a 2.0TFSI.
    Aftermarket vs. stock on a 4.2L S4
    OEM Audi 600 cell, two stage catalytic converter (double catalyst for heating up fast, heating up slow) from a 2.0 FSI engine.
    Feb 25 2013
    MI
    Mar 08 2010
    San Francisco, CA
    I respect CircuitTested about as much as I respect USA Today. It's cute and he's doing the best he can. That part may or may not be tainted.
    There are other vendors with high quality parts on the market or coming to the market, with proven applications on other engines.
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    It's possible to see gains, assuming the tune can take advantage of the increased airflow. Not sure if you would need a "test pipe" (i.e. Cat delete) file to take better advantage or not. The stock cats have a wicked sharp turn immediately after them, and the 034 HFC's have less of one for better airflow, but there was never any definitive gains shown, and some things pointed to poorer performance with these. Many also had to use spacers with the O2 sensor in order to get rid of CEL's, or use a test pipe file. The other big thing is that you have to either drop the engine or have someone who really knows things with special tools to get these swapped, they are wedged in just above the transmission at the top rear of the engine, and much like the headers install, nearly impossible to perform with the engine in the car due to space constraints.
    http://www.audizine.com/forum/showth...B8-S4-3-0T-fsi!!!!!!!
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Feb 25 2013
    MI
    Quote Originally Posted by westwest888 View Post
    Just trying to give you a reference so you don't have to re-invent the wheel. I'm not aware of anyone else who makes HFC's for the 3.0T. I don't even see the 034's for sale anywhere. This is all I see from 034, which would be very "un-westwest" to run...would be much better saving the world with your Tesla:
    http://store.034motorsport.com/produ...-3-0-tfsi.html
    Feb 25 2013
    MI
    Quote Originally Posted by NWS4Guy View Post
    I thought the test-pipe files were simply there to remove certain CEL's from showing up? No actual difference in the tune?
    Mar 08 2010
    San Francisco, CA
    I wonder if test pipes eliminate all of the back pressure and cause another issue that having a catalyst would mitigate.
    Veteran Member Four Rings integroid's Avatar
    Mar 01 2013
    Atlanta, GA
    Quote Originally Posted by drob23 View Post
    You are correct.
    2024 RS3 Kemora Gray
    Feb 12 2013
    Boston, MA
    Changing your cats to increase power is like painting a pipe to stop it from leaking... Is 5hp worth all that trouble?
    Sep 29 2009
    I'm not certain if it just kills the O2 triggered CEL or if there is any other actual differences.
    So far as these from 034, they posted videos then promptly removed (or made it private) them. The sound was pretty god awful, very raspy, harsh and not at all pleasant. There are videos on that thread I posted which have sound clips of a customer using the 034's with APR exhaust and it is not as bad as the original clips, but extremely loud under load. 034 claimed 22TQ and 20AWHP on stock exhaust (the broken links missing on the first post), however when these were taken to the track to prove what it showed in terms of actual useful performance, the times were almost always slower. After a lot of back and forth, 034 came back and said "the B8 crowd is too immature and not ready for something of this caliber, they don't understand what is being offered" and took the page and all reference to them down, refusing to sell them.
    I'm sure if you call they will likely sell it if they still make and have any in stock, most of the best times on the slips sticky are people with these, but again they also have a lot of other mods, and some with the 034's are farther down on the list as well, so it's not really completely clear.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Quality HFCs are definitely worth it if you are trying to squeeze power out of your engine. Will the performance be as good as test pipes? No. Would your butt dyno be able to tell the difference between Test pipes and quality HFCs? Chances are no.
    Will quality HFCs give you better performance than stock cats? Yes.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    i think you would be better off getting some 034 test pipes and adding the cats further downstream, if you flange them you could easily swap out for some test pipes.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Mar 01 2013
    Atlanta, GA
    It is the same file with just the O2 triggered cel turned off.
    Veteran Member Four Rings bwoy1981's Avatar
    Oct 28 2006
    2005 Porsche 911 997 Manual, 2022 Hyundai Tuscon
    Orlando, Florida USA
    Quote Originally Posted by Jake@JHM View Post
    ^^^^this, plus HFC are for ppl in states who require emission testing. In my B6, when the cat failed I did a testpipe and never looked back because we dont have emission testing here and I started focusing on power.
