Originally Posted by
audi49
So curious TexS4... how did it turn out? Thanks.
Turned out great! The entire ride is now much stiffer vs. my worn out stock shocks. I currently have 105,5xx miles on the car. I'll break down my experience based on Highway driving, City driving and what I call urban driving (speed bumps in neighborhoods, constant stop n go, etc).
Highway Driving: Most noticeable difference was over bridges and overpasses where the car would hit the sections of the bridge that connect each other. Before the bilstein's the car had a tendency to get into a rhythm over those sections in which you could feel the body of the car just sorta floating up and down as it hit those sections of the bridge and not really settle until off the bridge(s). Now with bilstein's and stock springs its a tight rebound and no longer does that floating feeling. <<< sorry if the word floating is throwing you off.
City Driving: Definitely an improvement. Here in Austin, TX the right lanes on our roads in the city are rather harsh due to our Metro bus's (Lamar Blvd is a good example). I purposely drove in those lanes today to see how well the car would take bumps and dips as with the old worn out suspension it would have a tendency to bounce a bit after each dip in the road and uneven surfaces you would feel all the way through the steering wheel. Its certainly stiffened up things and makes the city roads feel at lot less harsh. A few known spots where we would normally prepare for the bump felt like the road was fixed :)
Urban driving: Speed humps are everywhere in Austin's suburbs as well as the residential streets inside the city. I have two sets of road humps on my street for example. These are the ones that are intended to slow folks down if you're not familiar with them. You can really tell going over those road humps that the shocks are doing their job. Most noticeable was in the rear of our Avant; you can really feel the ass of the car plant as it comes off the road hump, as well it didn't feel as harsh when the rear of the car would go over the bumps.
Furthermore, I did a few stop light launches in S mode today (car is TIP) where it was safe to do so, and IMHO the car does feel like its planting itself better with the rear and not sinking as much due to better shocks. I had a chance to inspect the springs before the new struts and shocks were installed. Everything looked good, and while they were off the stock struts, I wiped them down and put a coat of Sealant on them (I'm a detail freak OK!). Control arms also still looked good as they were replaced two years ago; just wanted to point that out. I did find a torn CV boot so we went ahead and replaced that too.
Overall compared to the worn out shocks and struts, it was a very significant improvement. Car feels much stiffer but yet still very comfortable to drive. FWIW, the car sits maybe 1/4 of an inch lower than it did on the stock shocks and struts. Its nearly impossible to see just looking at the car but the Bilstein is shorter by about 3/4 of an inch. IMHO if you're not looking to lower your car but want to add a bit of sport feel to the suspension, you can't go wrong using Bilstein's or Koni's with your stock springs. Even if you're just replacing worn out shocks, you'll be very satisfied by putting high quality shocks in their place.
Hope this helps. If I need to clarify anything, I'll be happy to reply.
