Results 1 to 32 of 32
    Apr 17 2012
    Salem New Hampshire
    1.8t amb cat delete
    Gentlemen. Has anyone successfully deleted they're cat and fooled the ecm by using the non fowlers like I'm attempting to do?
    ~SWAFFELEN~
    Veteran Member Four Rings gottaBdope's Avatar
    Apr 07 2012
    '99 Clown Shoe
    Colorful, Colorado
    Dunno what non fowlers are...but I'm about to yank my test pipe out (prolly today) and it'll be up for sale. Its 034 3in with both o2 bungs. I believe it's not supposed to throw codes but I had motoza adjust the limits on the num2 o2 sensor because it was giving me cel. Never problems since then.
    Pm me if you're interested.
    ^Rory^
    *2014 Audi S6* <- Daily
    *1999 BMW Z3 Coupe* <- Street-legal Track
    Dec 05 2007
    Apr 17 2012
    Salem New Hampshire
    I ordered the test pipe from ecs tuning. I just need to know if it will work if I space the second o2 sensor out of the stream a little.
    ~SWAFFELEN~
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by euroman View Post
    I might, it might not. If I had to put a number on it from all the posts I have read across numerous B6 forums I give it a two out of three chance of working.
    Apr 17 2012
    Salem New Hampshire
    Wow. This really makes me nervous. I got pulled over this morning for not having an inspection sticker dude to my check engine light of catalytic failure.
    ~SWAFFELEN~
    Dec 05 2007
    Won't know till you try.
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A4%20B6/B8
    Arizona
    1.8t amb cat delete
    I have the JHM pipe and no CEL. No problems regarding it since my install (about 5000 miles). Also I thought it was a sweet design as the bottom holes are threaded so you don't need nuts on the end. Makes it so much easier.
    Apr 17 2012
    Salem New Hampshire
    I love you all. Wish me luck.
    ~SWAFFELEN~
    Dec 25 2004
    Earth
    I second this...my ECU had to be APR'd inorder for it to work! I tried everything before...nothing worked! So it may...it may not...
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Dec 25 2004
    Earth
    Quote Originally Posted by gmudan View Post
    Indeedy!
    I install exhaust studs, which IMO makes it easy, vise trying to tighten bolts and nuts in that cramped location!
    Dec 03 2009
    1991 RX-7
    Seattle/WA/USA
    Do you have a J pipe? Or some kind of spacer for the rear O2 sensor?
    ohm mani padme hum
    Apr 17 2012
    Salem New Hampshire
    I have a non fowler for rear o2
    ~SWAFFELEN~
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Just a straight spacer seems not to do the trick in most cases. You need a spacer with a 90 or "J" bend in it.
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Why not just get a tune written for a test pipe? The tune itself WILL code of the cel AND set the cat's readiness so that one can pass state inspections.
    Non-fowlers, J- plugs, etc. work only if youre lucky.
    2019 SQ5 Prestige
    Senior Member Three Rings JAYINH's Avatar
    Apr 19 2013
    f350 dually
    GRANITE STATE
    I have this on my TP and I has worked for the last 8 months without throwing a code
    http://www.ebay.com/itm/2X-O2-OXYGEN...item3a8619747c
    2003 1.8t-air lift -19" LM reps- motoza 1+ - meth, other shit.....
    Oct 02 2006
    Wadsworth,OH
    Thanks for the order!
    Police aren't going to bother you about whether or not you have a check engine light on or even a cat for that matter. Fix your vehicle so it can pass inspection (are you sure its a failed converter and not just an o2 sensor?). Once you get that figured out install your test pipe and see if you get a check engine light. If you do either run a anti fowler like others have said or search for one with a mini catalyst at the end which will fool the sensor into thinking the cat is installed. Or run a tune which codes the rear o2 sensor out.
    Good luck!
    Jason
    Apr 17 2012
    Salem New Hampshire
    Will it work if I install it into the stock cat ?
    ~SWAFFELEN~
    Oct 02 2006
    Wadsworth,OH
    I could. I've personally never tried it but I don't see why not.
    I would first pin point what exactly is causing the CEL. What codes are you actually getting?
    Jason
    Apr 17 2012
    Salem New Hampshire
    I'm getting p0420 catalyst efficiency failure
    ~SWAFFELEN~
    Apr 17 2012
    Salem New Hampshire
    ~SWAFFELEN~
    Oct 02 2006
    Wadsworth,OH
    OK so it could very well be that the cat is bad. A spacer with a small catalyst may or may not work. You would have to just try it out.
    They are pretty inexpensive so its definitely worth a shot plus once you pass your emissions you can install the spacer in the test pipe which should help keep the CEL off.
    Jason
    Apr 17 2012
    Salem New Hampshire
    I just installed the spacer on my stock catalyst. On the rear o2 sensor. The code came back.
    ~SWAFFELEN~
    Apr 17 2012
    Salem New Hampshire
    Quote Originally Posted by gottaBdope View Post
    which motoza did you have?
    ~SWAFFELEN~
    Apr 07 2012
    '99 Clown Shoe
    Colorful, Colorado
    Uhhh, 1+ I'm pretty sure. Pushed 25 peak hold 22 in hawaii, now its about 21 peak 18 here in colorado, a mile up. I'm still pleased, but not for much longer ;-)
    ^Rory^
    Apr 07 2012
    '99 Clown Shoe
    Colorful, Colorado
    Dave wrote it out by process of elimination. He lowered the values and it still came on, so he just wrote it out. Catch is that now I live in CO and have to get emissions :-(
    ^Rory^
    Dec 05 2007
    Your cat needs replacement. The spacer technique is for people who have added flow, so they move the sensor out of the direct path to trick the ECU into thinking everything is ok. Your situation differs, where you don't have enough flow.
    Apr 19 2013
    f350 dually
    GRANITE STATE
    Ihave my old OEM cat I can sell you. if interested PM me
    Senior Member Three Rings chadski's Avatar
    Apr 23 2013
    Harley Davidson Sportster
    South OC, CA.
    +1 - I installed an 034 TP 3" on my B6 and have APR Tuning, never threw a CEL and love it :)
    -Chad
    02' B6 A4 1.8T Dolphin Grey 5pd
    APR Stage2+|KO3s|TT225's|710N DV|Remus Dual w/Res Delete|034 3" TP-Cust.2.5" DP|Cust. AEM Intake|Stern Snub|B7S4 BBK Drilled&Slotted Fronts|StopTech SS Lines|BB FMIC|S4 Anti-RattleClips|NGK Iridium Spark
    S4 Rear Bumper|USP Front Lower|OEM RS4 Inserts|USP Door Blades|Cupra R|Eibach Susp.|RS4 19" VMR|OEM USP CF Spoiler|Boost Gauge|LED Interior Kit|HID Conv.8000k Lows/Fogs|Blacked-Out Euro E-Codes
    Apr 17 2012
    Salem New Hampshire
    Tunings out of my budget range. Unfortunately
    ~SWAFFELEN~
    Dec 05 2007
    ^Did you read my last post? The non fouler mod does not apply to your situation.
    Apr 17 2012
    Salem New Hampshire
    I have a 3 inch test pipe on it's way
    ~SWAFFELEN~
