Page 1 of 3 123 LastLast
Results 1 to 40 of 86
Thread: Fuel Filter DIY
    Senior Member Three Rings autobahnaudi's Avatar
    Oct 01 2010
    2016 Subaru Outback
    Newport News, Virginia
    Fuel Filter DIY
    Fuel Filter DIY
    Parts needed
    o Grommet for the seats 4L0886373 (x2) They can be reusable but I broke both of them.
    o Fuel Filter 8K0201511A
    o Union Nut 4F0201375
    o Pump Seal 4F0919133B
    o ****Disposable Rags****
    **Notes**
    Rags Rags Rags Rags Rags. Lots of fuel will escape the filter while you mess with it as well as the pump it self as you twist it out of the tank.
    The whole task not knowing what I was doing only took me about 45 minutes that was going slowly and figuring things out.
    Also be sure to cover the tank access hole once you have the assy pulled out.
    Lay rags all around the tank acces hole to catch the escaping fuel.
    Open the garage door.
    Remove the seat anchor points.
    [IMG][/IMG]
    Pull up the rear seat with a firm jerk.
    [IMG][/IMG]
    The clip locations
    [IMG][/IMG]
    The fuel tank cap remove the 3 screws
    [IMG][/IMG]
    Disconnect the 2 connectors
    [IMG][/IMG]
    Remove the fuel line ** Make sure the tank is near empty under 1/4 tank.** Also make sure to have disposable rags ready. Wrap the rags around the connector, squeeze the release tab I used pliers, and pull the line off. Fuel may spill.
    [IMG][/IMG]
    Stuff the hole of the fuel line with a rag.
    [IMG][/IMG]
    Remove the union nut, I did it with a screwdriver and a hammer as I dont have the VAG tool required. Just twists off.
    [IMG][/IMG]
    Pull the assy upward.
    [IMG][/IMG]
    Disconnect ground wire.
    [IMG][/IMG]
    Discconect fuel line to filter.
    [IMG][/IMG]
    (Phone died)
    Pull the assy upward swivel to the left to make room to get it out of the tank be careful with the fuel level bobber
    [IMG][/IMG]
    Disconnect the fuel suction line from the bottom of the assy.
    [IMG][/IMG]
    Disconnect #2 the wire clamp just pull downward.
    [IMG][/IMG]
    Pull the entire assy out of the car to make it easier to remove the fuel filter.
    Once out you will see 3 clips holding the filter in place I used zip ties to hold the clips off the filter. Pop the clip slide in a zip tie to hold it.
    Once the clips are released just pull the filter out.
    [IMG][/IMG]
    Replace the O-ring on the filter the new one comes with the filter.
    [IMG][/IMG]
    Slide the new filter in and make sure the clips on secure.
    Take the assy back over to the car and install in the tank reconnect everything in reverse order/
    Dont forget to refresh the tank seal
    [IMG][/IMG]
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    I am actually in need of this as well.
    Oct 01 2010
    2016 Subaru Outback
    I will be writing a DIY on this shortly (when parts arrive).
    Veteran Member Three Rings BMWBig6's Avatar
    May 20 2008
    Georgia
    When should the fuel filter normally be changed (according to Audi)?
    2020 F-Pace SVR / 2016 GLE350 4MATIC
    Favorite Former Rides: 2015 Boxster GTS / 19 E450 Wagon / 2015 X1 M Sport / 11 F-150 Limited / 09 A4 Avant / 08 TT / 03 SVT Lightning / 01 SVT Lightning / 93 740iL / 90 535i / 86 944 Turbo / 83 944
    Mar 26 2012
    Charlotte, NC
    Quote Originally Posted by autobahnaudi View Post
    Has anyone done a diy for a fuel filter change?
    I found the link to the russian walkthrough but its not very detailed.
    My car has a stutter under full throttle only while the stage 2 tune is on (demanding more fuel), and has had some starting hesitation as well.
    I suspect the fuel filter, and plan to change this out at my 50k mile mark. Hoping to find a better walkthrough looks fairly detailed.
    Russian instructions => http://www.drive2.ru/cars/audi/a4/a4...urnal/1947699/
    Oct 01 2010
    2016 Subaru Outback
    Quote Originally Posted by BMWBig6 View Post
    Audi "SAYS" it's a lifetime filter I believe. On the B7 it's changed fairly regularly. I plan to change mine at 50k. I may open it and check it out to see how bad it is.
    Quote Originally Posted by SDF1 View Post
    Ya I found that one it's not very detailed.
