I know this has been discussed before in past threads, but I still find it surprising how great the oil level readings between a stone cold engine in the morning vs a warmed up engine can show.
I've owned numerous cars where the oil levels were almost the same readings when taken while the motor was cold or warm, but with my S4 it's a pretty large change in reading.
When cold it shows basically just above the bottom plastic knob on the stick, so about maybe 20% on the metal portion of the stick. While when at operating temperature and shut down for a minimum of 2 mins as per the Audi manual it will show 80-100% full on the stick.
It's a bit shocking when I check it cold sometimes and find that the car is showing so low since I'm still tracking my oil consumption rate. Some brands of oil darken up faster and hence show an easier reading. The Liqui Moly Top tech 4100 I'm running has stayed very clear and resulted in more difficult readings especially while warm.
Has anyone else noticed this or am I losing it?
