I contemplated just extending an existing thread, but I have some video I want to share, and figured I'd provide a summary and save anyone interested in helping the trouble of reading through multi-page existing threads.:
- Part I: Original incident
- Part II: Gauge install and initial readings
- Part III: Oil Pressure Drops Suddenly Then Recovers
In 2012 and 2013 I had a couple incidents in which my red oil pressure light came on, then would go off. The threads above document the entire scenario pretty thoroughly. Suffice to say, driving along and "beeeeep" red oil pressure warning light. Pull over, sit and stew, pull codes, etc. Turn engine over and everything is normal, no warning light, engine running fine. In the end I put a full-time oil pressure gauge in (because a mechanical gauge in the garage never showed anything really amiss... this is an intermittent problem).
As the Part III thread describes, the pressure gauge revealed fluctuating oil pressures, so I decided to have my local Audi mechanic pull the oil pan and replace pickup tube, check for sludge, etc. Mechanic did so, and the pan showed absolutely no signs of sludge. I can post pictures of that tomorrow. There was really nothing of great note. Some plastic debris and the like floating around in there. The pickup tube had bits of particulate matter in the screen, but nothing close to significant blockage. Had the mechanic clean the pan thoroughly, replace the pickup tube, and away I went.
Unfortunately, I continued to see fluctuating readings on the oil pressure gauge. Given that I felt like I had crossed off all the possible causes, I tried to convince myself I was just seeing faulty readings from my newly installed oil pressure sensor. Sometimes it will run steady for days or weeks, then suddenly start dropping precipitously, then recover. Lately, it's been pretty steady on the good side, very little in the way of plummeting oil pressure readings.
Drove up to go skiing this weekend, and noted how steady the pressure was. Patted myself on the back. Probably a big mistake.
Driving back up the hill toward the Eisenhower Tunnel today, the gauge was going crazy. Dropping to like, 10 PSI at 3300+ RPM, climbing to 50 PSI, dropping to 11 or 12. Just all over the board. Right as I topped the hill and entered the tunnel, pressure dropped to about 2 or 3, and "BEEEEEEEP!!!!" Audi's own oil pressure warning light comes on.
Worst place in the world for this to happen, by the way... Sunday ski traffic starting to build, 1+ mile long tunnel with no break down lane or any place to stop. I dropped into a lower gear and revved the engine hoping it would crank back up, and miraculously it did, creeping back up to 10 or 11 PSI, then staggering up to the teens and twenties. Made it out of the tunnel, let it mostly coast down the hill, and nursed it home.
Video of pressure readings on the drive home.
So, now what??? Everything I've read indicates the oil pump failing would be sudden and complete. It's a fairly simple mechanical pump. Given there's no sign of sludge in the pan or pickup tube, oil level is normal — what could be causing this?
