Results 1 to 30 of 30
    Veteran Member Three Rings stevengrande's Avatar
    Feb 28 2013
    NH
    Low oil light on after oil change
    Just got my oil changed today (Mobil 1 5w/30) and this light came on. Brought it right back to the shop and had them check oil level, cap, filter, plug...all are good. What could it be?
    -Steve G - 2005.5 A4 2.0T
    ***If you're reading this it was probably sent via TapTalk while driving my B7***
    2005.5 B7 AUDI A4 2.0T - UNITRONIC STAGE II / CTS TEST PIPE / GFB DV+ / RS4 RSB / OEM A3 STEERING WHEEL w/ PADDLE SHIFT MOD / LED INTERIOR MOD /
    Mar 31 2012
    Savannah. GA. USA. TO. ON. CAN
    Never had this problem. Faulty oil pressure sensor perhaps
    Btw, Mobil1 yes but why 5W30? and did the shop fill the OFHAF with oil first before reinstall?
    //S POWER
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    why not audi approved oil? are they using mobil 1 filters as well?
    Established Member Three Rings V2Rider's Avatar
    Feb 11 2014
    2011 Jeep Grand Cherokee, 2007 Audi A4 2.0T Quattro, 2006 GSXR 750 (very fast ) :)
    Minneapolis, MN USA
    X2, 5w40. I have seen a few instances on 30 weight oil throwing the oil pressure light.
    Tell them to do it right
    2007 Audi A4 2.0T Quattro TIP /Debadged/Piston DV/Hids/APR Stage 1 AMSOIL
    Veteran Member Four Rings A-BlacK_MambA-4's Avatar
    Jan 22 2011
    '05.5 A4 2.0T Tip Revo Stage 2; Wifes 2013 Chevy Cruze
    Ohio
    Quote Originally Posted by V2Rider View Post
    Links?
    I used Mobil 1 0w30 my last change and no such lights. Don't think it has to do with the oil. Sensor on the oil pan was unplugged and they didn't plug it back in maybe? (not sure why they would do that but a possibility) I'd check there. If it's plugged in unplug it and plug it back in and see if that fixes it.
    -JOEL
    The Real Black Mamba
    Feb 11 2014
    Minneapolis, MN USA
    I only say this in regards to a BMW forum that was discussing the slight pressure difference between 30 and 40 weight oil, especially when the oil is hot.
    I have no experience, as I have only run Amsoil 5w40
    Feb 28 2013
    NH
    I unplugged the oil pan sensor and plugged it back in...nada. I'm bringing it in to Audi tomorrow to look at it. It's running fine and no leaks on the cardboard I put under the car when I got home after. Hopefully it's just a sensor.
    5w30 is what they have always used and I've never had an issue with almost 140k on her.
    Jun 27 2011
    That is an oil level light not oil pressure guys, fyi. Did they forget to plug the sensor back in? or maybe damage the harness/connector? Seems like the most likely scenario...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Mar 24 2013
    Oakdale, CT
    Car's broken. I'll give you $100 for it sight unseen.
    -Adam
    Feb 28 2013
    NH
    The sensor looked fine and I unplugged and plugged back in when I got her home, just to make sure. Hopefully, Audi can tell me what it is tomorrow.
    I have a guy from VWVortex offering $125. If he flakes, I'll call you on the 2nd Tuesday of next week to set up the logistics.
    Feb 26 2008
    Maybe unplug the battery and plug it back in? Sounds dumb but its worked for error lights in the past for me
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Disconnect the flux and recapacitate the linear distributor, make sure to replace the transgasket differential and reseal the biaxle manifold otherwise you could run into serious problems down the road.
    Also I would make sure that there is 5 qts in there, drain the oil, put it back in.
    Feb 28 2013
    NH
    Quote Originally Posted by Dirtyylicous View Post
    Haha... I just came in from doing just that! No such luck. Aarrgghh....so aggravating.
    Is the biaxle manifold the one between the whosamajingy and the fukifiknow valve?
    I checked the oil level multiple times...its reading full!
    Sent from my Nexus 7
    Nov 16 2006
    Skokie, IL
    Not trying to sound like a douche bag, but are you cleaning the dip stick, re-inserting and then pulling it out to read? Are you reading it after turning the car on and letting it idle then turning it off? The low oil light can be as simply as 1 qt less than it should be, but the dip stick level should make it obvious that it's low.
    Feb 28 2013
    NH
    Looks like there was some road grime in the sensor plug connector from all this lousy weather that was causing a bad connection. Audi cleaned it out, re-connected it and I had them wrap some blk weather proof tape around the connection to better seal it from the elements.
    Charged me $50 but gave me a free oil change coupon to make up for the charge. Not too shabby...oh, and they have her a bath.
    Jan 22 2011
    Ohio
    Good deal. Glad it was something easy
    -JOEL
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Quote Originally Posted by A-BlacK_MambA-4 View Post
    don't wanna have oil consumption ever again? use mobile 0w40 thank me later =]
    Feb 11 2014
    Minneapolis, MN USA
    Quote Originally Posted by dalmation53 View Post
    Amsoil here, 1/2 quart every 3500 miles on average
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    That is the absolute worst of the bunch when it comes to oil consumption for me. The best have been LiquiMoli and Rotella T6 (which I am using now). Rotella is the best thus far.
    Jun 27 2011
    Can we PLEASE PLEASE not start a thread discussion which oil is the "best" for oil consumption?
    Posted from my iPhone. Any misspellings are Siri's fault.
    -CP
    2017 Q7 3.0t
    Feb 11 2014
    Minneapolis, MN USA
    lol
    Feb 11 2014
    Minneapolis, MN USA
    Quote Originally Posted by B7Joe View Post
    X2, I hear good stuff about Mobile, but have been with Amsoil in all vehicles for years with no ill effects.
    Jan 22 2011
    Ohio
    I've never had an oil consumption problem....................
    -JOEL
    Jun 27 2011
    You must use Mobil 1!
    /s
    -CP
    2017 Q7 3.0t
    Jan 22 2011
    Ohio
    /s
    Hahahahaha once. Motul 8100 X-cess FTW.
    -JOEL
    Aug 19 2013
    Miami
    I used 5w40 and was probably consuming 1 quart every 700 miles or so I was getting tired of that an was going to let the B7 GO. Then used 0w40 and since 5 months ago have not have any warning go on an for some reason it performes better in terms of acceleration..
    Feb 11 2014
    Minneapolis, MN USA
    You went from the reccomended weight burning 1 qt every 700 miles, to a NON reccommended burning nothing AND improving performance?
    GTFO
    Aug 19 2013
    Miami
    GTFO
    Well that's how my car feels atleast is working I guess, it's been 5 months of joy
    Jun 27 2011
    Confirmation bias is a terrible thing.
    -CP
    2017 Q7 3.0t
    Feb 28 2013
    NH
    The shop I've been going too uses Mobil 1 exclusively as their synthetic brand. They charge me $60 for an oil change. I really can't complain as I've never had a consumption issue with it.
