Results 1 to 40 of 72
    Active Member Two Rings Scottish_A4's Avatar
    Sep 11 2013
    Scotland
    Cool Audi A4 B8 Bumper Removal / Grille Replacement Guide
    Hi All,
    I fitted my new RS4 type Grille yesterday which involved me having to remove the front bumper and the original grille. I could not find any guides online relating to the B8 and the only similar one was for an A5 which has a slightly different bumper and was not a comprehensive guide. Therefore I decided to write-up my own guide with photos for each stage. Please excuse the quality of the photos as they were taken on an iPhone.
    I purchased the grille from seller tcboverstock (based in California) on eBay:
    http://www.ebay.co.uk/itm/Audi-A4-S4...item4d1890eda4
    The car involved was a 2009 S line (UK Right Hand drive model) and I cannot confirm if the SE bumper of the facelift model are the same.
    **ANY PERSONS FOLLOWING THIS GUIDE DO SO AT THEIR OWN RISK AND I TAKE NO RESPONSIBILITY FOR ANY DAMAGE ETC. CAUSED**
    The time taken to carry out this task, was around 1.5 hours, but by following this guide it may be possible to do it quicker. I am not a mechanic and the guide is written as step-by-step guide for all abilities.
    Tools needed are as follows: (these can be purchased from a local automotive store)
    1x Torx t27, 1x Torx t26, 1x 3/8" Ratchet, 1x 3/8" 10" Extension Bar, 1x 3/8" 10mm socket, 1 x small torch (not essential), 1x small screwdriver, and some protective matting in front of the bumper.
    STEP 1: After opening the bonnet, remove the 4 bolts on the Airflow panel indicated below, using a t26.
    STEP 2: Locate the 3 plastic bolts indicated below.
    Push down on these plastic bolts.
    STEP 3: Remove the Airflow panel by pulling towards the engine bay and lifting upwards.
    The engine bay will now look like this once the Airflow panel has been removed.
    STEP 4: On the drivers side, turn the wheel inwards and locate the two bolts on the front edge of the wheel arch, as indicated below.
    Remove these 2 bolts using a t27.
    STEP 5: Peel back the wheel arch liner and locate the bolt, indicated below, that is located just below the headlight. (Note: A small torch might be useful in locating this bolt)
    Remove this bolt using the Ratchet with the attached Extension Bar and 10mm socket.
    STEP 6: There are 5 bolts located below the bumper. Remove these using a t26. (Note: There is a bolt located on the far edges of each side of the bumper, that is indicated on the left of the photo below. These bolts are different to the other 3 bolts so make sure you don't mix these up.)
    STEP 7: On the passengers side, turn the wheel inwards and locate the two bolts on the front edge of the wheel arch (the same as what was carried out on the drivers side. Remove both of these blots using a t27.
    STEP 8: Peel back the wheel arch liner.
    Locate the bolt, as indicated below, that is located just below the headlight. (Note: A small torch might be useful is located this bolt)
    STEP 9: Locate the two bolts on the top of the bumper, as indicated below.
    Remove these bolts using a t26.
    Use a screwdriver, lift the flange located underneath each of the two bolts. (Note: Be careful not to damage the paint of the bumper when using the screwdriver)
    STEP 10: Remove the Fog Light surrounds on either side by giving them a good pull outwards. (Note: This is not mandatory but I found it helpful for the next step)
    STEP 11: ENSURE THAT THE IGNITION IS OFF AT THIS STAGE TO PREVENT POSSIBLE FAULT CODES FLAGGING UP!
    Remove the bumper from the car by gently wiggling and pulling on all sides, foglight hole, and from top and bottom. (Note: this is where step 10 proves useful). Make sure that protective matting is in place in front of the bumper in case the bumper is dropped etc. Be aware that the bumper will still be attached to the car at this stage, via wires.
    STEP 12: Once the bumper is free, the airtemp sensor will then need to be removed from the bumper by gently pulling it free.
    STEP 13: Unplug the foglights by using a screwdriver to unclip the socket.
    The bumper will now be fully free from the rest of the car at this stage.
    STEP 14: Place the bumper face down on the protective matting and locate the 12 bolts indicated below.
    Remove these bolts using a t26. The bottom bracket indicated below can be removed once the 6 bolts holding it in have been taken out. This bracket has to be added to the replacement grille.
    STEP 15: Unclip the 4 clips, 2 on either side of the top of the grille, using a screwdriver.
    STEP 16: Unclip the 4 clips, 2 on either side of the grille, using a screwdriver.
    CURRENT: 2009 Audi A4 2.0 TFSI S line, Misano Red, 19" Black Edition Rotors, Sat Nav, AMI, Bluetooth, Phone & Voice Prep, CD Changer, Gloss Pack, Heated Seats, Cruise Control, Electric Folding Mirrors, S line Suspension, Rear Trunk Spoiler, K&N.
