Results 1 to 30 of 30
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    For those who painted the instrument cluster trim black...
    What paint did you use and how well did it match? I am trying to decide between:
    Wurth: http://www.eeuroparts.com/Parts/6608...#axzz2uMMbNugK
    Duplicolor: http://www.duplicolor.com/products/trimPaint/
    Most reviews seem to say the Wurth paint matches the soft touch color best while Duplicolor matches the raw black better.
    Thanks
    Veteran Member Three Rings a2 4.0t's Avatar
    Jun 18 2012
    Jimmy Hoffa
    Ocean City / New Jersey
    you could always vinyl wrap it, easy to do and the finish would be flawless
    2012 A4 s-line
    |Carbonio intake | APR quad outlet exhaust with tons of RSC technology | AWE downpipe | s4 rear valence | Vogtland coil overs | Rotiform BLQ's | stage 3+ Chinese turbo whistle |
    Veteran Member Four Rings diego_demarco's Avatar
    Feb 13 2014
    Ft Lauderdale
    Has anyone vinyl wrapped it in carbon fiber?
    Jun 18 2012
    Jimmy Hoffa
    I did trim for the doors and the front passenger seat. I ended up leaving the instrument color silver for some contrast.
    2012 A4 s-line
    Senior Member Four Rings r6_11b8's Avatar
    Oct 03 2013
    los ángeles
    wrap it....its easier and reversible for when you sell it
    2011 A4 ice silver metallic
    MODS- 25% tint rear, 75% front, 19" Rotiform BLQ, Solo Werkes coilovers, Custom FXR projectors
    upcoming mods - 10 inch sub
    2009 Yamaha R6 - Shogun FS-Zero Gravity-Custom FE-Hot Bodies Flush Mounts-MotoDynamic Integrated Tail Light-Supersprox -1+2-Taylormade Full Exhaust-PCV-OURY Grips-Corbin Seat-Ebay Shorty Levers
    Veteran Member Four Rings Audacious's Avatar
    May 03 2011
    plastidip.
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    WOW that looks sick! ^^
    Edit: how does that get removed? Does it just pop off with some patients or are there screws like the b6/b7?
    2016 S3
    Instagram- @Thisisastickup
    Feb 15 2014
    Florida
    Quote Originally Posted by a2 4.0t View Post
    Is the door trim difficult to remove? I think instrument trim just pops off right?
    '10 A4 .:[APR] - [aFe] - [AudiUP] - [R8] - [EC] - [VCDS]:.
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    If you plan on wrapping trim spend the $15 bucks for the ECS trim removal tool kit. You'll thank me later when you don't break tabs or a trim piece.
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    May 03 2011
    Quote Originally Posted by b6Hate4 View Post
    the instrument cluster trim just pops right off, no special tools required. be careful with the vent piece though, because if it falls apart, there's a lot of pieces to pick up....
    OSIR D-trim makes it look even better:
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    i wraped mine in carbon fiber.
    APR, Eurocode, AWE, P3, aFe , CTS, Spulen, H&R, 034Motorsport, STaSIS
    Jun 18 2012
    Jimmy Hoffa
    Quote Originally Posted by oh10a4 View Post
    the door trimming is really easy, just pops right off. However, the center instrument/head-unit trim is actually glued together so you would need to take it apart after removing if you want to wrap it then re-attach it afterwords.
    2012 A4 s-line
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    I had a body shop paint mine gloss black. I didn't specify any certain color beyond that, but it matches just fine. :) There is another thread around here somewhere where some people have DIY with varying degrees of success. Some were fine, for others it bubbled. I told the bodyshop about that, and they used a specific kind of paint to reduce the chances of that, I believe they said it was a low solvent paint. Regardless, it turned out well, and for me, was the biggest cosmetic improvement I could make in the interior. I always thought the silver plastic really cheapened it.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    Senior Member Two Rings sidkneeeeee's Avatar
    Jul 09 2013
    Fairfield, CA
    Quote Originally Posted by Audacious View Post
    plastidip.
    How the texture? what exactly color did you use, black only? any gloss spray?
    2010 A4 2.0T P+ 6 Speed CPO / ECS Interior + License led lights / RS4 Grill + Honeycomb Fog cover / Sline Rims 255-35-19 Et43 / ECS Spacer 10mmF:12.5mmB / ECS Inlet hose + Dry Filter / B12 KIT (Bilsteins Shock / Eibach Springs) / 10mm+12mm spacers / Wrapped interior + Window trim + Jcodes / ECS Shortshifter / LED 3200K Yellow Fog / Coilpack, NGK plugs / GFB+ DV / Revo Stage2 / Eurocode HFC / Hotchkis F:R Sway Bars / ECS Transmission Mount Inserts/ Future Mods: Podi Boost Gauge ; 3.0 TDI IC
    Veteran Member Three Rings wabbit23's Avatar
    Mar 20 2011
    2011 Avant Quattro & 2010 Jetta TDI
    San Diego, Ca
    Quote Originally Posted by dscline View Post
    Got any pics?
