Results 1 to 20 of 20
    Established Member Two Rings IrishCreamPuff's Avatar
    Jul 23 2013
    C7 Z-06, '07 S6 (sold)
    United States
    S6 to RS6 engine swap possible in US?
    So I found a website that allows me to buy used RS6 V10 TT engines in the UK for roughly $6.5k. Is transplanting it into a C6 S6 feasible without tons of creative modification? I know it's kind of a really open ended question, but if all goes well I would LOVE to try this. A 6 second 0-60 time for a V10 is really starting to piss me off. Any idea what other parts I would need? New tranny? New propshaft?
    Sorry for my ignorance!
    http://www.replacementengines.co.uk/...ll-audi-engine
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    No one has done it that I know of. However, I'd guess that it's fairly simple as long as the engine comes with ECU and harness. Probably some minor wiring involved, but physically everything should bolt up.
    I'm not sure how much power the S6 transmission can handle.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Feb 12 2013
    Boston, MA
    Whats wrong with your S6 that you are running a 6 second 0-60? I ran a 4.88 in mine with apr stage 1 (only 20 hp) and a modded exhaust, rest of the car stock.
    Much easier project to make the S6 faster is to go lightweight wheels, BBK (weight reduction) and APR stage 1 and you will be a in a noticeably better place.
    Jul 23 2013
    United States
    Quote Originally Posted by IanCH View Post
    No idea why, it just isn't that fast. Any other weight reductions I can make short of removing the rear seats?
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Quote Originally Posted by IrishCreamPuff View Post
    Well...since your name is IrishCreamPuff I would say start with by dropping a few pounds yourself ;)
    Lol I kid, I kid
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Established Member Two Rings haloguy628's Avatar
    Sep 01 2011
    Castle Pines North
    Carbon deposits. The engine can't breathe.
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    6sec for a v10 is sad.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Senior Member Two Rings Treedancer72's Avatar
    Mar 29 2013
    Stockholm Sweden
    My diesel does it in 6,4 so an s6 should be much faster. :)
    Veteran Member Three Rings KrUsTyX's Avatar
    Feb 05 2007
    1982 VW Caddy
    Quebec, Canada
    Swap a 3.0T, will be faster, no import charges, etc
    2006 Audi A6 Avant
    Arctic White
    Premium, Tech and Cold Weather packages
    VWQuebec.ca
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    Quote Originally Posted by LINDW4LL View Post
    From what I've read, A6/S6/RS6 all sport the identical ZF 6 speed. Not positive but if that's the case, looks like this transmission is up for some serious power.
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    Jul 23 2013
    United States
    Quote Originally Posted by haloguy628 View Post
    Already got a carbon clean 6 months ago.
    Jul 23 2013
    United States
    With the APR stage 1, are you pretty much forced to use 93-95 octane? I do already, I'm just curious. Also do you have any idea how much resonator deletes cost?
    Feb 12 2013
    Boston, MA
    I ran 91 when I was in Maine without any problems, threw an octane booster in on one of the tanks and didn't see a noticeable difference. Ran shell 93 the rest of the time.
    My resonator delete replaced with tig welded stainless cost a little over 200, can't remember the exact price, but I did all 4. If you search s6 quad resonator delete on YouTube you can find the video before and after of my car.
    Jul 23 2013
    United States
    With the resonator delete, was there unbearable humming at cruising speed at all?
    Senior Member Three Rings z06psi's Avatar
    Jun 25 2012
    2002 Corvette Z06
    Hawaii
    Remote mount turbos would do wonders for this car in place of the rear resonators. Also a little N2O in each airbox does the trick too. 50 dry in each airbox.
    2008 S6
    2002 Z06 (6.7L with twin turbo coming)
    2005 Navigator
    2001 Prelude
    Feb 12 2013
    Boston, MA
    There was drone when throttle was applied at highway speeds in 6th, I didn't find it unbearable, its all personal preference
    Nov 01 2012
    1993 Mazda Rx-7
    San Antonio, Texas
    Quote Originally Posted by z06psi View Post
    I had a discussion about this, i think one of the hang ups was the amount of money it cost to effectively tune the bosch ecu.. or something along those lines especially for fuel management and what not
    Jun 25 2012
    2002 Corvette Z06
    Hawaii
    N2O is the way to go. Dry shot before the MAFs and it will adjust on its own. To a limit though. But 100 h.p would go a long way in this car though.
    2008 S6
    2005 Navigator
    2001 Prelude
    Nov 01 2012
    1993 Mazda Rx-7
    San Antonio, Texas
    100 Hp would do wonders in this car.. if we could all contribute equally that own them then i think we could come up with something that is feasible and affordable..other than a 20k turbo kit
    Feb 12 2013
    Boston, MA
    Quote Originally Posted by BlackS6 View Post
    There's actually nothing to be done. The major restriction in the S6 is in the intake manifold. If you bossed the hood then you could fit a gallardo intake manifold (can be purchased for cheap actually) on there and the car would be almost instantly a monster (after tuning and all the other adaptations) but that will easily cost you a boatload and you have to sacrifice the hood. In theory the IMF could be modified like they do to the RS4 IMF but nobody is offering that service and last I check JHM wouldn't do it.