    Sep 11 2013
    Scotland
    STEP 17: Locate the 5 clips, 4 of which are indicated below.
    Unclip these clips by gently pushing down with a small screw driver.
    The grille will now become free from the bumper.
    STEP 18: Turn the grille over and locate the 10 clips on the back of the Audi logo.
    Unclip these clips by pushing the black clips attached to the grille, away from the chrome part of the Audi logo, using a small screwdriver.
    Once these clips have been unclipped, the Audi logo will now be free from the grille. This can be easily attached to the emblem holder of the new grille.
    Reverse these steps to attach the grille to the bumper and the bumper back onto the car.
    THE FINISHED PRODUCT:
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    Great write up!
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Active Member Two Rings AndyA6's Avatar
    Sep 08 2013
    '14 I3, 13 Q5, '14 Boxster
    Utah
    Keep right except to pass!
    Veteran Member Four Rings name.goes.here's Avatar
    Mar 17 2012
    South of Boston
    Quote Originally Posted by ed@mtl View Post
    Great write up!
    +1 probably the best one I've seen yet for grille replacement. Well done.
    His: 2015 Audi A6/Quattro/Glacier White/Premium Plus/Bose/Cold Weather Package/Sport Package
    Hers: 2016 Infiniti QX50/AWD/Majestic White/Premium Plus Package
    Established Member Two Rings Benan's Avatar
    Feb 09 2014
    Sweden
    Thank you so much!!
    Audi A4 2.0T Quattro -11
    Eibach Pro-kit / 8x18 w 245 40 / 15mm H&R spacers / Custom Ram-Air intake w JR drop-in-filter / RS4 grill / E85 flexifuel /
    Dec 08 2012
    Moldova
    Thank you !
    Audi A4 B8, 2.0 TDI. Retrofits: Bi-xenon. Front parking sensors with graphics. OEM Bluetooth. Servotronic - 1N3. Footwell lights. Color DIS. AMI. Audi Drive Select. EGR off. DPF off. 207BHP CAHA remap. Keyless Entry/Go. Lane change assist. B&O. Aux Heater.
    Veteran Member Three Rings Limey's Avatar
    Nov 27 2010
    2004 srt4
    Edmonton,Alberta
    There is no need at all to pull the fog light grilles off. Once you pull the bumper off just unclip from the foglights. Save your self the extra step
    Later Gents
    2009 A4/Brilliant Black/6MT//Usual Vag-Com mods//A5 5 spoke "y" rims with Michelin 255/35/19 super sports//bilstein pss10's//rs4 grill//rs4 grills//S-Line side blades//Ecode halogen to bi xenon conversion//LED bulb interior swap//AWE quad tip exhaust//Eurocode Short Throw Shifter/inlet pipe/sways/end links/alu kruz//S5 front brakes//APR carbonio intake//SPM Test & downpipe//APR stage 2 flash
    Senior Member Three Rings billyhelmsorig's Avatar
    Oct 22 2012
    long island NY
    saving this to my favorites so I can use it when I get a new grille
    09 b8 ibis white, 18% tint,, LED interior/plate lights , 5k hid headlights, yellow fog's, VAGCOM mods, plasti dip stock grille, AG M510'S 19x9.5with 245/35/19 hankook evo 12 tires, h&r coilovers
    follow me on instagram @billytoad http://instagram.com/billytoad
    Nov 25 2011
    Quote Originally Posted by Limey View Post
    Later Gents
    +1 Don't risk breaking/not being able to put back the fog covers, just disconnect the wires for the fogs when you pull the bumper off, saves a step.
    Otherwise, great DIY, I'm sure many people will find this very useful.
    Also, I believe that non s-line bumpers do not have that bracket in step 14 (picture 2) for anyone confused who has a non s-line.
    2018 RS3 & 2017 SQ5
    Insta: @ccampbs
    2012 A4
    2015 S4
    2014 SQ5
    Sep 11 2013
    Scotland
    Thanks for the kind remarks all!
    Like I said, you don't need to take the fog light surrounds off but as my bumper was stuck quite solid after I removed all the bolts, I found it easier to wiggle it free by way of the fog light holes. The surrounds just pull off easily and you wont damage them as they are quite solid.
    Established Member Two Rings ryan_m's Avatar
    Jan 16 2014
    '99 Jeep Wrangler
    Boston, MA
    Great detailed write-up! I'll put this in the saved items folder in case I ever go with a honeycomb grille.
    Well done !
    Established Member Two Rings ThatOneOrange's Avatar
    Jan 26 2014
    United States
    Where can I buy the grill that will fit the B8.5 A4
    Senior Member Two Rings eirebob's Avatar
    Apr 13 2010
    santa rosa ca
    Terrific write-up. Thanks very much, and where in Scotland are you located?
