Results 1 to 12 of 12
    Senior Member Three Rings MBrock's Avatar
    Oct 24 2012
    Motor Trend: 2014 Audi RS 5 vs. 2014 Mercedes-Benz C63 AMG 507 Edition
    If you're a keen reader of Motor Trend, you might have noticed two Easter eggs we placed in the November 2013 issue, "hidden" on a one-page addendum to our annual Best Driver's Car feature. There, nestled among a long list of 70 lap times we'd recorded at Mazda Raceway Laguna Seca, were two that, for all intents and purposes, had no business being there (partly because we printed incorrect times for both). We hadn't covered the cars prior -- at least not together -- so you probably thought, "I don't recall a track test on the Audi RS 5 and Mercedes-Benz C63 AMG 507." Well, no need to recall a thing, as voila! the wait and confusion are over. We meant to run this comparison a while back, but we took the Audi on, how should I say it, a bit of a "field trip," so we had to hold tight till we got a replacement. (Sorry, Audi!) Thus, the lap time is from our initial 2013 RS 5 loaner, while the test numbers reflect a subsequent 2014 vehicle. (There are no notable differences between the model years.) Without further ado, let's meet the players. 2014 Audi RS 5 Mercedes Benz C63 AMG 507 Edition
    The Cars
    The $78,320 Audi RS 5 entered this comparison as a slight underdog to the $90,810 Mercedes C63 507, thanks to a naturally aspirated 4.2-liter V-8 whose 450 hp and 317 lb-ft pale in light of the Merc's monstrous 507-horse, 450-lb-ft 6.2-liter. Not only is the all-wheel-drive Audi less powerful than the rear-drive Benz, it's also heavier -- 4027 pounds versus 3952. Both feature seven-speed transmissions, with the Audi's S tronic dual-clutch boasting quicker shift times to the Benz's untraditional wet-clutch automatic. The $12,490 price gap between the two is sizable, represented for the most part by the C63's $9750 P61 Edition 507 package, which includes the 56-hp, 7-lb-ft output upgrade as well as a higher 174-mph top speed, 19-inch forged wheels, and the C63 Black Series' aluminum hood and bigger brakes, but not its brake pads. Throw out the 507's superfluous items not optioned on the Audi -- the $3950 matte paint job, $850 illuminated doorsills, $1000 black wheels -- and the delta, at $6690, becomes less glaring.
    The Road
    Senior features editor Jonny Lieberman and I headed for our favorite 50-mile test loop through and around Malibu, an ideal mix of freeway, demanding mountain roads, and coast highway. The RS 5 emerged as the firmer rider of the two, steadily relaying a detailed feel of the road for better or worse, while the C63 rode softer and more composed, with no noticeable deficiency in handling. Given the Benz's dynamic prowess, its ride comfort was impressive, reminiscent of a Panamera. The 507's steering was deemed superior, offering excellent feel, light but not too light weighting, and nice, organic sensations. In contrast, the Audi's helm came across heavy and numb, and definitely the weakest part of its formidable chassis.
    I say formidable because, as its 0.99 g of max lateral accel suggests, it delivers tenacious grip. The "party trick," as Lieberman notes, is the sports rear differential. "When you're in Dynamic mode, it overdrives the outside rear wheel through corners, meaning that once you've reached the apex of a turn (or really, even sooner), you can just bury your right foot. It's very counterintuitive, and frankly a weird way to drive, but it works." That said, the RS 5 does relay its mass to the driver more than the 507 does. The Audi always feels glued to the road, but you feel the weight transfer between the big 275/40R20 Pirellis as you work the car to "unglue" it through turns. The Benz, conversely, at 0.91 g of max lateral acceleration, just glides along the road, coming across lighter and nimbler. It should be noted, too, that the 507's sport seats and driving position were rated above the Audi's. Per Lieberman, "In the Audi, I was getting flung about when the road got bumpy and twisty, making me wish for much more shoulder bolstering." Under aggressive braking, especially when the brake zone featured bumps or slight bends, the Audi proved more stable, staying flatter and exhibiting less drama. Both registered curt 60-0 stopping distances: 103 feet for the C63 and 104 feet for the RS 5. That's not to say the C63 didn't offer great brake feel. With lovely, high engagement that allowed gentle breathing on the pedal to start the slowdown process, yet prodigious bite when really needed, the Benz's binders were nothing short of excellent. Ditto for its 6.2-liter. Man, what a motor. Revs above 7000 rpm, yet has massive low-end grunt and sounds like a '60s musclecar. Lieberman: "Just so much power, everywhere. Revs like crazy. All the torque you'd ever want is on tap. Angus MacKenzie, MT editor-at-large has said that if they ever build an engine Hall of Fame, the AMG M156 deserves a place in it. Every time I drive this motor, I see how much wisdom there is in that statement." The RS 5's relatively puny 4.2 probably would make it into the hall as well. After all, any V-8 that spins north of 8000 rpm is all right by us. Compared with the 507's low-end-torque-monster 6.2, the Audi's 4.2 is reminiscent of what it was like matching a Honda S2000 with a Porsche Boxster. You can go just as fast; you just have to keep the tach needle bouncing about the big numbers. And keeping the Audi's tach needle where it needs to be couldn't be easier, mostly b ecause you don't have to do anything. The S tronic intuitively does it for you, whether performing seamless shifts in Drive or firing off millisecond gear changes in Sport. Simply put, it's a noticeably better transmission than the Benz's MCT. Thus, there's no surprise the RS 5's 0-60 (3.9 seconds) and quarter mile (12.3 seconds at 112.2 mph) runs were just a tenth behind the C63's (3.8, 12.2 at 117.4, respectively).
