Results 1 to 13 of 13
    Veteran Member Four Rings BranCKY3's Avatar
    Mar 08 2005
    Greenville, SC
    Angry Stripped a torx screw, help!
    I went to install my brand new cluster rings I just received in the mail like 40 minutes ago and I stripped one of the torx screws. Damnit!!!!!!!! I was looking forward to getting these on for a week. Is there anything I can do? The torx bit won't grab the screw at all anymore.
    Should I sell the rings or is there a fix? Would an allen wrench possibly work if I got it to fit?
    2016 Audi S3
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    try using some vice grips if you can get at the bit.or use a slightly larger bit and tap it in with a hammer. works on engine parts, but i dont know about anything in the cluster area.
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Feb 27 2005
    North Wales, PA
    If you are really in a bind, just get a dremel if you can fit it in there and cut a groove for a flat head screw driver. Get a replacement also.
    Mar 08 2005
    Greenville, SC
    It will be very tight to fit a dremel in there. I will try to cut a groove in there though.
    2016 Audi S3
    Veteran Member Four Rings marked001's Avatar
    Feb 17 2004
    08 Subaru Impreza WRX; vr
    South Philadelphia
    I cant imagin that screw is in there 'that' tight.. maybe use an ez out?
    F the Jersey Jerks
    Jersey Jerk hata #1
    99.5 t28 A4 ....bye bye.
    www.REVI21ON.com
    Active Member Four Rings Ben@SpeedBarn's Avatar
    03 A6 2.7t, 00 GTI, 76 GMC
    Pittsburgh, PA
    Or just get a drill bit and slowly drill until the head comes out. Then once removed grap the rest with vice grips.
    If you were closer I'd let you borrow my torch
    Mar 08 2005
    Greenville, SC
    You'd be suprised. I unscrewed the screw on the right, it was actually pretty damn hard to unscrew. Or maybe it was because I could only use a couple fingers to turn the screwdriver.
    2016 Audi S3
    Feb 27 2005
    North Wales, PA
    you could also try reverse threaded drill bit.
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    i got a 12 point socket slightlylarger than the size of the screw's head and hammered it over it, slowly and straight on, then i just turned the socket out.
    i had a few stripped cam tensioner bolts
    Pittsburgh, PA
    you might break something if you hammer your gauge cluster though
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    pound an allen in, go for a really small one first since it's a really delicate bolt. One of those stripped on me once... I melted it into a puddle w/ a welder. Some say I'm unbalanced
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    Mar 08 2005
    Greenville, SC
    Alright tomorrow morning I will try to pound an allen in first, then dremel for a screwdriver if that doesn't work. Thanks for the help guys, I will be sure to post pics if I ever get these rings in!
    2016 Audi S3
    Veteran Member Four Rings 01'A41.8T's Avatar
    Mar 06 2005
    F82 M4
    PA & AZ
    You can always try these. I have a set just like them, works every time. You could find them at home depot or something. http://www.tool-net.co.uk/data/index.php?ToolID=315878