    Mine- 2011 Avant Quattro- Premium Plus w/ Sport Package- APR Stage 2/ SPM Downpipe/ AFE Prodry S/ R8 Coilpacks/ ECode HFIP/ ECode Intercooler Piping kit/ 20% F & 15% R tint/ Dipped Parts & Vagcom stuff
    Hers- MKV Jetta TDI- Matte Black VMR V710's / H&R OE Sports/ Koni FSD's/ Dipped parts everywhere
    Senior Member Three Rings Celiot29's Avatar
    Jul 17 2012
    boston ma
    this never crossed my mind until this thread, I think I found my next mod
    2013 Audi A4 Quattro brilliant black | light pckg | convenience pckg | 35% all around | RS4 grille | S4 trunk lid | S Line rear valence
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Quote Originally Posted by wabbit23 View Post
    Got any pics?
    No, but I'll take some this week.
    '11 S-Line A4 Avant
    Nov 25 2011
    I had wrapped my door and dash trim in CF vinyl I had laying around. It was a piece of cake to wrap the door trim + the passenger side 'quattro' blade, but my trim around my mmi screen actually started bubbling from sitting in the hot sun for hours on a summer day. I am going to dip mine black with glossifier in the spring around the dash and shifter, but I will keep my CF trim around the doors as it has held up nicely.
    2018 RS3 & 2017 SQ5
    Insta: @ccampbs
    2012 A4
    2015 S4
    2014 SQ5
    Feb 13 2014
    Ft Lauderdale
    Darn! Anybody in south florida who can do mine? Lol
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Mod added to the spring list: plasti-dip the silver trim.
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    May 03 2011
    Quote Originally Posted by sidkneeeeee View Post
    Texture is very smooth. It all depends how you spray the plastidip. I did 3 coats of regular old black plastidip.
    Sep 30 2009
    b
    lulz strange how this shit is all super old, but there's a whole new wave of forum users who have never seen it.
    Apr 29 2013
    Ottawa
    That's the way forums work..."You either rage-quit the forum in a flame war, or live long enough to recognize the re-posts".
    Feb 25 2013
    MI
    How hard did people with the B8.5's find removing the one contiguous instrument cluster dash trim piece? I was trying to get my p3 vent gauge in but couldn't get the upper corner near the MMI off without feeling like I was gonna break it. Also, do you guys put any felt tape down while it's off to reduce squeaking?
    Now I just need to re-assemble the upper vents after that metal connector fell off, ugh, what a PITA
    Senior Member Three Rings billyhelmsorig's Avatar
    Oct 22 2012
    long island NY
    I remember seeing somebody wrap it in white carbon fiber. cant remember what thread that was though
    09 b8 ibis white, 18% tint,, LED interior/plate lights , 5k hid headlights, yellow fog's, VAGCOM mods, plasti dip stock grille, AG M510'S 19x9.5with 245/35/19 hankook evo 12 tires, h&r coilovers
    follow me on instagram @billytoad http://instagram.com/billytoad
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Got any pics?
    Sorry, I kinda forgot to take one. Here it is, just gloss black paint done by a body shop, with the OSIR d-trim pieces added. FWIW, I really like the design of the OSIR pieces, but they have a rather cheap looking finish. They'd be really nice if the same design were available in brushed aluminum, rather than silver plastic.
    '11 S-Line A4 Avant
    Senior Member Three Rings bsully1850's Avatar
    Jun 14 2012
    04 VTX 1800 Mod Chopper, 1990 GSXR 750 (tricked out too)
    San Clemente, CA
    What did the body shop charge you to do this?
    Oct 03 2013
    los ángeles
    piano black looks very nice.
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Quote Originally Posted by bsully1850 View Post
    I think it was $70. But I was already putting it in the shop to get a ding in the fender fixed, so that may have helped. I removed it, they just had to paint it.
    EDIT: Also, FYI, there's a thread around here somewhere about painting this yourself. I had read it before hand, some people had success, others eventually experienced bubbling of the paint. I talked to the body shop about this before hand, and he decided to use some special "low solvent" paint, or something to that effect, that he thought would be less likely to do that. He described it as being less aggressive. Whatever he used, it seems fine. I had this done a year ago, and it's held without any issues.
    Another edit: I think he may have said he used waterborne paint.
    '11 S-Line A4 Avant
    Jun 14 2012
    San Clemente, CA
    Thank you! I just finished installing PB trim everywhere else and now this piece just sticks out.
