Originally Posted by
oh10a4
I assume its about making extra money. Just like why isnt it equipped with bluetooth streaming by default. AUX/BT should be standard in all cars.
I have the ipod/iphone 30pin connector and bluetooth, but I agree, Aux/BT should be standard in all cars.
booost
I have a screen but no navigation or bluetooth. The Concert radio has SD card, single CD, AM/FM/XM and the AUX in from the 3.5mm jack in the center console. It also shows the car options & A/C controls on the screen. If I have AMI, where would the connector be, passenger side of the glove box? I will take a look after work but I was under the impression that you either had AMI, or the AUX in jack...
For reference:
I have AMI and the 30 pin connector for ipods/iphones is in the glovebox. I'll take a pic and post later today unless someone beats me to it.
wxsgt
the difference between AMI and no AMI is a connection in the back of the radio either to the glove box for the AMI or to the center console for the 3.5mm. the reason you cant have both is because there is only one port on the back so one or the other(i know id rather have both also!)
Ah, ok. Oh well. These are the little things I know I will look for on my next car purchase.
SDF1
Same here no 3.5 aux input either on mine.
I wonder if it can somehow be retrofitted. It was mentioned that DavidB8 tried, but had no solution. Looks like we're stuck.