    2009 A4 Quattro, Manual, Prem Plus, Sport Package
    Mods: APR Stage II, Stratmosphere short shifter, Alu Kreuz, Tips, Tint, 034 Turbo hose, Cocomats. EC Intercooler pipe, hose kit. RS 5 pedals. Apikol rear diff kit. Vag.com mods. Stoptech slotted rotors, Akebono pads. Interior LEDs, BFI heavyweight knob, CF trim. BC BR coils. P3 Guage. ECS SS brake lines, 10/15 spacers. CR 15 brace. USP HFC.
    Oct 20 2012
    Danbury
    Don't have the grill yet but thanks for this :)
    Mar 26 2012
    Charlotte, NC
    AWESOME!!
    Sep 11 2013
    Scotland
    Quote Originally Posted by eirebob View Post
    Thanks mate! I'm up in the Highlands.
    Jul 19 2013
    Porsche 944
    Las Vegas, NV
    5 stars...this is excellent.
    We need more of this on this forum.
    Black 09' Avant, 30% Huper Optik tint, R8 coils
    Jan 08 2014
    Ireland
    Hi, Really good post. I also have a Misano Red S-line and I have been thinking about fitting an RS grill for a while. I have had a look at the ebay link you posted and even with shipping (i'm in southern Ireland) it is good value. Just one question though, on the title description on ebay it is a gloss black grill, but in the description in the ad it says "ABS plastic in a matte black finish, Which is it? It is even hard to make out in the last two photos you posted, the last photo looks like it is a matte finish and the one before it looks as if it is a gloss finish. Could you let me know which it is and even post up a few more photos if possible?
    Thanks James
    Sep 11 2013
    Scotland
    Quote Originally Posted by j.r View Post
    Thanks James
    Hi James. The grille is gloss black. The description on eBay is a typo by the seller. I checked with him before I ordered mine. Most of these grilles seem to be un-painted on eBay but I think the gloss black suits a misano red car very well!
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Great work! Thanks much!
    Jan 08 2014
    Ireland
    Thanks ordered, order mine just there.
    Sep 11 2013
    Scotland
    Cool. I hope the guide proves helpful when you fit your grille. Post some pics up when you do!
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    We should make this a sticky!!
    2015 Sepang Blue S5- APR Dual Pulley Ultracharged, APR TCU tune, CR-15, AG M580s, Girodisc F/R rotors, EBC Red Stuff pads, APR Open Box CF Intake, AWE Track Exhaust with AWE Resonated DPs, etc...
    2017 Mythos Black S6- Stock
    2020 Nardo Grey RS3- Stock
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    Did you end up drilling and mounting a license plate on?
    Or does that bracket have mounting point for a .us license plate already?
    Lurker
    Sep 11 2013
    Scotland
    Quote Originally Posted by mrpeterparker View Post
    It has a built in Euro plate holder. I stuck my license plate on with plate tape.
    Mar 26 2014
    Phoenix, AZ
    I used this write-up to install my RS grill yesterday. Great write-up. Took me a bit longer because I plasti-dipped the impact/crash bar behind the grill but still a short and satisfying install. Great work.
    Sep 11 2013
    Scotland
    Quote Originally Posted by Hansen View Post
    Glad you found it useful mate!
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    Good write up but ecstuning has a downloadable PDF that is perfect for grill install, it's what I used....
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Apr 11 2013
    St Johns, FL
    Excellent write up. I just used this yesterday to install my RS4 grille.
    Thank you!
    Mar 22 2014
    NC
    Thumbs up
    +1 Excellent write up. Funny; I also used it this past weekend to install mine, and I plastidipped the crash bar as well
    Sep 11 2013
    Scotland
    Quote Originally Posted by Hod Lipson View Post
    Thanks buddy! Your car looks great in white with the gloss grill!
    Mar 26 2014
    Phoenix, AZ
    I would post up a picture of my car but you wouldn't be able to tell the difference. Looks great man!
    Sep 11 2013
    Scotland
    Has anybody found some mesh fog light surrounds to go with the grille?
    May 24 2014
    Gaithersburg, MD
    I bought a pair for my b8.5 off ebay, fit great, easy install. I'm sure they make for b8 as well.
    I broke a clip on the audi logo black housing during the install, now the bottom half of the logo does not sit flush. Any ideas how I can get it flush...I tried 3m tape...no luck.
    Sep 01 2014
    Northants, UK
    This is a great writeup, done nothing but try and maintain my A4 and I've been longing to change out the grille!
    Might just be my first change thanks to how straightforward you've made this!
    Mar 17 2014
    Suffolk NY
    Awesome!!! Thanks for taking time out to do this!!!!
    Aug 10 2014
    2009 GMC Sierra
    Atlanta / Macon
    SO helpful
    Sydney / / / A4
    Jun 05 2014
    Jackson, NJ
    Well written and detailed instructions with pics. Great work! Question, anyone know if this writeup also applies to the B8.5?
    May 07 2014
    Wow, what a thorough and well executed writeup. Will be printing this guide out for reference!
