Page 1 of 3 123 LastLast
Results 1 to 40 of 86
    Veteran Member Four Rings pat_do's Avatar
    Feb 19 2012
    Montreal
    NGK BKR7EIX: stock gap - Noticing stronger power and smoother delivery.
    Guys,
    Recently ordere a bunch of maintenance parts from Europaparts and one of those items were the NGK spak plugs.
    I checked the gap and they were all at .028' in stock form. I removed the old spark plugs (original and had about 56k Miles on them) and also added new coil packs.
    The car seems to run smoother overall, and when stepping on it, jeez, the engine sure does sound and pull stronger. Is this normal? Have you experienced a better power delivery with new spark plugs and coil packs? Also changed the air filter for a new mann filter.
    Changed the oil dipstick since the old one has a broken o ring on it. I wasn't able to push 20psi before now...the car seems to hit 20psi easily.
    Pat
    Veteran Member Four Rings xander3zero's Avatar
    May 30 2013
    Rhode Island
    What tune and supporting mods are you running to hit 20 psi?
    Sent from my Nexus 7 using Tapatalk
    2017 Audi S3
    Mythos Black Metallic | Dynamic Package | Tech Package | S Sport Seats | Bang & Olufsen
    Previous:
    2013 Allroad Premium+
    2006 A4 Quattro 6MT
    Established Member Three Rings The_Ocho's Avatar
    Jul 07 2013
    45 Willys MB
    Las Vegas
    Quote Originally Posted by xander3zero View Post
    Idk about him but I hit 20 all day long with my car. Apr stage1 And cone filter
    2007 A4 2.0T Tip Quattro, St Coilovers, APR stage 2, HFC, DV+, Intake, Spacers, Stuff
    May 30 2013
    Rhode Island
    Quote Originally Posted by The_Ocho View Post
    Really? I only 18 peak with Apr stage 1 and my mods are in my Sig...I thought 18 was pretty normal for stage 1 Apr...might have to check for some leaks this spring
    2017 Audi S3
    Previous:
    2006 A4 Quattro 6MT
    Veteran Member Three Rings Obsidian's Avatar
    Jun 16 2012
    '06 A4 2.0t
    Valley of the Sun
    18-22 psi on APR stg II w/ TP & drop in filter.
    2006 Audi A4 2.0T / 6MT / Brilliant Black
    APR stg II / 034 Motorsport / aFe / Avus
    Feb 19 2012
    Montreal
    APR Stage 2 HPFP on a tiptronic. Boost holds in the upper 17-19psi even when shifting. 034 HFC mated to stock catback.
    APR HPFP new pump.
    034 Silicone boost hoses
    Jul 07 2013
    45 Willys MB
    Las Vegas
    16-18 is normal with 19-20 peak. But from my research iv seen that it changes car by car. Iv seen a few that hold 20. I guess my wastegate is just a little tighter than most
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    .028 is a good gap size for stock turbo cars. What was the gap on the old ones?
    Feb 26 2008
    I run the bkr7e coppers at .32. Should I try to gap them at .28 next time?
    Aug 31 2011
    Lathrop
    Quote Originally Posted by Dirtyylicous View Post
    .032 is still good. However, if you start off at .028 you have longer life of the plug as it wears before you start to misfire
    Feb 19 2012
    Montreal
    Quote Originally Posted by Jake@JHM View Post
    I think they looked like .32 stock Bosch sp.
    Jul 07 2013
    45 Willys MB
    Las Vegas
    I went out and got some today though I just got the BKR7E. For $11 I'll just change them every oil change. But it did smooth out boost a lot and it pulls a bit harder. Worth it
    Established Member Three Rings V2Rider's Avatar
    Feb 11 2014
    2011 Jeep Grand Cherokee, 2007 Audi A4 2.0T Quattro, 2006 GSXR 750 (very fast ) :)
    Minneapolis, MN USA
    That's exactly what I started doing, every oil change, BKR7E plugs.
