Results 1 to 4 of 4
    May 12 2005
    Bay area, ca
    Testing fuel pump/fuel pump relay
    My a4 isnt starting, and im beginning to think its the fuel pump or fuel pump relay. I pulled the relay to get a new one, but its 50 dollars and has to be special ordered.. Id like to test it before I put a new one in, but I dont know how. Is there anyway to test the relay, or hotwire the fuel pump to see if the relay is the culprit? How would I test the pump? thanks!
    -Steve
    gt3071r'd a4
    May 12 2005
    Bay area, ca
    Ok, i unplugged the fuel pump and hooked up a voltage tester to each connector, moving it around (while the key was in the ON position) and I got about 3 or 4 volts to the fuel pump. Now, im not sure how many volts im supposed to be getting, is it 12? Is there any way to hotwire the fuel pump so I can see if its working or not? Please, please help me before I take this to a shop
    thanks
    -Steve
    gt3071r'd a4
    May 12 2005
    Bay area, ca
    Ok, I went to audiworld and found a writeup on how to test the pump here:
    http://1.8t.org/~quattroman/Audi%20B...%20&%202.8.pdf
    the pump went on when it was hardwired, which makes me believe the resistor is what is bad. I tried starting it with the pump running, but didnt start.. makes me think the injectors/pump run on the same relay, and the injectors are stuck closed even tho the pump is running. Is this true?
    gt3071r'd a4
    May 12 2005
    Bay area, ca
    anyone?
    gt3071r'd a4