    The Track
    With the 507 emerging as our road favorite, it was time to hit the track with our resident racer Randy Pobst to see if it could maintain its thin margin over the Audi. Pobst went out in the Merc first and set a fast lap of 1:43.45 around Mazda Raceway Laguna Seca's challenging 2.21 miles. All smiles? You could say that. "Oh, holy cow!" said Pobst. "Really strong driver's car. In its weight category, it definitely runs with the 911. It creates a lot of confidence, giving the driver the ability to place the car really well, because it's so well-balanced. When the spring forces are loaded up on one side and then unloaded, it does it slowly and predictably; it doesn't pop back, and the car does not snap. The damping is really well-done, and that package makes it a very good driver's car." 2014 Mercedes
    Given how high Randy was on the 507, we figured the less powerful, heavier RS 5 had no shot. We couldn't have been more wrong. Posting a best lap of 1:42.97, it was 0.48 second quicker, but Randy's comments suggested more like 4.8 seconds. "The R8 should be half this good! This car is fantastic. I adore it. It does such a great job utilizing all-wheel-drive traction off the corner, with zero push. You just drive in there and you think it's too early, but you just floor it and you're like, man, I should've gotten on the gas sooner. And no push, no oversteer -- it just drives right out of there, beautifully carving an exit line, using all the power. The gearbox is also very friendly. I just got more confident with carrying speed in and trusting the grip." Indeed, Pobst was able to dive deeper into the corners in the Audi and then carry more speed through the turns. That's where the Benz lost time, albeit not that much. Had it not been for the 507's underhood advantages, which gave it the drop exiting corners and on straightaway Vmax, the RS 5 would have extended the gap.
    The Decision
    The RS 5 is a balanced blend of rally car, road racer, and GT, and in many ways it's the cooler, more desirable machine. Its stance is meaner and stronger -- the sheetmetal seemingly shrink-wrapped over the five-blade 20s -- while the Benz looks like it's a big engine stuffed into a small car. And seeing the RS 5's bold mug, with the big black grille and brake ducts, in the 507's rearview makes you want to switch driver's seats. Then there are the Audi's screaming V-8, quick-firing DCT, Quattro AWD, and superior track time. But the 507 is more fluid on winding roads than the RS 5, which feels robotic in comparison -- like going from an analog 911 to a digital GT-R -- and it's certainly no slouch at the track. The Audi might be quicker up and down a mountain and around Laguna, but it's more of a ride-along. The Benz is engaging, inviting you to join in and experience the party. And we always prefer being the life of the party.
    Current: 2025 Audi RS6 Performance, 2023 Alfa Romeo Giulia Quadrifoglio, 2019 Mercedes AMG GTC Roadster
    Senior Member Three Rings TitanG545's Avatar
    Mar 01 2013
    Northern VA
    WOW pretty close, very surprised by the MPG disparity. Interested to see what the new M4 head to head would be.
    Jan 23 2013
    CO
    Wonder how the merc would do with reasonable tires?
    2018 Audi TT RS Ara Blue
    PAST: 2017 BMW X6M
    PAST: 2015 Daytona Gray Pearl SQ5, Tech, Lux, 21s
    PAST: 2017 Porsche 911 Miami Blue Carrera 4S
    PAST: 2015 Lexus RCF
    PAST: 2013 Phantom Black Pearl RS5, MMI, Titanium, DA
    PAST: 2011 Lexus IS-F
    PAST: 2010 Infiniti G37x
    PAST: 2009 Subaru Spec B
    Jun 16 2010
    └A / California
    Things I'm wondering about:
    1. In order for the RS5 to reach max HP (450), one would have to redline at 8250 every time?
    2. I don't know the physics behind it, but I'm wondering how much slower the C63 would be if it was equipped with 20" Wheels as well.
    3. How can a $90k Mercedes (I know it's MSRP) not have 20" Wheels standard?
    Rest in Peace:
    '10 Audi S5 | Quartz Gray
    Veteran Member Four Rings essfour's Avatar
    Dec 03 2010
    Boston
    Quote Originally Posted by FaceSmA5h View Post
    Well, the hypothetical 20 inch wheels on the merc would have to weigh more in order for them to act as a negative to the cars speed - not sure if a change in diameter between 19 and 20 would have much of an effect as long as all other factors remained the same - but weight would certainly be the factor. In most cases a cast 19inch wheel will weigh more than a high quality 20 so...