    Current: 2022 E-Tron Sportback Premium Plus, Siam Beige, S-Line, Black Optic Package, 22x10.5 Q8 Rotors, 285/35/22 Continental DWS 06 PLUS
    TOY: 2005 Porsche 911 997 Carrara White / Black Interior 6 Speed manual, Aero Kit,
    BC Racing Coilovers, FABSpeed Exhaust, Headers & Intake, 991 GT3RS Reps "GOLD"
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Backpressure isn't a concern with turbo applications. However, for NA and Supercharged (depending on output of the Supercharged application) ones need a bit. If you'd like to say Street Legal and have some kind of emissions test passing capabilities, you'll probably want to try a high-flow one and see what it gets you. In the past I've had custom ones built by Random Technologies and they've worked great, but make sure your tune is right or you will eat through them and have some loose cells in the exhaust in no time. Ask me how I know... lol
    Anyway, I've always been an advocate of high-flow cats if built by a quality company and does show power improvement over stock setup while still maintaining some emissions controls. The only thing you'd have to worry on the S4 is if the ECU is calibrated in stock form to pick up a certain cleanliness of the exhaust throughout its warmup and operational stages. If the newly added higher flowing CAT doesn't clean up as many of the hydrocarbons as the OEM one, you will set a CEL. This of course can be taken care of by simply changing the expected limits of the O2 readout but not completely defeating them... so as to keep you in the know should the new CAT fully fail and you need to set the CEL for that issue... know what I mean?
    All that said, only you can pick the right setup for you (no, I don't mean this tongue in cheek this time, lol). If you feel that you'd want to maintain a CAT based setup with some minor back pressure and get some gain as well, maybe the high-flow is for you. If not, either leave it stock or eliminate it. Hard to say what you'd get with a high-flow, but you should already know what removing the CATs gets you. I'd anticipate probably a 40-60% gain of that difference if you went with a high-flow CAT setup. Again, this is an estimate since there is still some restriction in there, but the percentages are within what I've seen on other applications.
    Feb 25 2013
    MI
    I wonder if APR will make a HFC for the 3.0T, they've done so on the A4 setup, especially with the Stg3 in the pipeline...
    Senior Member Three Rings CircuitTested's Avatar
    Mar 02 2011
    First off, you're blatantly ripping off a project I started over three years ago. Second, you have absolutely zero experience other than the shallow level of knowledge you have gained by doing a few Club driving events. Third, you are more than welcome to dispute anything I've done. Strap on some of the new HFCs and let's see what you think.
    2011 Audi S4 (gone) // 2015 Audi A8 L 4.0T // 2013 Land Rover LR4 HSE // 2006 Lotus Exige // 1986 Land Rover Defender Ninety // 1964 Daimler SP250 // 1964 Pontiac GTO TriPower // 2015 Chevrolet 2500 HD Duramax // 1952 Chevrolet 3100 1/2 Ton // 1987 Porsche 911 Carrera // www.blackbridgemotors.com
    Senior Member Three Rings priceprince's Avatar
    Jul 26 2012
    Northern California
    Are the cats hidden enough on this car that you'll pass a visual inspection when you go to smog check your car here in CA? I'm sure the HFC would pass the sniffer test ok.
    2010 Audi S4 Prestige / 6MT /Sport Differential / B&O
    Sep 29 2009
    Quote Originally Posted by CircuitTested View Post
    I love you.
    Quote Originally Posted by priceprince View Post
    They would have to even know what to look for. The stock cats can be seen from the engine compartment, but most shops are not going to know enough to know what the stock cats even look like, let alone if they are there. They likely are not even going to look for these unless you fail.
    Jul 26 2012
    Northern California
    ^thats what I figured, thanks
    Aug 31 2011
    Lathrop
    The HFCs that we use across all of our platforms are a very high quality. While everyone in California knows that HFC are "Intended for off road use only" our customers report back to us all of the time stating that they passed out the pipe very cleanly. However, if the smog tech notices that it isn't the OEM cat you may have some issues.
    Apr 11 2012
    why not stage 2 before HFCs?
    Aug 05 2013
    N/A
    Quote Originally Posted by will13k7 View Post
    lol, cuz Revo doesn't have Stage 2. Or as West looks at the issue... Cuz Revo doesn't need Stage 2 to make the same amount of power his car does.
    Established Member Two Rings budda's Avatar
    Mar 10 2010
    2000 S4 6M GT25 SOLD, 1990 Accord H22 GT35R w/JRZ RS Pro's, 2013 S4 GONE, 2016 S6
    Only HFC I would use..... know several people running these and each has documented HP gains
    http://www.hjsna.com/categories/HD-C...B47%7D-EURO-5/
    Apr 11 2012
    Quote Originally Posted by SwankPeRFection View Post
    Time to switch to APR/GAIC, its just Revo SW that will get replaced right?
