Results 1 to 22 of 22
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Bad Bosch 5.0 ABS module, what to do?
    I have a 2001 Tip with ESP, which means that I have the Bosch 5.0 ABS module. It is failing. The research I have done says that it can't be rebuilt. The research also suggests that the actual electronic "brain" is somewhere under the back seats. This leads me to believe that I need to replace that module, and not the unit attached to the ABS assembly under the hood. However, I have not seen any threads on how to fix this issue with the 5.0 module. How do you fix this guru's?
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Jun 14 2007
    2000 S4
    Connecticut
    http://www.modulemaster.com/en/Audi/S4_info.php
    They rebuild both 5.0 and 5.3 modules..
    Mine was done by them back in 2008 and it is still working to the day.. Great company to work with.
    Veteran Member Four Rings ilyafil's Avatar
    Nov 03 2011
    Bay Area , CA
    I second that!^
    "Basically the B7 is the girl you bring home to mom, and the B5 is her slutty sister."
    For Sale: Neuspeed Sport Springs
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by jpurre View Post
    R&R, that's the fix. There's no 'fixing' failed microprocessors. The question you need to ask is 'used' or 'new' control module.
    rip the CM out first and check for water leakage and that the contact points are not corroded. Past that, replace.
    Jun 11 2013
    2004 BMW 325i
    South Florida
    I've been trying to find the part number for the EBCM, I don't have a problem eventually just buying a new one if mine is toast. I will be checking this during the weekend to see if there is moisture/corrosion.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    jpurre...i have a 5.0 sitting in my garage sell it cheap. also have the stuff under the back seat. let me know.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Jun 01 2008
    Apopka, FL
    I can check ETKA, but you should be able to simply lift the rear seat and the BCM is located right under the bench.
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Ok, thanks guys. I'm gonna check this weekend and I'll see where to go from there.
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Update: I found the part number for the controller. It didn't look like any moisture got in there. Now I'm having trouble sourcing the controller.
    8D0907389E
    Edit: Found a couple on ebay.. just kinda sketchy about buying a used one from there.
    Active Member Four Rings
    Nov 12 2013
    '01 S4 Tip '91 200 20VTQA, '01 A6 2.7TA, VW Rabbit GTI truck.
    SanHo, CA
    Contact BlkdoutS4. He's parting out his S4 and I'm pretty sure he's got the controller you're looking for.
    Jun 12 2011
    Austin tx
    $129 for a rebuilt unit with lifetime warranty. ASI is a great company to deal with.
    http://www.autoecu.com/index.php
    -APR Software -APR Stealth Cat Back -Piggy Pipes -APR Snub Mount -034 Motor Mounts and Transmission Mounts -Forge Diverter Valves -RS4 Clutch & Pressure Plate -Vogtland Coilovers -S4 B6 wheels 8mm Spacers -18z BBK -B6 300mm rear -AWE Boost Gauge -B&M Short Throw -RS4 Upper & Lower Grills -M3 Lip Spoiler -CF engine covers -20% Window Tint -Sport Interior -Color matched Shifter Surround
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    That's weird those things rarely fail. Why not find a local s4 to swap computers for testing
    Be sure to have a vagcom so u can code it
    Sep 29 2013
    The module under the back seat is the yaw sensor. It's for the esp system. If you abs unit is failing you can take the unit off without taking any brake lines off. A little tight but u can get it out. Send it to module masters to be rebuilt. You can still drive the car till u get it back. U just won't have abs and a few lights on in the dash.
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Quote Originally Posted by DxC View Post
    Swapped with a known good one, and still the same result. So the only thing left is the ABS module under the hood. Aggravated.
    Edit: Part# 8E0614111T is probably shot. That is the valvebody under the hood. I will need to check the other "brain" which is under the passenger side carpet apparently. The battle continues.. but I WILL win the war!
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Quote Originally Posted by thyreloaded View Post
    They don't rebuild Bosch 5.0 modules. So now I have to scour the entire planet to find a working 5.0 module that doesn't cost $1.4 million. Perhaps I can install a 5.3 module, that if it fails CAN be rebuilt.
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Sorry to resurrect this thread, but I'm still trying to get this ABS thing figured out. Does anybody know if you can swap a Bosch 5.3 valve body in place of a Bosch 5.0? Any brake gurus among us??
    Established Member Two Rings BlackS42002's Avatar
    May 06 2009
    85 Scirocco. 99.5 Jetta. 02 S4
    Delaware
    What is the issue?
    Jun 11 2013
    2004 BMW 325i
    South Florida
    My ABS module went bad, and it cannot be fixed like all the other Bosch modules can because I have the 5.0 version. I was hoping someone could shed some light on if a 5.3 module could be installed in the place of a 5.0. I don't think anyone has done this. I guess who needs ABS, lol.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Hey I'm not running ABS and have a good working pump. You can come scoop mine up in stuart for $100.
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Quote Originally Posted by landfill View Post
    Thanks, I'll keep that in mind. This ABS thing bothers me. I don't have ESP either with this issue ongoing. Not that ESP is normally engaged either ;)
    Jan 24 2010
    Paramus,NJ USA
    ebay abs module rebuild will cost you about $60 shipping included
    Ziddy Autowerks