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Wondering if the fuel filter and associated lines use something like: http://hpfpupgrade.com/Products/Show...nce+Rail+Valve
    I have been meaning to check and see if a fuel rail on the B8 uses something similar. Getting those back seats off looks quite fun.
    Senior Member Two Rings Dan_Q's Avatar
    May 18 2011
    2011 BMW 335i, 392 whp
    Colorado Front Range
    Quote Originally Posted by A4 Centaur View Post
    Yes there is a valve like this on the fuel rail. You can see it right from the engine bay. It's right where the rigid line coming from the HPFP connects to the fuel rail.
    Oct 01 2010
    2016 Subaru Outback
    Will that have any benefit to us, I think not probably.
    Jan 10 2012
    Republic of Boulder
    Can't really help on changing the fuel filter, but all I can say is that my S.A. (a very honest and thorough guy) recommends that I change it at every major oil change (15k,25k,35k,etc...) because it'll keep the injectors healthy, and they aren't expensive to change.
    I've done so since 25k (now 65k), and my car has had zero engine related issues.
    Hope this helps.
    PREVIOUS:
    1991 Audi 200TQ Avant
    2001 Audi S4 Avant
    2009 Audi A4 Avant (click)
    2014 Audi allroad
    Oct 01 2010
    2016 Subaru Outback
    Quote Originally Posted by crash1121 View Post
    Hope this helps.
    Have you been having the dealer do it?
    How much has it been costing you?
    Jan 10 2012
    Republic of Boulder
    Yes, only the dealer.
    I just checked my 65k service receipt, and they replaced my fuel filter ($54.99) + flushed my fuel system for a total of $95.00.
    PREVIOUS:
    2001 Audi S4 Avant
    2014 Audi allroad
    Oct 01 2010
    2016 Subaru Outback
    Actually sounds like a steal of a deal for the work and parts involved (new seal, filter, and new union nut and seat clips.)
    I need to call and ask them. Good looking out.
    Jan 10 2012
    Republic of Boulder
    My bad, I misread my receipt! (Dealer's new receipt format is confusing)
    "PERFORM VEHICLE FUEL SYSTEM SERVICE AS PER CUSTOMER REQUEST.
    Installed 10104 : FUEL SYSTEM FLUSH AND REPLACE FUEL FILTER : 1@$54.99"
    Labor: $95.00
    Sub Total: $149.99
    IMO, $149.99 is still a good deal for every 10k miles...
    PREVIOUS:
    2001 Audi S4 Avant
    2014 Audi allroad
    Senior Member Two Rings jaysen's Avatar
    Oct 30 2009
    Labor: $95.00
    Sub Total: $149.99
    $150 for me every 10K miles would be hard to swallow... but i agree not totally outrageous for something that is beneficial to an engines health.
    subbed
    Jun 05 2009
    Scottsdale Arizona
    [QUOTE=autobahnaudi;9414424]
    Thanks for posting up the diagrams. I was hoping we might get some kind of result from the valve opening earlier. The B7's were able to get a little bit out of this simple mod.
    Oct 01 2010
    2016 Subaru Outback
    [QUOTE=A4 Centaur;9415368]
    It would be worth a shot. It's an easy mod. I personally can't find any specs on the valve in the b8 I know the b7 was rated to 126 bar.
    Also don't know how much or many bar the high pressure fuel pump pushes on stage II or II+.
    Would be curious to have that info though.
    Oct 01 2010
    2016 Subaru Outback
    Garage reeks of fuel still.
    Veteran Member Four Rings Frinkferta's Avatar
    Aug 27 2012
    Earth
    Febreez!
    Mar 26 2012
    Charlotte, NC
    AWESOME DIY!!
    Did you notice any difference with the new filter?
    Oct 01 2010
    2016 Subaru Outback
    I did notice a slightly better pull through the gears at above 4k rpm.
    The true test will be when I retune my car with the APR stage II and see if the power hesitations (spasms) are still there.
    Hope to have it retuned shortly.
    Veteran Member Three Rings Comp4k's Avatar
    Aug 10 2009
    Carlsbad, CA
    Oh, I never knew our fuel filters were "life-time". I'll get mine changed at 50k.
    Veteran Member Three Rings formula1guy's Avatar
    Apr 14 2009
    B8 A4 Avant S-line,2010 A4 prem + w sport package
    Northern California
    Great write up autobahnaudi, thank you!
    May 07 2014
    Just did this myself, and it was easy enough except for the union nut. Anyone have a link or name to the tool that Audi uses to remove it? Myself, I used a hammer and screwdriver as instructed in this DIY, and stripped about half of the ridges on the union nut before I finally twisted it off enough for it to come off. Good thing the DIY clearly states to get a new union nut, and this isn't even an OPTION guys!!! Try to get the angle as acute as possible (keep the screwdriver angled low), and hammer away quickly but with enough force.
