Results 1 to 16 of 16
    Feb 18 2013
    Silicon Valley, CA
    Accidentally over torqued flywheel bolts. Am I OK?
    I torqued the bolts to 60ft/lb + 180*, instead of the spec'd 60Nm (44ft/lb) + 180*.
    I know they are stretch bolts, and have seen a lot of people who use an air ratchet and don't pay attention to the torque value, so I am wondering if I am OK, or if I should back them out or what.
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    I can't imagine that being a problem. As you said a lot of people just use an air impact and pay no attention
    CHECK OUT MY BUILD THREAD!!!
    Noggy S4 Avant MT B6
    OZ superleggera 3, Pilot SS , 034 (Trio, adjustable uppers, Zero gap snub, rear sway with endlinks) APR full exhaust with drilled cats, H&R Coilovers, Red rear diff mount, JHM (NO2,Center diff, rear LSD and stage 4 kevlar clutch with LWFW)
    ...BBK coming soon
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    What kind of tq is you car making.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by rtl5009 View Post
    stage 3, k04
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    If they were brand new bolts I'd say your fine. 20 ft lbs is not much after you do a 180*
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Shitty. It is prob only an extra 1/16-1/8 turn.
    I bet it is fine, but I would prob have to change them so I could sleep.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by infinkc View Post
    They are brand new bolts.
    You can not remove a set of these bolts and reuse them.
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Quote Originally Posted by Tumbler510 View Post
    I spent $150 in flywheel bolts in 3 weeks because you can't reuse them. Damn RMS.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Jul 28 2009
    Philadelphia PA
    It's fine.
    c8 a6 allroad
    Nov 27 2013
    B5 S4
    IL
    Shouldn't be a problem at all.
    Veteran Member Four Rings ilyafil's Avatar
    Nov 03 2011
    Bay Area , CA
    it's fine, leave it.
    "Basically the B7 is the girl you bring home to mom, and the B5 is her slutty sister."
    For Sale: Neuspeed Sport Springs
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by 01audia4 View Post
    (little secret: you can reuse them, its just not recommended). The ones on my car have been torqued 3 times! Its holding together alright.
    c8 a6 allroad
    Feb 18 2013
    Silicon Valley, CA
    I figured as such. But the new PP/FW/Clutch came with new ones, so I'll hang onto the old ones just in case
    Veteran Member Four Rings AudiForeman's Avatar
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    I reused mine on my a4, 3k miles 10 clutch dumps an no issues.
    Boosted.Tuned.Cooled
    Feb 18 2013
    Silicon Valley, CA
    So here's the golden question.
    How do you know that the bolts are still good? Are there signs that they have gone bad?
    Jul 28 2009
    Philadelphia PA
    Look for deformation in the threads.
    c8 a6 allroad
