Car had some problems a while back so i took it off the road. Got somenice weather today and trying to figure out the proble. Installed an electronic battery kill switch today. Now onto the questions
1.Get into car start raise to level 4. Turn car off lock doors disengage battery car seems to hold level 4 w no problems.
2. As soon as the car battery is turned back on the back end drops. You hear what i believe is the solenoid open and air being released. Which seems to happen 2 or 3 times dropping it down usually to level 2. I have not let it sit overnight yet but would assume it would drop to the ground.
So now if power is off holds air i assume bags are fine? I have 2 replacement rears if anyone would suggest replacing them
I have 2 replacement sensor that i need to pick up, i assume they are faultytelling the car to drop when power is back ON in the car? I would assume replacing them 1st would be the problem.
Or has my solenoids crapped out and they are just opening as they feel? If so i assume ill be looking for the control unit?
Vag com was just cleared. No codes after cycling the car on and off a few times.
Suggestions are welcome. Please advise. Ive searched and not found anyone doing a trial and error by removing battery. (4:00pm)
(6:40 pm)Its been about 2.5 hours with battery off and still holding on level 2 right now.
