So I got my S4 together and drivable finally. It idles and drives smooth. Problem though once it warms up to about 3/8 or sometimes the normal operating temp of 1/2, the engine starts sputtering and I can hear the valves or lifters making noise on the driver side head. A friend of mine mentioned the variable timing piece on the head under the valve cover.
I did run Mobil1 5w-30. I saw 5w-40 is called for the engine so would that make the difference or would it be the variable timing piece or something else? Only mods on the car currently are ceramic coated exhaust manifolds, port and polished exhaust ports on the heads and polished entrances to the exhaust manifold (that weld bead is now smooth). The stock downpipes are on the car and light could be seen through the pre-cats and cats.
Scanned the car and I'm getting the EGT code that my friends S4 has had, but doesn't run like mine. He thinks his code is due to the pre-cat in his downpipe.
It has been pretty cold for here in NJ at about 10 degrees Fahrenheit, but I do notice my upper radiator hose gets warm before the temperature gauge is centered on the dash. The temperature gauge will read about 3/8 and never get to the 1/2 or it will get to the 1/2 and then drop to 3/8 and never make it back up to the 1/2. I imagine this would be the thermostat and hopefully clears up as the engine is run more, but thought I should mention. Before taking the car out of the garage, it would get to the 1/2 and stay there.