    2007 Audi A4 2.0T Quattro TIP /Debadged/Piston DV/Hids/APR Stage 1 AMSOIL
    Feb 19 2012
    Montreal
    So spark plugs do help regain back some performance! Hahh
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Spark plugs and coils can 100% affect performance. Coil packs can go bad in different ways. They dont just completely fail most the time. Sometimes they just get weak, and lose a little power without you noticing.
    Sent from my SGH-M919 using Tapatalk
    2021 Audi S4, P34 Intake
    Feb 19 2012
    Montreal
    Surprising that these maintenance items mke quite a noticeabl difference!
    Glad I changed the coil packs and added new spark plugs.
    Established Member Two Rings seco007's Avatar
    Jan 06 2013
    Omaha, Nebraska
    Quote Originally Posted by pat_do View Post
    Guys,
    Pat
    Sorry to bump this thread but I just bought 4 new plugs at Advanced Auto (Google discount code and you get 30% off..total was 21.23 AFTER taxes)....and I measured them right there at the store and I was surprised to get a .043 FROM STOCK!!! ..and mind you I stopped measuring the moment I felt some resistance...so of course I bought the
    $ 1.49 measuring device to make sure I gap them accordingly.
    Aug 31 2011
    Lathrop
    You can expect a different gap when going with plugs that didn't go on the car from the factory. That is why it is always good to check them before installing them.
    Where those the Denso plugs?
    Jan 06 2013
    Omaha, Nebraska
    Quote Originally Posted by jake@jhm View Post
    you can expect a different gap when going with plugs that didn't go on the car from the factory. That is why it is always good to check them before installing them.
    Where those the denso plugs?
    ngk bkr7eix
    Feb 19 2012
    Montreal
    Very strange normally the stock gap is .028
    Get a real feeler gauge; the coin gauge is not accurate
    Senior Member Three Rings SwiftA4's Avatar
    Aug 20 2012
    Would there be a problem running the Denso ones gapped at 0.04? I'm currently running them now with no misfires. When I bought them, I tried gapping them to 0.032 but they didn't seem to wanna budge so I left them like that and threw them in.
    2008 A4 S-Line | APR Stage 1 93 | Ibis White | 2.0T Quattro Tip | Koni FSD/Eibach | Debadged | R8 Coilpacks | BKR8EIX | OEM Roof Rack | VEI/Podi | 15% Side, 5% Rear | Rev. "D" DV | 034 Snub |
    Retrofits: S4 Power Folding Mirrors | Warning Triangle |
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Several people are on the large gap train running 0.044, i did it for a bit, but it might have stressed my old coils as they failed over the next few months, new coilpacks and new plugs @ 0.032 and I couldnt tell a difference really.
    I run 0.030 in my 1.8T now.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Aug 31 2011
    Lathrop
    Quote Originally Posted by SwiftA4 View Post
    When I bought my B7 it had the densos at a .045 gap and as soon as I tuned the car it misfired like crazy. Brought the gap down to .028 and it was fine. But then I put OEM NGK plugs in it for R&D. These cars like the smaller gap and it is also less stress on the ignition components.
    Aug 20 2012
    Quote Originally Posted by Jay-Bee View Post
    I thought I saw people running the larger gap. I just put new red coilpacks in a few weeks ago. I'll pop the plugs back out this weekend and try to regap them down to around 0.028 since I'm planning on going Stage 1. I've noticed everyone recommends this gap for chipped vehicles.
    Thats what I assumed in regards to the ignition components. Thanks Jake.
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    hey Pat can you elaborateon the broken already on your dipstick? my dipstick is also broken, those two little plastic notches on the dipstick have crumbled up and fell off. Do you think those would cause me to leak pressure?
    2008 A4 S-line 2.0T
    JHM Stage 2
    Feb 19 2012
    Montreal
    Quote Originally Posted by Schweini View Post
    HeyJoe,
    The 2 plastic notches we broken. The o-ring right below the handle was finished...and i threw it out.
