So this morning I took it to my usual oil change place. Right after I drove out of the lot, the coolant light went on. I pulled over and popped the hood and looked at the expansion reservoir. I opened it (with a towel and glove) and a lot of water came out. I looked inside and it looked like the level was okay, so I closed it up and drove some more. When I got to my destination the light came on again, I looked at the reservoir and put some water.
After that, I drove around a bit in the city, and noticed that the temp would go about 3/4th of the way and the coolant light would turn on, and then the temp would drop back to the middle. This happened a handful of times when I was driving in the city.
On the freeway on the way back home (about 40 miles) the light came on 4-5 times, but the temp never moved.
I searched around, and found this thread:
http://www.audizine.com/forum/showth...-wondering-why
"The wire on mine was broken off and triggering the light.
I think a lot of people just push the reservoir aside when doing work on the engine and this fatigues the wires. That is how I got my car and I wire nutted it on...been fine since.
Since this happened right after the oil shop did my oil change, and they had to shove their hands in there to get to the oil filter, are the symptoms I just described a possibility that the wire is broken off? bear in mind I have no idea what this wire does or looks like. (if anyone has a pic, that'd be greatly appreciated - I will try to look for it tomorrow morning).
That wire aside, what are some other possible issues I may be looking at?
I read about fans working on idle, or turning on the AC/heat for the fans to run, but I'm not sure what exactly that achieves, or checks for. Again, an explanation would be appreciated.
Thanks in advance
