Originally Posted by
jsandor91
so a while back Arin threw out the idea of a APR gtx kit for the b7 to gauge interest.
The programs actually back on our plate. We have two employees with B7 A4's (both motors) and both would like to go the GTX route, and then later add headporting. I'm not going to discuss timelines because I don't know what they will be, but the program should be pretty simple.
one thing i noticed earlier is the power APR is claiming for 100 octane race gas 449 chp!?
We did 402 WHP on our dyno with the BPY FSI engine, front wheel drive. That's what was used for the graph above. Head porting allowed us to go further.
Stock at the wheels, was 190 WHP.
The A4's quattro system ultimately produces much lower results than the front wheel drive vehicles.
Our number fall in line with a couple of our dealer's dynojets and our crank numbers are typically estimated pretty accurately compared to both US and ROW MAHA crank dynos that are setup properly.
APR makes doesn't mention anywhere that rods are required for either of those power figures which is surprising.
On the new Golf R, the rods are awesome. On the older A4's and other 2.0T's, no way. They'll likely fail without upgraded rods and a lot of use. However, if I'm not mistaken, we did collect the stage 3 data on stock rods. They were swapped when we did the head porting.
they also don't mention any kind of fueling upgrades other then a fuel pump
FSI (BPY) k03 based engine gets S3 injectors, APR rail valve and APR HPFP. If you add head porting, you need to upgrade the LPFP. Our official kit for that is releasing shortly.
The golf R uses the stock injectors. Gets a rail valve and APR HPFP. The new LPFP releasing shortly will come with a power increase on the Golf R kits.
The A4 GTX kit (when we do it) will require S3 injectors, APR rail valve and APR HPFP. I'm also willing to be it will need our LPFP upgrade as well.
