Results 1 to 22 of 22
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Blew off intercooler hose, damage?
    I was driving at lunch today during work and hit the gas a bit, off came drivers side intercooler hose accompanied by a loud whoosh sound I immediately realized what happened and drove back to work in vacuum. So did I potentially hurt anything? Just going to reconnect it after work and drive home.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Apr 07 2011
    Home of the mighty beaver
    nope you will be just fine. as long as you didnt suck any rocks in.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by S4James View Post
    Wish this was true for me after I got my STK running last year. I forgot I had a "temporary" pipe with no weld beads right up near my ds headlight. Well I was taking a friend for a quick spin to show him what 22psi felt like on the new revision of my tune and pop..... goes my headlight tabs
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    you're fine. I've blown off hoses a bunch of times.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    Quote Originally Posted by CELison View Post
    some people say driving for more than a few miles like that will over spin turbos and damage them. Not sure how much truth in this. Probably from running rich there is some likelyhood of fouling O2 sensors and plugs.
    Veteran Member Four Rings ilyafil's Avatar
    Nov 03 2011
    Bay Area , CA
    Shit, I'm still having issues with 034 TB boot blowing off. I've tried hairspray and sleeved clamps, still blow the DS bi-pipe. Time to go APR I guess.
    "Basically the B7 is the girl you bring home to mom, and the B5 is her slutty sister."
    For Sale: Neuspeed Sport Springs
    Dec 04 2012
    Arlington VA
    Quote Originally Posted by ilyafil View Post
    S..Time to go ARP I guess.
    Best way to forget about the cursed TBB
    Nov 03 2011
    Bay Area , CA
    Quote Originally Posted by V1nny View Post
    I know right, so phuking sick of it!!!
    Jun 14 2012
    2000 Jeep Wrangler TJ
    Tampa, FL
    I just went with APR....no i have to tap it for meth...what a pain haha
    Jun 11 2013
    2004 BMW 325i
    South Florida
    I got tired of the TBB pretty early on and forked out the cash for the APR bipipe. After breaking 2 boots, I had no patience left for it. I changed my oil this past weekend and took the hose off to access the filter better. Guess I didn't clamp it down well enough. That's what you get for 20+ psi.
    Nov 03 2011
    Bay Area , CA
    Use these
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    the tbb is not the only boost hose that pops off. most people don't have other ones too often though. very common to have boost leaks, and its not a super serious issue with devastating reprocutions for your other parts.
    engine movement and chasity flex are as important (or even more so) than boost pressure as far as popping off hoses.
    clean it super well, get quality clamps, snug it up, check your engine mounts, and ride it until it fails again. rinse and repeat.
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Guess I'm lucky. 22psi never had a hose pop off. Not even my bi-pipes with samco.
    Sent from my SCH-I535 using Tapatalk
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Use these
    I have these very same Swedish ABA clamps on everything with boost associated with it. Bought a box load of them from ECS. Very good clamps, but I have to remember to tighten them down properly
    Sep 11 2009
    NE
    I blew hoses off at least 10 times, it makes a very loud pop doing that at over 30psi :).
    And no, you cannot overspin a turbo once you pop a hose off since your engine essentially immediately stalls since MAF is no registering any flow.
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Quote Originally Posted by julex View Post
    I was at 27psi when mine "popped" :) I noticed the slight stall.. good to know it didn't over spin.
    Veteran Member Four Rings sherbet's Avatar
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    Tbolt! Last week my samco TBB blew off. I replaced it with a 034 and Tbolt clamp and have not had any problems with it yet.
    B5S4 Sedan/ Stg lll/6MT/ Trouble
    B5S4 Avant/ Stg ll/6MT/Daily
    Sep 11 2009
    NE
    Quote Originally Posted by sherbet View Post
    034 is crap, too soft so it balloons and pulls the material from under the clamps. IE boots are way stiffer and don't have that issue.
    Nov 03 2011
    Bay Area , CA
    This! I'm so sick of mine! I'm gonna try one more thing (contact cement) and if it doesn't work I'm going APR.
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Installing the APR bipipe is lots of fun, just so you know. There will be blood. There will be cursing. There should be beer.
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    I actually went and check on it last night. Still didn't sit well. I put the samco back on just with a Tbolt this time. That should solve it.
    Veteran Member Three Rings EMF614's Avatar
    Jun 15 2011
    cbus
    I don't think you will over boost the turbos w/ a blown off intercooler hose as the wastegate should prevent this.
    Like others said above, no damage should be done unless debris are sucked in.
    Ethan
    Single Turbo B5 S4
