Results 1 to 17 of 17
    Established Member Two Rings British-Audifan's Avatar
    May 23 2009
    '16 Q5 3.0T, '11 Q5 2.0T, '04 A4 1.8T Avant, 03 A4 Avant, '17 VW E-Golf
    Gilbert, Arizona
    How on earth have you guys replaced the drive shaft c/bearing - UPDATE, I fixed it!!
    So this PITA job is done! I got a used drive shaft from a manual car that had a 'C' clip style attachment on the centre UJ! Which made life a whole lot easier I still couldn't get the centre bearing off, so took it to Arizona Driveshaft, and had them install the new 034 centre bearing, and re-assemble the whole thing! The best $45 I've spent in a while
    But interesting that there are different drive shafts out there. And being that it's for a manual car, I could get rid of that nasty, heavy and leaking spacer that Audis4parts gave me.
    And my cheap drive shaft alignment tool work well. My drive shaft wasn't correctly aligned! So that might of caused the bearing to fail. Happy to be on the road again
    My set up tool
    I've been having a high frequency vibrations on my A6 since the 6 speed conversation was completed, along with hot grease smells from time to time. Well, on Sunday it started getting worse! And banging as I was pulling away from a standstill. I found that the bolts that attach the front of the drive shaft to the spacer the guys down in Tucson installed instead of using a prop shaft from a manual car were loose!! That's were the grease was coming from! And the two centre bearing bolts were also loose, and the bearing assembly was off centre!! So now the centre bearing looks and feels shot So I have a replacement centre bearing from a friend, but can we get that 17mm bolt undone!? No we can't. I don't see how you can get anything in there to remove it? The open end of a wrench/spanner, is way to wide, so I cut it down in size, but then it just broke. There isn't enough clearance to get the ring end of the wrench passed the end of the bolt!
    I took it to a drive shaft shop today, and they couldn't do it either! So how have you guys done this?? Perhaps the only difference between a manual and auto drive shaft is that part of the UJ? Makes sense to only have to design two small parts, and keep the rest common between all A6's?
    Does the drive shaft on a manual car have more clearance in the UJ? Here is a photo of mine....
    Current '16 Q5 P+ 3.0T, '04 A4 Avant 1.8T, 03 A4 Avant 1.8T, '11 Q5 2.0T slammed, 17 VW E-Golf Golf R seats, wheels and H&R springs.
    Past here in USA; 98 A4 Avant, 07 A3 S-Line, 17 VW Jetta, 04 A6 4.2 6 speed manual, 20th Anniversary GTi, modified, BMW E36 Convertable -crap car. Back in UK, 03 Audi A4 2.5 V6 TDi Cabriolet, 01 Audi A6 Avant 2.6L V6, 97 Audi Cabriolet, S2 running gear, bumpers, suspension! Hardtop, 18" Azev, ICE, 91 BMW E30 conv' M3 look-a-like, 98 VW VR6,
    Vauxhall Astra Mk1
    Apr 22 2007
    Riverbank, Ca
    Did it on my A4... Lots of heat, cursing, and fire involved. In the end I dont think it did anything (I was fixing a clunk from the torn diaphram). If you can find an entire new driveshaft or get a shop to do it, do it. Its not worth the work.
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Sep 11 2009
    NE
    Quote Originally Posted by British-Audifan View Post
    Grind down the ring side of wrench (make is thinner).
    May 16 2008
    South Texas
    It's extremely difficult but possible. You need to make a wrench and hope the yoke isn't pressed onto the shaft with too much pressure.
    Jan 07 2011
    cincinnati ohio
    You will need to be sure you mark both halves so that it is not clocked out of alignment when reinstalled. I ended up replacing my nut with a stud and bolt. Its virtually impossible to torque it correctly.
    Veteran Member Four Rings Racin2redline's Avatar
    Aug 19 2012
    1997 Yamaha razz 50 (sik)
    Long island
    I'm all for doing everything myself ...but for this job ( and the fact I have a non serviceable shaft) I would throw my money at a new one
    IG: d3bel1o
    May 23 2009
    Gilbert, Arizona
    I did grind down the ring side of a wrench to get it passed the bolt, but the wrench broke! In fact, I've broken 3 wrenches on this job And so did a company called Arizona Driveshaft and Diff' in Mesa!! I have a replacement driveshaft arriving today! But, I'm going to start saving for one of Scotty's one piece carbon driveshafts! Not going through this shit again!!
