Hey AZ'ers,
You may have seen a few posts from me about my 2008 Audi A4 Ti 6MQ S-Line. I bought it last year, around this time, and have since put close to 20k on it.
My impression: I. LOVE. THIS. CAR.
It may not be the fastest (APR stg 2 helps) , best handling (though my PSS9 coils and RS4 RSB help), or most modern car in the line up today... I am still utterly impressed by its reliability, fun factor to drive, and when tastefully modded, good looks on the road.
I can't go a week without someone complimenting it, commenting on it, asking me questions etc.
Being that I am going to KILL the value by driving the car as much as I do (Which I'm a big fan of) I figured I would explore something different.
ENGINE SWAPS!!!! So I've been looking into options that I will go over below:
4.2 V8
- Easiest BY FAR (came in this platform in the US)
- Limited amount of mods (compared to other drivetrains in the family)
- Plethora of US spec cars to pull a motor from
- Well documented
- Fairly reliable with correct maintenance
- Sounds very very good :)
2.7TT
- More complicated, especially with the B7 electronics
- Has been done but not as well documented (E.g. Devil's, and that Ibis white one on Gold IND's that I haven't seen ANY documentation on!)
- TONS of motor options, and will bolt to the B7 platform with mounts
- Will bolt to trans with b5 spacer
- TONS of mods, which is a good and bad thing depending on how far down the rabbit hole you want to venture
- Probably the most bang for your buck
- This car should have been made by Audi :(
VR based motor
- Uber complicated
- Tons of motor options
- With enough money ANYTHING is possible
1.8T
- Step back but a PROVEN motor, time and time again
- TONS and TONS and TONS of platforms to source from
- STUPID amounts of mods, again a rabbit hole
Leaning towards this one...
3.0 TDI
- Was available in the B7 in europe so it "should" bolt in
- The 01E bolts so again the 01X should as well
- Fairly reliable motor if you deal with the chains
- TONS of potential for mods, better fuel economy
- This motor in one iteration or another is in about everything TDI
- Electronics are a mystery to me on this... Who knows if the ECU needs to be changed or not? VagCom coding to reconize the TDI motor?
- Its a common rail engine so it'll run for a damn long time
Just wondering what people's thoughts/ideas/comments/suggestions.
