I have been fighting what I assume is an air pocket for days? This all started with a coolant flange change. Upper hose on radiator hot, lower hose ambient temp. Temp spikes while driving. Changed thermostat thinking may be the problem, nope. Sucked it down twice and refilled via vacuum, now no heat. Did the best I could going systematically through the coolant system looking for a clog and there appears to be none. (I did get a small amount of debris out of the heater core). The water pump impeller seems to be intact and not free from the shaft, unless as water temp increases the impeller begins to slip on the shaft. Is there a way to ensure water pump is moving coolant? Any thoughts or suggestions?? Thanks in advance.
