Originally Posted by
blmlozz
Sounds like air in the system to me. This fluid will expand when it has air trapped inside. I would try bleeding by turning the steering lock to lock and add fluid slowly.
I have tomorrow off so I'll put it up on jack stands and add fluid to the system and try to bleed it again and just leave it running for awhile and see if I can find a leak.
ianwpb
I would just try to flush all of the fluid.
If you don't know the process -
Remove the fluid from the reservoir then pull the return line off and use a barbed connector to attach it to a piece of 3/8" hose that empties into a gallon jug. Plug the return line hole on the reservoir (I used one of the fingers from a rubber glove and a zip tie). Fill the reservoir and start the car and turn it off within 2 seconds. Don't let the reservoir run dry. keep doing that until you see fresh fluid coming out of the return line that is going to the gallon jug. Once the old stuff is flushed then do your bleed. Make sure the front wheels are off the ground when turning lock to lock.
FYI - CHF 11s is green, CHF 202s is blue, so use the opposite one so you can see a clear difference. They're compatible with each other.
I'll have to order more fluid to flush it and get the blue CHF 202. See what happens when I try bleeding it and leaving it running.
richmonds4
There's a leak in the supply line between res and pump .
Usually it's the elbow hose at the pump , it sucks air in when running
And foams up the fluid. It's not pressurized so it doesn't leak .
I replaced the elbow with the pump. It did this before and after I replaced it. I'll try tighten the clamps and see what happens.
