Results 1 to 20 of 20
    Established Member Two Rings osoquik's Avatar
    Oct 08 2008
    alabama
    Lug bolt spins but never tightens, can't get it out. Any trick to this?
    Rotated the tires and I had one bolt go in and it never tightened up completely. Tried to remove it and it won't back out now. What is the best way to get the lug bolt out? Any help is greatly appreciated!
    19" VMR Gunmetal 708's/Bilstein PSS9's/Hotchkis RS4 Sways/JHM Tune/JHM Piggies / Fast Intentions 2.5" Cat Back/Brembo Cross Dimpled-slotted Rotors/Uberhaus Front Spoiler/ DTH sides
    Jun 17 2013
    jersey city nj
    Use a 12 point socket with a shop rag covering the opening of the socket and jamb onto the lug nut. Use a impact gun or ratchet if you don't have a gun and rotate it counterclockwise while twisting it outwards should do the trick
    Oct 16 2008
    South Florida - Ft Lauderdale
    If it spins, it's well stripped
    Jack the car
    Remove all good lugs from the wheel
    Now with another set of hands, have someone put some pressure on the lug by pushing out the wheel while you try to unscrew the lug
    Phil
    Oct 16 2008
    Quote Originally Posted by vce1232000 View Post
    If the lug spins, gun won't do crap, just spin even more
    Phil
    Jun 17 2013
    jersey city nj
    Phil
    He has to do a pulling out action while the gun is spinning . That,s why I suggested the rag so it will keep the socket jambed into the lug nut. I like your idea also.
    Oct 08 2008
    alabama
    God I hope this works...Wife's car, and I'm screwed if I can't get this thing out! Thanks and keep them coming. All tricks welcome!
    Oct 16 2008
    Quote Originally Posted by osoquik View Post
    Well try and keep us posted
    Phil
    Oct 08 2008
    alabama
    Will do Phil, thanks! The lug bolts in these cars are total crap. I've never had this much trouble with studs. That's my next direction!
    Jun 17 2013
    jersey city nj
    Jack the car
    Now sit on the ground facing the tire. Have the bad lug nut at a 12 o'clock position and your foot pressing against the tire at 6 o'clock applying psi and try spinning the lug nut with tool of choice. The psi will maybe enough to grab what ever good threads left and possible spin off
    Phil
    Combined idea
    Oct 08 2008
    alabama
    Combined idea
    That is a good one. This will take an extra set of hands out of the equation...
    Established Member Two Rings Eddy Jo's Avatar
    Jan 11 2013
    11 TDI Jetta wagon, 07 A4 Quattro MT Premium
    Leigh Valley PA
    Had they problem when I had new tires put on a while ago - The tire "kid" used an impact gun and ran the lug in with to much tork- I had to cut it out with a torch and scar/ruin a rim- I use the same product you use on plugs- Anti Seize- never had a problem since- (the ruined rim is my spare-
    Jun 17 2013
    jersey city nj
    That's what the is all about
    Active Member Four Rings waiapasi2006's Avatar
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    That is why I always check my lugs when I leave any tire service place.
    It happend to my previous vehicle. Too much torx with one messed up lug.
    I learned it the hard way, but you should always keep an eye on it.
    Just my $0.02 Better to be safe then sorry.
    Waiapasi2006
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Quote Originally Posted by Eddy Jo View Post
    Quote Originally Posted by waiapasi2006 View Post
    *torque
    Feb 25 2011
    Seacoast NH
    Anti seize on lugs is a no-no I thought. Because it screws with torque settings.
    Oct 08 2008
    alabama
    Got it out with the combined method of pushing on the oppposite side of the wheel from the stripped bolt. Worked like a champ without issue. Retapped the hole and fixed it up for a new bolt for now. Going the stud route, so this is the last time I'm dealing with these shitty bolts. Thanks so much for all the help! This site f***in' rules!
    Oct 16 2008
    Glad he worked out
    Phil
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    I remember a couple years back, some kid had a wheel bolt stuck on his MK5 GTI, so they CUT the wheel off some how, hilarity ensued it was all over Vortex.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Veteran Member Four Rings Inked's Avatar
    Dec 11 2010
    Polaris Outlaw 525 Quad
    Central FL
    Quote Originally Posted by Jay-Bee View Post
    Damn lol
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    I broke the teeth on the locking key lug nut last year. That was a MAJOR pita. I bought a socket to jam over top the lug and then try to unscrew it that way, but damn Audi has to make circular lugs (probably to prevent thieves doing just that).
    2008 A4 S-line 2.0T
    JHM Stage 2
