I've been looking around for some clues to solve this but I haven't found anything that fits my situation exactly. My car was on jack stands for 8-ish hours while working on it - nothing brake related - I got the wheels back on and went to go for a test drive - the brake pedal went to the floor twice. Third pump, I had a pedal. Low on brake fluid, was my first thought. Checked it, the reservoir was full. The red light started flashing. Had a buddy watch the reservoir while I pumped the brakes and the fluid went up and down with the movement of the brake pedal (Is this normal?) We kinda think it is the master cylinder but I've been reading that the ABS module failing would cause the same situation (For the most part) - Thing is my ABS has been in-active for 2 years because of a broken wheel sensor connection. Could it be the brake booster? My pedal will be solid after a pump or two; before that it is a little spongey but definitely stops the car. Any thoughts about what this could be, couldn't be would be appreciated. Thanks in advance for reading and the help