    I haven't seen a plot of Revo's power-band, but I would like to believe a stage2 APR/GAIC setup will have more HP/Torque more of the time through-out the powerband, even at the top end. Does Revo get 16 PSI near the top end of the RPM range?
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    Does anyone know the stock flow rate? It's kind of important for comparative purposes.
    Feb 12 2013
    Boston, MA
    I just want to mention that, from a laws of physics perspective, there is no fucking way that any tune that doesn't have a pulley makes anywhere near the power of a tune with the pulley.
    And that's coming from someone with no real brand loyalty.
    Apr 11 2012
    Seems like west is on the hunt for more power, no need to be loyal to Revo, time to make the switch! Okay, I'll stop derailing this thread now.
    Veteran Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    Yet he thinks his Revo tune is "conservative."
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, B8.5 MMI 3G+ Nav, Ti Pkg
    APR Stage 2+ Stock/93/100/Valet, Eurocode Alu Kreuz, Eurocode USS Sways + End Links, Eurocode Meisterwerk SSK, Roc Euro Intake, Apikol Rear Diff Mount, Fast Intentions Exhaust, Escort 9500xi, Laser Interceptor, P3 Vent Gauge, VCDS
    Sep 29 2009
    Quote Originally Posted by helix139 View Post
    It is, didn't you see the numbers comparing race to pump gas?
    Mar 01 2006
    Kitchener, ON
    I have these up if you are interested
    http://www.audizine.com/forum/showth...ally-high-flow
    Mar 08 2010
    San Francisco, CA
    It is conservative. It's the same tune a dealer will sell you and it's capable of being warrantied, although the Revo route will save you $500 and contain no extended warranty. You can certainly purchase a 3rd party warranty to 100k miles and use an independent shop that can bill the guarantee company and not check for TD1 because they can't.
    I will evaluate Revo Stage 2 if it becomes available to the US dealer network.
    Sent from my Nexus 5 using Tapatalk
    Sep 29 2009
    I guess you missed the memo?
    http://www.audizine.com/forum/showth...Stasis-no-more
    Mar 08 2010
    San Francisco, CA
    Yeah that was apparent years ago and I got laughed at for pointing out some of the subtleties of the Stasis and Revo partnership. That doesn't change all of the deployed software on thousands of people's cars or invalidate any of my statements about the tunes and their ability to conform to underwriter guidelines.
    Feb 12 2013
    Boston, MA
    West says: commit fraud, If you know the guys helping you out its okay....
    Mar 08 2010
    San Francisco, CA
    Quote Originally Posted by IanCH View Post
    If you can pull one over on 3rd party sketchy mail order warranty company, you both win. Nothing in that contract says you can't modify the car. Auto finance, guarantee and reinsurance companies in and of themselves are ponzi schemes that blow up every other decade, particularly when the collateral is American cars produced in absurd volume.
    I pay for my own service and take responsibility for my own vehicle. Some people fix whatever they can in their driveway and cry to the dealer looking for a freebie when they need a mod bailout. You won't find westwest888 in this situation.
    Senior Member Two Rings rynurz23's Avatar
    Feb 06 2011
    2009 GMC DENALI, 2010 Triumph Speed Triple SE, 2017 Ford F-150, 2016 Chevy Cruze
    shorewood/il.
    I'd like to add my 2 cents since I have run at the dragstrip with cats and with 034 test pipes. With cats, my fastest run was 11.87 @ 116mph without cats, my best was 11.67 @ 118mph Both runs were 100 octane gas and tune. Also Both days were at the same track with similar conditions, and DA's. Just for the heck of it, I'm planing on going to the Dyno soon to see if any increase shows up with the 034 TP's. It will be the same dyno that I did with the cats on.
    Mod list and 1/4 mile times...
    Stage 2 APR ECU Tune, APR TCU tune, APR Pulley, APR CPS, 034 test pipes(currently not installed), stock down pipes, Stasis touring Exaust, 19" LW Rims, Stasis LW rotors and brakes, JHM rear LW rotors, JHM lightweight crank pulley(not oversized one)and Custom Strat Intake
    11.61 @ 118.33 034 test pipes, 104 tune, and stock TCU.
    11.56 @ 119.62 on stock cats, 104 tune, and APR TCU tune.
    Feb 12 2013
    Boston, MA
    Actually, every single warrany offered by a third party has an explicit and strict clause that prohibits any modification to the car, even if it is not related to the claim at hand. I know this and have posted screen shots of the clause because I have read many of the available contracts.
    Aug 05 2013
    N/A
    ^^^^ Ya but that's stock CATs vs no CATs. Not what he's wanting here.
    Feb 06 2011
    shorewood/il.
    but it was brought up, so i responded
