Other Stuff Needed: Big pan/pans for catching coolant, towels, normal sockets/extensions/swivels. M9 triple square bit. L handle T30 torx wrench.
My water pump was leaking a very small amount and since I am getting ready to sell the car, I didn’t want to pass this problem onto the next owner.
As far as I know there is no elegant way of draining coolant. Accept the fact that you are going to make a mess of your garage floor. I have two XL sized disposable aluminum turkey baking pans that I use for any work requiring coolant draining. I just get a couple of old towels and lay them out below the engine then put the pans on top of those and hope for the best. This usually catches the majority of what comes out.
Step 1: Jack up the front of the car and remove the following:
• Rear undertray
• Front undertray
• Intake manifold (my carbon cleaning DIY explains how to do this)
Step 2: Disconnect the two T30 bolts holding the cover over the water pump belt. The longer one goes into the block. Shorter one goes into the water pump.
Step 3: Detach the two T30 bolts holding this coolant line in place. One goes into the block and one goes into the water pump housing. This actually seemed to be the location where my pump was leaking but I went ahead and replaced the whole pump because apparently the housing commonly leaks from multiple places and I didn’t want to fix this location just to have a new leak form in 6 months. Once disconnected, you will need to pull the coolant line out of the water pump housing slightly so that the belt cover can be slid out of the way. The deluge of coolant can now begin.
Step 4: Slide the metal clips open on the main connections for the coolant lines coming from the expansion tank and the radiator. Pull both hoses off the water pump housing and let the rain of coolant continue.
Step 5: You are going to need to detach the water pump belt from the water pump in order to get it off. I believe this is most easily done by removing the bolt holding the spur gear onto the block. This bolt is LEFT HAND thread. Unfortunately the head on it is very stubby and it seemed to be an 11.5 mm bolt head???? An 11 mm wouldn’t fit on it and a 12 mm was fairly loose. I tried using a crescent wrench to grab it incredibly tight in conjunction with wedging a screwdriver behind it to hold the wrench on the short bolt head. After applying what felt like enough force to break it loose, I gave up and went to Plan B. If this bolt had stripped or snapped then I’d have been F’d. I show a pic of the spur gear and bolt below.
Plan B was to actually unbolt the water pump from the water pump housing. This approach would allow you to slide the water pump out of the housing which gives enough slack in the belt to remove the housing followed by the water pump. There are five T30 bolts holding the water pump onto the housing and you will need an L handle torx (i.e. like an allen wrench) to fit in there. The locations are shown in the first photo. Access was tight but not horrible. The second photo shows the water pump detached in situ. Two of the bolt locations are highlighted. The downside to this approach is that the belt will not have enough clearance to come off the spur gear so you will need to reuse the old belt. I specifically asked the parts place where I ordered everything what was required to do this job and they did not include the belt in their list of recommend parts. So apparently at least genuineaudiparts.com did not think it was required. Fortunately my belt looked great anyway so I had no heartache in re-using it.
Step 6: Unbolt the water pump housing from the block. There are five T30 torx bolts holding it on with different lengths. Their locations will be obvious from looking at the new water pump. I just put each bolt into its corresponding spot in the new water pump in order to keep track of where each one went.
Step 7: The water pump housing should be free to remove at this point. The remaining coolant will spill out. Pull the cooler pipe out of the cooler if it doesn’t come with the housing.
Step 8: I cleaned off all mating surfaces on the block and covered them with duct tape so that I could clean off all the trapped coolant. I used some hot water in the teapot to strategically dump water/scrub anywhere where there was coolant or coolant residue left. I wanted all of it out of there so that when I was done with the repair I could confirm that there were no leaks. When I was done I blew everything off with the air compressor and let it dry.
Reinstallation: The new O-ring ordered replaces the old one on the rigid pipe removed in step 3. Lubricate all of the rubber sealing rings with Vaseline while reinstalling them. This includes the cooler pipe, mating surface of the water pump housing with the block and hoses coming from the expansion tank and radiator. When reattaching the hoses, slide the metal clips back in place (see first pic) before installing them to the water pump housing. This way you will hear them click when they are fully in place. Bolt everything back up and it will look minty fresh again.
Refill Coolant: After reattaching the intake manifold I simply refilled the expansion tank with coolant. It bubbled as it refilled the water pump housing and then eventually stabilized. I started the car up on while still on the jack stands and let the coolant temp heat up. I also turned the heater all the way up to burp any air from the heater core. The coolant level in the expansion tank went down but not by too much. I topped off the coolant, reinstalled the undertrays and took the car back down from the jack stands. After a day or so of driving the smell of coolant will go away.
