Results 1 to 11 of 11
    Veteran Member Four Rings Dannydyn's Avatar
    Dec 20 2013
    Mercedes Benz ML350
    Is it possible to remove the front grill without removing the whole bumper as well?
    Hey all,
    Trying a little experiment with plastidip on the stock grill and would like to refrain from removing the bumper if possible. I did a few searches, but everything I come across includes bumper removal as part of the process (in RS4-swap threads).
    Just wanted to make sure this was the only way to do it (removing the bumper). Anyone managed to pop the grill out without removing the bumper?
    TIA
    2014 S4 | 6MT | Estoril Blue | Lunar Alcantara | Rotors
    AWE S-Flo | Bilstein B8 | H&R OE Sport | RS4 Grille | 35% Tint
    Senior Member Three Rings Ryan_qttro's Avatar
    Oct 17 2011
    2005 2.7T Allroad
    Baton Rouge, Louisiana
    No unfortunately there are some screws that hold it in from behind
    But front bumper removal is pretty easy, can be done on ground or jack stands without removing wheels. I'm sure someone has made a Do It Yourself thread on it.
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by Ryan_qttro View Post
    Thanks
    Yeah, I saw a couple of DIYs... was trying to see if I can somehow get away without having to deal with the bumper.
    Thanks again
    Senior Member Three Rings mageiger's Avatar
    Jul 05 2010
    PA
    Here's a good link from the B8 A4 section that is pretty detailed.
    http://www.audizine.com/forum/showth...lacement-Guide
    Current: 2009 Ibis A4 3.2 Prestige
    Previous: 2006 A4 2.0T
    Veteran Member Four Rings integroid's Avatar
    Mar 01 2013
    Atlanta, GA
    took maybe 15-20 minutes to remove front bumper.....not a big deal
    2024 RS3 Kemora Gray
    Oct 14 2012
    Empty...for now...
    SE PA
    I agree it's not a huge deal to remove the front bumper, but out of curiosity wouldn't it be possible to remove the plastic under liners / trays that connect to the underside of the bumper and then reach up from under the car to get to the bottom grille screws? If I remember correctly, the main reason it was necessary to remove the bumper was that the block of styrofoam sandwiched between the stock grille and the crash beam blocked the access to the lower fasteners, but I haven't seen anyone try to get at them from the bottom.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings name.goes.here's Avatar
    Mar 17 2012
    South of Boston
    Quote Originally Posted by Dannydyn View Post
    TIA
    Yes, if you own Avant you can.
    J/K - sorry, I couldn't resist. Seriously, though, someone in the B8 A4 forum posted a great and detailed DIY about a week ago about how to remove the bumper that you may want to check out.
    Good luck!
    His: 2015 Audi A6/Quattro/Glacier White/Premium Plus/Bose/Cold Weather Package/Sport Package
    Hers: 2016 Infiniti QX50/AWD/Majestic White/Premium Plus Package
    Veteran Member Three Rings jamesj2k's Avatar
    Feb 17 2008
    Ashland, KY
    I found it quite amazing how the S4's (B8) disassembles! Front and rear bumper I could probably remove in my sleep now.
    Plus love how the oil filter is accessed from the top. One of the many reasons the S4 is a great automobile
    2019 SQ5, 2021 Q7
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by name.goes.here View Post
    Add to cart....
    Jun 06 2013
    Model 3, MK7 GTI
    Carrollton,TX
    I recommend getting a long extension for your ratchet. It will make removing the bumper a millions times easier. My first time, I tried without an extension and the space inside the bumper was so small so my ratchet was only able to click a couple of times.
    2016 M3 Mineral White
    2014 S4 Ibis White - Sold
    Veteran Member Three Rings jfabes's Avatar
    Feb 05 2012
    H-town
    Front bumper is super easy to remove, 15 minutes is all it takes. You need a long extension for the 10mm bolt up under the fender. No need to jack up the car. Turn the wheels left/right to gain acces to the fender well screw. Crazy easy.
    Re the plastidip....why can't you plastidip while its on the car? If you watch fonzie's vids on YouTube, he never removes it.