    Not sure what the correlation is between price of the car and a 20inch wheel option. I'm sure this has to do with what tested best for the car during R&D as well as what looked the best with the lines of the car during concept testing somewhere along the value chain.
    And yes, the RS5's motor needs to reach 8250rpm to achieve full power, unlike your motor, assuming it is the 2.0t, which makes full power between 4500 and 6000rpm but then begins to stop making power beyond 6k. The power delivery is extremely linear all the way up to redline on the RS5's motor, however.
    I was impressed with this review. I really like the Merc and am shocked that the RS was nearly able to match it in a 1/4 - although being 5mph down in the trap (which really shows how much more power the 6.3 motor is making). Despite this the RS was faster around the track which was novel.
    My favorite line was from the driver, when he said he, "The R8 should be half this good"... I though that was interesting as I have always seen the RS5 as a value R8 with more usability
    2022 Daytona RS6
    2020 Alpine White X7 50i
    1987 E30 325ic 5spd
    2018 Tanzanite M3 ZCP - sold
    2013 Phantom Black RS5 w/ Alu Optic package - sold
    2011 S4 6MT Meteor Grey w/ Ti package - sold
    2008 A4 S_Line Avant 2.0T 6-speed - sold
    2006 A4 Sedan 6-speed - sold
    2001 A4 Sedan 5-speed - sold
    Jan 06 2014
    Pensacola, FL
    I can't figure out how the RS5 lost. Better looking inside and out, much better transmission, faster around the track and thousands cheaper.
    2014 Audi RS5
    Ibis White, MMI+, Sports Exhaust, 20" Titanium
    Veteran Member Three Rings Zee Dgerman's Avatar
    Sep 06 2010
    Montréal
    Video
    http://www.youtube.com/watch?v=f5ZXTDLIUXw
    It seems to me most reviewers like the C63 better because they feel it is more involving. If I were driving my car on a track every week I'd probably agree, however I find the qualities of the RS5 more in line with my needs. It would be nice to have reviewers actually review cars from time to time with ''normal people'' in mind. It seems they always prefer cars that they car push sideways and beat the hell out of, which I wouldn't do to an 80k car anyway. I personally don't think the C63 coupe looks good at all, I like the sedan way more. Yes the engine probably has more grunt, but as reviewed it is 12k more expensive and from what they say has a crappy transmission. IMO the RS5 is the better all rounder, and for 90% of people that makes more sense.
    2023 Audi A4 Allroad - Ordered
    2019 Audi SQ5
    2018 Audi Q5 - Sold, 2016 Audi S3 - - Sold, 2013 Audi RS5 - Crashed , 2010 BMW X3 - Sold
    2010 Audi S4 - Sold, 2006 BMW X3 - Sold, 2003 Subaru WRX R1 - Sold, 2001 Subaru WRX - Sold
    1998 BMW M Roadster - Sold, 1997 Honda Prelude - Sold, 1996 Acura Integra - Sold
    Jun 13 2013
    2011 Forester XT, 2006 STi, '31 Ford Model A death trap
    Northern Illinois
    I think the B8 platform is getting long in the tooth. Audi has a great way of balancing a platform. However lately they always seem to be heavier and down on power. Those are two huge turnoffs for enthusiast buyers. I welcome them getting with the times and going with a lighter B9 chassis and switching to a turbo six cylinder. I think when that happens the platform will be far more compelling.
    May 28 2013
    2005 BMW M3
    Baltimore
    Quote Originally Posted by CasualObserver View Post
    A turbo 6 is never more compelling or desirable than a 4.2L NA V8
    IMHO, of course
    _____________________________________
    2019 RS5 Sportback
    2005 M3 ZCP
    2020 Mercedes GLE 450
    Sep 06 2010
    Montréal
    +1 while these new turbo 6's have great torque and punch, nothing beats the sound and the smooth linear delivery of a high revving V8, it's not all about speed, it's about the drive :-)
    Quote Originally Posted by Liberation View Post
    IMHO, of course
    2019 Audi SQ5
    Jan 06 2014
    Pensacola, FL
    The reason I bought a 2014 RS5 (and was considering a C63 507 as well) was because I was scared this would be my last chance to get to own a great big german v8 coupe. And I'm extremely pleased I did.
    The RS5 was faster around the track, looks better, has a better transmission, AWD, better gas mileage and all for LESS money??? Seems like a no brainer to me. RS5 all the way.
    2014 Audi RS5
    Veteran Member Three Rings audisarecool's Avatar
    '11 S4
    Quote Originally Posted by Captain Freez View Post
    Coming from a tuned B8 S4, couldn't agree more!
    Current: 2014 Phantom Black RS5 - Stock for now
    Gone: 2011 Quartz Grey S4 // Stasis V2 // VMR V710 // H&R OE Springs // 034 Adj CA's // Alu Kreuz // APR Stg 1&2 Intake // 12.44 @ 112