    All of that said, without the o-ring on the top portion of the boost is bled off in tiny amounts. It was so long ago that I was able to hit 21psi....now...my podi gauge hits that mrk consistently.
    how many psi are you hitting?
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    HeyJoe,
    I never see 20psi... 18 max at stage 2+ apr. Ive tried everything and now you got me thinking its the dipstick
    2008 A4 S-line 2.0T
    JHM Stage 2
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    ^ get a new dipstick and call it a day. My notches and O-ring were gone when I changed my oil last. IIRC a new dipstick is around $20.
    smaller gap is going to make the plugs and coils work harder and prone to fail faster like Jake said. too big of a gap and the spark isnt going to last as long. I've always read that plugs come gapped from the factory but everyone checks them anyways..well most people do haha.
    OP - what gear are you in when you hit 20psi?
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Feb 19 2012
    Montreal
    Quote Originally Posted by thenofjboy View Post
    2nd gear
    All gears...its an automatic...it holds boost between shifts
    Senior Member Three Rings turbowop's Avatar
    Dec 01 2012
    '91 Mitsu GVR4
    Yakima, WA, PNW
    Huh? The dipstick is in no way, shape, or form connected to the intercooler plumbing. If anything, with that o-ring damaged, you will vent some extra crankcase pressure. It makes zero sense that you would see increased boost pressure by replacing the dipstick o-ring.
    And nobody should be feeling power gains via butt-dyno by changing the spark plug gap. Unless you're getting obvious misfires, you're not going to make a noticeable difference in power regardless of gap. Smoother at idle? Maybe, MAYBE. But most likely, this is all placebo. Somebody wanna prove it otherwise? Put the car on a dyno and try out some different gap sizes. I guarantee you won't see significant changes that can be traced back to the gap size. You'll see more of a difference from air temp or coolant temps causing a change in boost pressure or timing.
    -Mark
    '91 Mitsu GVR4 #1051 / 425awhp / 11.90@121mph / tuning and wrenching by me / full weight @ 3280lbs
    '08 Audi A4 2.0t 6mt Quattro / Ibis white / convenience & premium package / APR 2+ flash / APR exhaust / APR HPFP / 034 test pipe / CTS FMIC / Stasis street sport coilovers / RS4 rear swaybar / Thor undertray / Podi boost gauge / BFI snub /
    Thule ski rack / tint / paint matched reflectors / 19" Hartmann R8's on Conti DW summers / 17" stock split-5's on Dunlop Graspic winters
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Quote Originally Posted by turbowop View Post
    Go pull your dipstick with the engine running and come back and state that again ;)
    a broken dipstick WILL create a vacuum/boost leak with the way our PCV system is routed.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Did the same with my Avant and it made things so much smoother.
    Dec 01 2012
    '91 Mitsu GVR4
    Yakima, WA, PNW
    I guess I better study up on the way this things PCV system works. I would think that the vacuum you see at the intake manifold would be completely separate from crankcase ventilation. I'm getting old. Cars are getting more complicated...
    -Mark
    Active Member Four Rings waiapasi2006's Avatar
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    I don't remember the NGK's I got a while back, but how often should we replace these?
    Waiapasi2006
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by seco007 View Post
    Take a photo of the box with the part number. If it has a number appended to the part number, that means the stock gap is different. That looks like .044 to me which would make me think its a "-11".
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    New dipstick ordered, thanks for the suggestion guys
    my o-rings have been completely broken off. Hope this helps
    2008 A4 S-line 2.0T
    JHM Stage 2
    Feb 19 2012
    Montreal
    You will notice a difference
    Jan 06 2013
    Omaha, Nebraska
    Quote Originally Posted by PNW Avant View Post
    You sir are a gentleman and a scholar.....
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    #thumbup
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    I remembered replacing my originals with stock pre-gapped OEM NGK PFR7S8EG (Audi parts dept) and my car pulls at a pretty efficient rate, and most notably smooth. It all depends on your car. Mine is 100% stock.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
