Results 1 to 29 of 29
    Veteran Member Three Rings a2 4.0t's Avatar
    Jun 18 2012
    Jimmy Hoffa
    Ocean City / New Jersey
    19x8.5 with 235,35, 19 tire load issues, shop won't sell/mount tires
    I have a set of 19x8.5 et35 wheels and I was going to go with a 235,35 r19 tire to avoid clearance issues because I'm lowered on coils. When I called the shop to purchase the tires they said that they wouldn't mount 235 tires on the car because they don't have the correct load rating for the b8 a4.
    I thought this was a fairly common setup on our cars? Is anyone else running this configuration, if so what brand of tires do you have? And have you run into any issues?
    2012 A4 s-line
    |Carbonio intake | APR quad outlet exhaust with tons of RSC technology | AWE downpipe | s4 rear valence | Vogtland coil overs | Rotiform BLQ's | stage 3+ Chinese turbo whistle |
    Senior Member Four Rings r6_11b8's Avatar
    Oct 03 2013
    los ángeles
    19 9.5 on 235/35/19 here…find a different tire shop lol
    2011 A4 ice silver metallic
    MODS- 25% tint rear, 75% front, 19" Rotiform BLQ, Solo Werkes coilovers, Custom FXR projectors
    upcoming mods - 10 inch sub
    2009 Yamaha R6 - Shogun FS-Zero Gravity-Custom FE-Hot Bodies Flush Mounts-MotoDynamic Integrated Tail Light-Supersprox -1+2-Taylormade Full Exhaust-PCV-OURY Grips-Corbin Seat-Ebay Shorty Levers
    Dec 01 2011
    i think they are just being cautious and dont want to be liable if anything happens. they prob are wanting to stick to the OEM 255, but 235 is definitely ok on 8.5 wheels, not even near a stretch and is a good flush fit. yeah i'd check out a different shop.
    IG @theshawon
    Jun 14 2005
    Anaheim, CA
    I honestly have never sold a 235/35/19 tire for a B8 before. Usually our customers run a 245/35/19 or 255/35/19. Those wheel specs aren't super aggressive, so you should be able to get away with a wire tire option. The issue isn't whether it's going to be stretched or not, because a 235/35/19 on an 8.5 will fit just fine, but it's the load index, like the tire shop is mentioning. The tire could theoretically get damaged while driving if the weight rating is not to spec.
    Brandon @ VMR Wheels
    Aug 28 2013
    Ft. Lauderdale
    I'm on 235/35/19 on a 19x10 set up lol
    2010 Grandpa Beige A4 | APR | Solo-werk | Rotiform | Vag Com | Stvbek |
    insta-@cleanb8
    May 21 2010
    Read post #4. Load rating on sidewall. Every tire has one.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by Wilbur View Post
    +1, its not necessarily the tire size or how stretched it is, its the tires load carrying capacity, I think our cars require a minimum load capacity of 93?
    Jun 18 2012
    Jimmy Hoffa
    Quote Originally Posted by VMRWheels View Post
    I understand that the load index corresponds to the weight of the car, but isn't there a 235 tire with the proper load index rating?
    Also those of you running stretched tires which tire/brand did you go with?
    2012 A4 s-line
    Feb 06 2012
    Allentown, PA
    91 is the highest load rating Tire Rack has for that size; http://www.tirerack.com/tires/TireSe...35&diameter=19
    Jun 18 2012
    Jimmy Hoffa
    Quote Originally Posted by o1turbo30v View Post
    thanks for the link, I just checked it out, I guess a 93 in 235 really doesn't exist.
    I also looked into the weight that corresponds to each tires load rating.
    91 1356 lbs
    93 1433 lbs
    so there is a 77 pound difference in the rating per tire, although if I'm thinking about this correctly, if you multiply the 91 rating by 4 you get 5,424lbs total which is still significantly more than the b8's curb weight of 3549 lbs, so it shouldn't be too much of a risk right? although I'm sure if you drove aggressively it could shift a lot of weight to each corner.
    2012 A4 s-line
    Veteran Member Four Rings smetch's Avatar
    Jun 21 2013
    long island
    hahah I just got the same thing done to me, your using discounttiredirect.com they wont sell you a 235/35/19 because the weight of the car requires a 96 load rating, 235 has 91, the guy said to run 245 and use make psi to have like a 94 which is suitable. I just went to the same trouble with them, just tell them you have a bmw or porsche something that uses that tire. goodluck
    May 21 2010
    Just go 245 to be safe AND avoid stretch .
    Jan 10 2007
    VA
    I you are so low that a 245/35/19 would rub and thus you're choosing to stretch a 235 for clerance, you're too low. Just raise your coilovers a tad so you can run a 245 with proper load index.
    Just my 2 cents.
    Registered User Four Rings Need4Speed's Avatar
    Jul 25 2013
    Glendale/CA
    find a different shop to do the mounting for you.