    Thanks guys, Paul..
    Vauxhall Astra Mk1
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    I thought the driveshaft on our cars are considered unserviceable. You have the cv joints at the ends, and the center has the u joint but no clips that one would remove to disassemble the shafts and service or rrplace the bearing in there (forgot it's proper term).
    Wrong, or intention of audi to do so but people are finding ways of doing this? I always thought on our cars that if the shaft got damaged or the u joint damaged, we have no choice but to replace the whole shaft assembly.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Veteran Member Three Rings Nogaro Nitwit's Avatar
    Sep 13 2010
    2000 S4, 2005 allroad 2.7t, 2004 allroad 4.2
    Sterling, VA
    In case others haven't seen it, 034 Motorsports makes the center bearing for the driveshafts for the C5 chassis and allroad.
    034 Motorsports center bearing for C5 Chassis
    034 Motorsports center bearing for allroad
    2000 S4 - ASP Stage 3, ER ICs, ASP DPs, ASP True Dual Exhaust, 710Ns, Neuspeed 19mm swaybar, ASP phenolic spacers and many more goodies
    2005 allroad 2.7t - 6mt conversion, Daz Stage 2 tune, S6 seats/headliner, Podi boost gauge w/ custom pod, Arnott Gen IIs, H-sport swaybars, Magnaflow exhaust, 19"x9.5" Miro 111's, Euro roof rails, OEM spoiler, LED Tails
    2004 allroad 4.2 - APR tune, OEM spoiler, H-sport swaybars, OEM hitch, BFG K02 all-terrain tires, Yakima roof basket
    Jan 07 2011
    cincinnati ohio
    Quote Originally Posted by Nogaro Nitwit View Post
    After finding these for sale a few years ago I too thought it was a cheap fix. Having actually replaced mine after buying these parts, I can say that the shaft is not designed to be serviceable, it can be service after a lot of work, frustration, and time, and in the long run, is not worth doing. By the time I finally got my bearing swapped and the shaft installed, I was just a few bucks shy of a replacement shaft that would have cut the time down to a few hours at best. It was a total pain in the butt and I will never do it again. The shaft was not designed to be serviced and it really shows when you attempt to do it.
    May 23 2009
    Gilbert, Arizona
    So my question is, where is the best place to get a replacement driveshaft from? $1800 from my local stealership! A rip off price...
    Paul
    Vauxhall Astra Mk1
    May 16 2008
    South Texas
    I can get new aftermarket articulated shafts. They run $695-$795.00
    Scott
    Jan 07 2011
    cincinnati ohio
    Another option is to look for a local drive shaft specialty shop.
    May 23 2009
    Gilbert, Arizona
    Update at the top
    Vauxhall Astra Mk1
    Aug 19 2012
    Long island
    How on earth have you guys replaced the drive shaft centre bearing!!??
    Nice. I have the same type of driveshaft. I haven't had a real good chance to look at it...was TOLD it was unserviceable because of the C clip, haven't tried myself I yet... LOL cool to see it can be done tho
    IG: d3bel1o
    May 16 2008
    South Texas
    The shafts with the c clip are not serviceable at least not by the average DIY'er..
    The clip is pressed in under alot of pressure, so you can't get it out.. And if you manage to get it out, you can't get it back in. You need a press and fixture to remove that clip.
    May 23 2009
    Gilbert, Arizona
    Quote Originally Posted by Scotty@Advanced View Post
    It wasn't that bad to remove, maybe 10 minutes and I had pulled the rear haft of the drive shaft out. After marking 3 splines. Arizona driveshafts put it back together, so I didn't go through that pain
    Audi is quiet right, none of these are servicable! And I won't do it again!! Next time Scott, I'll be purchasing one of your carbon one peice jobbies
    Paul...
    Vauxhall Astra Mk1
