Results 1 to 35 of 35
    Veteran Member Four Rings S4UCE's Avatar
    Aug 21 2007
    Fairfield County, CT
    Make my valve covers stop leaking.
    I've had leaky valve covers/cam plugs forever. In the fall, I had a shop (owned by a friend, well versed in 2.7Ts) do my valve covers and cam seals. Get the car home, find it's still leaking. Bring it back, they find one cam seal is dumping oil and reseal it. Get the car home, it's still leaking. Bring it back, they pull the covers off and the surface seems pitted and scratched, so they put new valve covers on it. This is right around the new year. It doesn't leak for like 2 weeks and then I start catching whiffs of oil again. Fast forward to today and there's a puddle in my parking spot and for the past month the thing stinks on every drive, but I'm just kind of living with it. Help me find the will to live. Thank you.
    Veteran Member Three Rings kingkhalilz's Avatar
    Jan 31 2013
    Mchigan
    Might want to do it yourself. Don't know what that shops deal is however, I have done plenty of these. Most important is rtv or silicon on the sharp corners, dont go crazy with it but a little helps. Cam caps rtv or silicon the edges when you push new ones in. Also torque the bolts down evenly and to spec. Of course if you dont have a nice smooth surface you got some problems. Make sure the gasket you receive is good and not starting to crack. The middle gasket thats 3 rings is recommended to replace as well. Oil around the spark plugs is no bueno.
    May 16 2008
    WA
    its not the tensioner gasket causing the mess by chance is it?
    Active Member Four Rings
    Nov 12 2013
    '01 S4 Tip '91 200 20VTQA, '01 A6 2.7TA, VW Rabbit GTI truck.
    SanHo, CA
    Did they replace the cam tensioner gaskets? That's where most of the upper end leaks come from.
    Nov 12 2013
    SanHo, CA
    Quote Originally Posted by getslideways View Post
    Dang, I need to type faster...
    Veteran Member Three Rings uponone nogaro's Avatar
    Sep 13 2011
    01 Silver S4, 00 Noggy S4 Sport Package, B8.5 Dsg S4 Dual Pulley,240sx w/2j swap
    Bay Area CA.
    good thread i have to do mines also did you use oem gaskets? is oem the best to go with or
    Aug 05 2011
    Memphis, TN for now!
    I would also check on the PCV system...if it is building up pressure then your valve covers will want to leak.
    Get a quality set of VCG's... I noticed on my recent purchase from NAPA that they seem to be of much better quality. Had OEM audi part numbers on packaging...made by elring.
    As stated...use sealant in corners and do not overtighten.
    Veteran Member Four Rings ilyafil's Avatar
    Nov 03 2011
    Bay Area , CA
    Quote Originally Posted by airjawed View Post
    This!!!
    "Basically the B7 is the girl you bring home to mom, and the B5 is her slutty sister."
    For Sale: Neuspeed Sport Springs
    Veteran Member Three Rings EMF614's Avatar
    Jun 15 2011
    cbus
    this may be a long shot but do you think faulty primary o2 sensors causing the car to run rich would mess with the PCV system, blowing the seals on the vcg.
    I'm having this same issue. I changed my vcg, cam seals, etc and it started leaking, re did the gaskets and my spark plug holes are still filled with oil.
    I just changed my primary o2 sensors and I will be redoing the gaskets this summer. Maybe this will fix it?
    Ethan
    Single Turbo B5 S4
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    honestly i've changed out like 2 of the vcg's in 10 years of ownership. done once, never needed again. head gasket done once. the little cam chain tensioners were spewing oil pretty good... replaced those. turbos have gone twice... even had the lines on my oil cooler fall off once (shop cut the line to short and didn't click it in).
    bottom line is oil leaks from just about everywhere at some point or another. but you replace them once and they should be good for 60-100k. any repeat fix is total nonsense.
    Sep 07 2012
    Tucson, AZ
    Quote Originally Posted by kingkhalilz View Post
    +1. When I changed my valve cover gaskets right after I bought my s4, I made sure to apply rtv on the tops and bottoms of the corners and no leaks after over a year. Same with half moons and cams tensioner gaskets. (Knocks on wood) Sounds like the shop wasn't too familiar with the 2.7's and the vulnerability they have to leaking in these areas. The rtv is really key here.
    Aug 05 2011
    Quote Originally Posted by EMF614 View Post
    Depends how rich... if fuel and oil are mixing heavily due to misfire then possible(gas eating seals and sealant). Otherwise I would not look at that as a cause. How long before it leaked after fixing?
    Our cars are prone to leaking....but a leak doesn't mean it is normal. Find the problem.
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    I'm pretty sure they are rtv-ing to all the people stating that. If they are a remotely professional shop, they know better.
    We had a problem like this on a car at my shop. Although it wasn't cam seal. It was the crank seal. Car kept blowing them out. Turns out crank was wiped along with thrust bearings and crank was moving in and out.
    What kind of shape is your cam in? Check for play etc.
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Sep 11 2009
    NE
    Have they replaced cam plugs/caps too? These are the hockey puck like things pressed in back of head and one in front. These age and are rarely replaced with "VCG". You don't even need to open the haeds to swap them as they are external. If you ONLY smell oil about 3-5 minutes after start up and it clears afterwards without oil smell until the car cools down (this is when they shrink and allow residual oil to seep around them) and cycle repeats, that's plugs. Unless they are completely dead in which case they might let oil through 24/7.
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    From my experience it always leaks from the camseals behind the sprockets. This is because a lot of oil rests there as its a v motor and oil pools at the bottoms. Same goes for the cam caps in the back of the motor.
    Make sure u grease the inside of the cam seal so it's not dry
    Like everyone said, clean well and apply rtv in corners and torque with torque wrench to 7ftlbs in an inside out bolt sequence so it's torqued evenly.
