Results 1 to 22 of 22
    Nov 13 2012
    MINNESOTA
    Running blizzak year round?
    http://eauclaire.craigslist.org/pts/4284902726.html picking these up tomorrow does anyone know what year they came off of? I have never seen them they have blizzak on them which is great for winter here in MN. But I plan on running them in summer too. I know they will ware faster but I read someone ran them for three years no problems what do you guys think. And I plan to paint them, copper or gunmetal
    Sent from my SCH-I435 using Tapatalk
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Those aren't Blizzaks that are on those tires. The ad even says 2001 A8. Not sure what ad you are looking at but the one you posted is pretty obvious.
    RAI Test pipe / TT DP / S4 rear sway / Motoza stage 1 / SAI delete / IE Blockoff plate / S4 Front Recaros / B7 Center Console
    http://www.flickr.com/photos/27286038@N03/
    Jul 25 2012
    MI
    If you need some tires just to get through the summer, they will work fine. If you plan on putting more than a few thousand miles on them over the summer and expecting them to be a good winter tire you may be sorely disappointed.
    tl;dr they will work, but wear at maybe 3x's the rate of winter use
    edit: + the things he said ^^
    sic semper tyrannnis, canis
    Veteran Member Four Rings MNAudi101's Avatar
    Aug 18 2011
    Stuff
    Minnesota
    Quote Originally Posted by coowhip View Post
    with him on this one, they say in the title they also aren't snow tires, and no in MN don't use winters in the summer. you will not make it far with them
    200k daily tank
    My Build Thread
    "Like a fat chick in Yoga Pants...Mad stretch "
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    The soft compound during the summer months is going to wear very fast. My sister ran winter tires on her car for 1.5yrs on her car (2 winters) and they were killed with only ~13,000 miles on them. If I knew she was running on winters, I would have given her my wheels off my B5 to get her through the summer but women are dumb when it comes to cars and rubber.
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Did you post the wrong link or are you brain-damaged? Clearly those tires are Potenzas - not Winter tires at all.
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Veteran Member Three Rings rollaphillie's Avatar
    Jan 12 2009
    B6 A4
    Its doable I ran winter tires through the summer last year but it was a death trap in wet weather.
    Warm temp + wet roads & winter tires = easy to slide on roads.
    Also the car doesn't drive as smooth as having a nice set of summers/ all seasons.
    Veteran Member Four Rings Samsonite's Avatar
    Apr 15 2013
    Golf Clubs
    Minnesota
    Yeah like everyone else said, those aren't blizzaks.
    As far as running winters in the summer, not only will they wear fast like everyone already said, they will also be super loud and reduce mpg a bit...
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    I run my blizzaks year round. No real complaints about tire wear or noise.
    Veteran Member Three Rings strtdrms's Avatar
    Apr 03 2012
    Noblesville, IN
    I ran general snow tires for about a year and a half (two winters and 1 summer). No issues running them the second winter. I'm fwd too. Only complaint is that there was alittle more road noise in the summer
    2003 A4 1.8T Avant 5MTQ My Progress Thread
    2003 A4 1.8T Avant TIP - Daily Driver
    Instagram: mr_avant
    Senior Member Three Rings SaabtoAudi's Avatar
    Apr 30 2012
    Erie, Pa
    I was told in my area, that when the temp gets a constant ambient air temp of 50F it's time to swap back over to summer tires. I wouldn't run winter tires year round, period.
    Oct 02 2006
    Wadsworth,OH
    Those are not 18's either those are the 16inch swings from a B5. Running snow tires year round is questionable. Some compounds are softer than others which will wear really fast on warm pavement.
    Either way those are Bridgestone Potenza's which are a pretty good summer tire.
    Jason
    Dec 19 2007
    York, PA
    This guy from Minnesota seems like a super addition to the b6 section...jesus...
    Oct 28 2007
    Ocean Beach, CA
    Quote Originally Posted by n7plus1 View Post
    If it weren't for OldGuy, Walky, Devo, and some other OGs, I'd probably never come to the B6 tech forums.
    EDIT: And Jace.
    Dec 19 2007
    York, PA
    same here...im never on the forums anymore unless im having a problem. Im trying to be more proactive now though. Lifes just got busier and with home ownership, thats where my time and moneys has gone.
    Veteran Member Three Rings Lornnn's Avatar
    May 01 2011
    Pe
    At least he's tilting the noob V. asshole ratio on this forum.
    Dec 19 2007
    York, PA
    i never really ran into many assholes here...
    vortex is a different story.
    Jun 30 2008
    Erie, Pennsylvania
    Those are not 18's either those are the 16inch swings from a B5...
    Jason
    Actually, that's incorrect. Those are the rare 18" version of the 7-spoke "swing" wheel. They are somewhat sought after and were offered on the D2 A8. Part# 4d0 601 025 f
    http://forums.audiworld.com/showthread.php?t=2523974
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by Elliott View Post
    EDIT: And Jace.
    I'm pretty sure you are confusing me with someone else.
    Oct 02 2006
    Wadsworth,OH
    I had no idea those even existed. I loved the way the swings looked on my old B5, they were simple yet sporty. I had even hoped they came in a larger size. Bravo!
    Jason
    Veteran Member Three Rings VAGlover's Avatar
    Sep 23 2013
    b6 a4 track rat
    boston
    Those wont last you three months
    Mar 27 2008
    Denver
    EDIT: And Jace.
    Dawwww!!!!
