Results 1 to 20 of 20
    Feb 19 2014
    United States
    2000 Audi A6 Quattro MAF
    Hi. I am a recent Audi owner and I am not sure where the MAF is located. Could someone let me know please I cannot find videos on it anywhere.
    Thank you
    Sep 03 2011
    ATL, GA
    Here is it to the right of the guys hand on a 2.7t...the plug. http://www.audiworld.com/tech/pics/eng82_007.jpg Not sure the engine you have though.
    Feb 19 2014
    United States
    Thank you very much. One more question if you know. Is it a 4 pin connector?
    Feb 19 2014
    United States
    Sorry. We have the 2.8l
    Sep 03 2011
    ATL, GA
    Quote Originally Posted by asrocco View Post
    Same location, just on the front side of the air intake. http://www.fototime.com/ftweb/bin/ft.dll/picture?PictId={9CB99F25-10A4-4D8C-85AE-DF26D987C997}&size=ORIG No sure about the pins though.
    Jun 22 2013
    Yes 4 pin
    Feb 19 2014
    United States
    Thank you for your quick response I really appreciate it.
    Would anyone else happen to know how many pins are on the MAF for a 2000 A6 Quattro 2.8L?
    Feb 19 2014
    United States
    Thank you Vinnie981. Much appreciated!
    Jun 22 2013
    no problem. Why didn't you just unplug it and check yourself? Take 2 seconds
    Feb 19 2014
    United States
    All the rain, snow, and ice my husband didn't want to disconnect it.
    Jun 22 2013
    got it
    Feb 19 2014
    United States
    One more question the O2 sensors, do they need to be direct fit or can they be universal?
    Jun 22 2013
    pre or post o2 sensors.......
    You have Bank 1 Sensor 1
    Bank 1 Sensor 2
    Bank 2 Sensor 1
    Bank 2 Sensor 2
    Feb 19 2014
    United States
    I want to replace all of them bc I don't know if the prior owner took care of the car
    Jun 22 2013
    no point in replacing them if there working....do you have a code/check engine light for a bad o2 sensor?
    If you do want to replace them to be safe the do only Bank 1 Sensor 1 and Bank 2 Sensor 1
    http://www.ecstuning.com/Audi-C5_A6-...Oxygen_Sensor/
    Feb 19 2014
    United States
    Yes, the check engine light came on the day after I bought it. I did run the codes and stupidly erased them but it said O2 up and downstream
    Feb 19 2014
    United States
    Will the universal ones work or they should and need to be direct fit?
    Jun 22 2013
    you can use universal o2 sensors for the two rear o2 sensors......
    Bosch Universal 4-Wire Oxygen Sensor- Mfg Part#15733
    But for the front two you cannot. I suggest OEM ones or Bosch for the front two
    also do you have a quattro or FWD.......and is your engine code ATQ or AHA
    Feb 19 2014
    United States
    I have the Quattro and not sure about the engine code?
    Feb 19 2014
    United States
    Can you tell me is something should be in this hole? We checked the MAF and it is very clean. Thanks. [IMG][/IMG] I posted the link for the photo. I hope it works.