    I have stretched a 235/35/20 tire on a 20x10.5 before
    It can be done they just don't want to do it.
    a 235 tire will be fine for a 8.5 wheel it will have a stretch
    just remember as the tire is stretched and depending on your roads it will wear out more.
    Jun 18 2012
    Jimmy Hoffa
    Quote Originally Posted by b6onboost View Post
    Just my 2 cents.
    That was my first choice but, the rears are maxed out height wise.
    I just test fitted the wheels with the 255's again and I'm thinking 245's might just work.
    Are there any brands that run slightly narrower than size?
    2012 A4 s-line
    Jun 18 2012
    Jimmy Hoffa
    those of you running 8.5's with 235s or stretched tires in general what brand/tire are you going with? I'm hoping to place an order for tires tonight and tie a bow on this fitment issue.
    2012 A4 s-line
    Jan 10 2007
    VA
    Yes. If you put different brand '245' tires on the same wheel some will be more streched than others which provides a little more clearance. If you search online you can find the exact specs for any tire.
    Quote Originally Posted by a2 4.0t View Post
    Dec 14 2013
    Wilts, UK
    My contact 3, 255's are narrower than my Michlin 245 winters
    Senior Member Three Rings billyhelmsorig's Avatar
    Oct 22 2012
    long island NY
    I was also thinking about doing 235 on my next wheel/tire set up. anybody have pics of how much the tire would be stretched on a 8.5 or 9 inch wide wheel?
    09 b8 ibis white, 18% tint,, LED interior/plate lights , 5k hid headlights, yellow fog's, VAGCOM mods, plasti dip stock grille, AG M510'S 19x9.5with 245/35/19 hankook evo 12 tires, h&r coilovers
    follow me on instagram @billytoad http://instagram.com/billytoad
    Established Member Two Rings BlackedoutB8's Avatar
    Nov 22 2013
    Fort Myers
    Im rolling on 235/30/20 nitto invo's on a 20x8.5 wheel. Il see if I can find some pics real quick
    2013 A4 Quattro | 20" XO Miami's | ST Coilovers | Mesh Grill/Foglights
    IG: jacobjohnsonnn
    Nov 22 2013
    Fort Myers
    IG: jacobjohnsonnn
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    91 1356 lbs
    93 1433 lbs
    Quote Originally Posted by smetch View Post
    Wait a minute, so is running a 235/35 R19 on 19x9 OEM Peelers not recommended because of the load rating? I looking for a stretch but I also don't want to blow out my tires.
    I'm currently running 19x9.5 Niche Targa's using 245/35 R19 and there's a stretch, but I only checked to see if I was within the recommended diameter variation (within 3% of OEM) and I didn't bother checking the load ratings!
    Help! I don't wanna blow up!
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
    Veteran Member Four Rings 100Daily's Avatar
    Jul 03 2010
    Parker, CO
    Call Tire Rack. They know.
    2012 Audi R8 V10 Gated - Stage 1 - Phantom Black - Carbon Package
    Gone But Not Forgotten: 2013 S4 3.0 ---- 2008 A5 3.2 ---- 2005.5 A4 2.0T ---- 1993 90S 2.8
    Jun 18 2012
    Jimmy Hoffa
    Quote Originally Posted by doowopaudi View Post
    A cautionary tale:
    I got a flat after hitting a nail a couple weeks ago & when I went to put my stock wheels on I found that the inner sidewall of 1 of the tires was completely blown/bubbled out & another wheel had multiple bubbles on the inner sidewall. It was actually pretty scary to find this & realize I could have easily had a blowout at any moment.
    A couple of my wheels were very slightly out of round & I was usually pretty lax with maintaining the air pressure so there may have been other contributing factors. I am sure there are people who would argue that they have run 235 tires without issue.
    However, after this experience I wasn't willing to risk it so when I ordered a new set of wheels I went with 245s that had the proper load index.
    2012 A4 s-line
    Oct 03 2013
    los ángeles
    i had 225/35 before i went up to a 235 ride quality was pretty bad on a 225....as long as the person knows what theyre doing when it comes to installing tires you wont have any issues...if you have uneven tire wear then thats a suspension/alignment issue...but 235 on a 9.5 isnt that extreme at all
    Aug 10 2011
    North Whittier
    Quote Originally Posted by r6_11b8 View Post
    Are you still running 235 on 9.5? Do you have any pics?
    Oct 03 2013
    los ángeles
    yep...this is the only pic i have that shows the rim and tire up close ill get some rear angle shots later when i get home..and the second pic was me coming out of my driveway(im not that low lol)
    Aug 10 2011
    North Whittier
    Wooo! That's stretching it! :)
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    I'm running 235 series for winter. My Dunlops are a 91 load rating which according to some searches is fine. I'm on 255 for summers. Haven't had any issues except the cost of the tires seems to get higher the narrower the aspect ratio.
