Originally Posted by
Bordom
Since they press in from both sides, wouldn't I be able to use a vice to press them in? Given the spindle bushings are in that tight space, do they push in from inside the control arm or from the outside. If it's from the outside it'd be a lot easier.
I think I'd be able to walk them out given enough force. I thought about getting brand new ones from ECS, but I couldn't justify $600+ to do this.
You can try, but I don't think a vice is going to cut it. I heated the knuckle *AND* froze the bushings and greased them. And they
still took a lot of force to go in. I mean...maybe you could make something happen in a jam, but I wouldn't plan on changing *all* the rear end bushings without a press available.
I don't think you're going "walk" anything out. No way. You have to burn out the center, then cut the outer casing and beat it out. You won't get anywhere with a hammer and chisel.
And like crazyquick said, the tie rods are a disaster if the bolt freezes to the ID of the bushing. You have to cut through the entire thing to get it out. Either with a torch or cut-off wheel. You'll probably go through a couple discs to do both sides.