    Also make sure green check valves are working and also the check valve on the pcv
    Aug 21 2007
    The shop has a ton of experience with 2.7Ts which is why I'm thinking there's something wrong with my car rather than something wrong with their work. I will check the PCV system before the next attempted re-seal.
    Nov 03 2011
    Bay Area , CA
    Quote Originally Posted by S4UCE View Post
    How much boost are you running? Anything higher than stock requires upgraded PCV.
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    Quote Originally Posted by ilyafil View Post
    Tell that to 90% of stage 3 owners who are running the stock PCV system...
    2005 Ferrari F430
    2007 RS4 Daytona Grey | 2008 RS4 Mugello w/Ti Package | 2007 RS4 Avus Silver (ex-Audi Corporate) | 2008 RS4 Avus Silver w/Exclusive Package
    B6 S4 Avant 6MT Dolphin Grey
    B5 S4 Avant 6MT Laser Red Stage 3+
    B5 S4 Sedan 6MT Silver Stage 1
    Veteran Member Four Rings gottaBdope's Avatar
    Apr 07 2012
    '99 Clown Shoe
    Colorful, Colorado
    Didn't read the whole thread, but just a plug: the shop I worked at wouldn't touch victor reinz for any reason, and from what I saw there, rightfully so. Unfortunately that seems to be the most common option. 034 stands by that brand and I bought them for my build. Just something to think about. Rtv seems to be the answer.
    ^Rory^
    *2014 Audi S6* <- Daily
    *1999 BMW Z3 Coupe* <- Street-legal Track
    Jun 14 2007
    2000 S4
    Connecticut
    He has a vented oil cap... He has the updated intake manifold running the newer style PCV which he took apart and replaced the hoses.. Possibly the pancake valve? I would think that if your PCV is shot you would be puffing the oil out of the exhaust as it would be returned to the intake to be burnt off rather than seeping out of the engine.
    I guess the one way valves could be updated, but do you really think a stuck one way valve is going to cause oil to seep out of the valve covers?
    Aug 21 2007
    I was running up to 25 pounds on F4Hs when my MBC started to run away
    Quote Originally Posted by gottaBdope View Post
    I'm pretty sure they used Victor Reinz. I had those on the car years ago with no issue.
    Jun 14 2007
    2000 S4
    Connecticut
    Here's the self study guide.. Can someone explain how stuck one way valves would cause seepage? Srs question lol
    http://www.ibiblio.org/tkan/audi/2.7...-SelfStudy.pdf
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    NVM. I didn't read good
    Oct 27 2011
    TOYS
    Philly Suburbs
    If crankcase pressure (due to blow by) is unable to be released via the breather/pvc system, the pressure will get out in other more creative ways... like through your seals...
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    If you are talking about the smaller check valve to the intake, it dont do that. Many people run with it capped.
    The pancake prv valve can though.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Veteran Member Three Rings mightemouce's Avatar
    Mar 12 2007
    01 S4
    Next time you park, take the filler cap off and see if you get a sound of pressure relief.
    If its leaking when hes parked I can't see the PCV system being an issue unless its holding pressure still.
    I should have the "pancake" valve at home if you want to give a different one a shot.
    Leaning towards your Cam Chain Tensioner seals possibly leaking.. I don't remember if these have been changed on the car.
    07 - RS4
    05.5 - 2.7t B7 -Sold
    Insta-Ste3v3_0
    Sep 11 2009
    NE
    Quote Originally Posted by mightemouce View Post
    Severe PCV problems like this would cause excessive smoking from exhaust and oil in intercoolers as oil would be forced from both side of shaft. Also, the crankcase would probably pressrizeat at idle too, easily detectable with a sheet or paper put flat against oil filler hole, if it bows out, there is pressure in crankcase.
    Aug 21 2007
    I'm coming out of "ignore the problem" mode and transitioning to "throw parts at it" mode. Hopefully we can get it sorted before I decide it's a good idea to do rods and bigger turbos because of an oil leak.
    My exhaust is free of blue smoke. My oil comes exclusively from the top end of the motor.
    Oct 27 2011
    TOYS
    Philly Suburbs
    When I originally installed my new half moon CCT gaskets, I did not put any sealant around this piece and it caused a major oil leak like you are describing. I only use Audi gasket maker BTW from GAP ($20/tube, this stuff is awesome and sets up quick!)
    Mar 12 2007
    01 S4
    Quote Originally Posted by julex View Post
    I don't see the car in mention having severe PCV problems, there is no smoking from the exhaust. If I recall correctly his intake tract is pretty dry as well (have not seen it in awhile though).
    07 - RS4
    Insta-Ste3v3_0
    Jun 14 2007
    2000 S4
    Connecticut
    Right.. That's why I really don't think it's PCV related but more of an issue that something is being overlooked or skipped. Like the tensioners. No one does those.. Mine were done during timing belt job.
    Aug 05 2011
    It is possible that your PCV is working correctly at most boost levels but at full boost it is getting overwhelmed...especially if your N75 is dumping everything into the valve covers(I see you mention MBC getting overwhelmed).
    Might be time to put a vacuum gauge on and see what the pressures are like under the valve covers.... might also be time for a catch can? Seems your PCV is not stock so not sure if problem is gaskets themselves or something else.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    I like where this is headed
    May 01 2010
    Atlanta
    If the PCV system is clogged anywhere, oil will come pouring out of the vented cap before it will blow out any of the top end seals. Just my experience.
    2005 Ferrari F430
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Many ignore the half moons. I ran Victor Reintz VCG for 18 months before replacing with OEM when my engine was pulled for turbos. At that time, I had every bloody seal and gasket changed. No more oil leaks.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