    Lots of fuel will be in the filter and get all over the place. Also, if you don't plug the fuel line hole, every time you hammer, you'll splash fuel all over the place, so it's key to do this.
    Removing the whole assembly is a bit cumbersome. I removed the upper part, and not certain I reseated it properly (although by feel, it slid right into place).
    Started the vehicle up afterwards, and no issues whatsoever. It'll be a few more days until the next fuel-up, but so far no adverse effects. Would recommend that everyone has this service performed. Quality (or lack thereof) of North American fuel is regularly something over-estimated by German auto manufacturers.
    Sep 14 2006
    Just ordered my filter for $41.64 shipped from autohausaz. Planning to do this every 50k miles like I did on my B6. The union nut on the B6 was metal, not sure why they changed it :(
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Sep 14 2006
    Crap, I found a place that sells them for even cheaper :-0
    http://www.rmeuropean.com/Part-Numbe...b-9b1728e03c38
    I'm liking the fact that we can get these filters for less than the price of 5qts of synthetic oil lol
    -Thomas
    Current: /S3
    May 07 2014
    Man, great find, and thanks very much for sharing!
    Mar 26 2012
    Charlotte, NC
    Bump.
    Anyone notice the fuel filter help with cold start issues with the car vibrating/shaking?
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Just used this DIY to change my filter out at 80K miles. Thanks OP!
    None scientific comparison below:
    Blew through the new one: Was like blowing through a straw.
    Blew through the old one after draining gas out of it: Was like blowing through a straw into a milkshake.
    Engine revs faster now and the car feels more responsive on the road.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Junior Member Two Rings Kaz62's Avatar
    Sep 13 2012
    Avon, CT, USA
    Great DIY! I just completed this with 84k+ miles and it's made a huge difference in performance - perfectly smooth now under acceleration. I have a couple additional tips that should be helpful. First, there are two locations, 180 degrees apart facing each rear door, where there are ring locks through a simple toothed latch. You will need to hold these away from the ring so it will rotate freely. Second, if you can get somebody to help, have each of you tap a screwdriver with a hammer on opposite sides together - this will loosen the ring very quickly!
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    thank you autobahnaudi for posting this diy its been a great help. just performed this yesterday took me 20 minutes. had a indy shop quote me 300 plus tax to replace this which i thought was ridiculous. thanks again.
    Senior Member Three Rings DJ_AudiA4's Avatar
    Oct 01 2012
    2005 Kawasaki ZX6R
    Temple City, CA
    Did the the fuel filter change, the Union nut is definitely a pain to get off, even with the tooth and latch pushed down.Didn't remove the whole pump, just the top but I had some trouble getting the bobber to seat correctly, even tally got it. Ran the car and is was fine so think everything is good. Putting the seat in was a lot easier with the plastic brackets removed.
    All in all, glad i saved myself the money and changed the fuel filter. THANKS for the write up.
    Also ordered the OEM filter from ECS and it came with plastic tabs to disengage the pump.
    09 A4 6MT Quattro Frankenturbo, Eurodyne Tune,K&N intake , SPM TP, AWE catback, CTS FMIC, ST Coilovers, Roc-Euro STS, 034 Transmount, Apikol bushing, GFB DV+, H&R sway bars, AWE boost gauge, VMR 701's 19x9.5, RS4 grille and fog light housings.
    289HP @ 6100| | 297ft lb @3900
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Pics don't work
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Active Member One Ring makhanaka's Avatar
    Sep 29 2015
    TN
    Quote Originally Posted by DGVR6 View Post
    Pics don't work
    /\ /\ /\ that
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Pics don't work
    Just saw that and was thinking this is something I should do sooner than later.
    My 2009 A4 Prem+ Build thread
    Jun 21 2014
    2012 Grand Cherokee 5.7 L
    Santiago, Chile
    I cannot see the pictures on this thread, does anyone have the procedure with pix? Very much appreciated
    Thank you
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by Westija View Post
    Thank you
    +1
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Jul 07 2012
    Boston, MA
    Fuel Filter DIY
    Parts needed
    **Notes**
    [IMG][/IMG]
    [IMG][/IMG]
    The clip locations
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    (Phone died)
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Pictures not working. Can you fix please?
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    So I just tried to have this done yesterday at my independent Audi shop and apparently the part for the B8 is slightly different than the B8.5 (which I have). So the part I ordered above did not fit.... According to them the B8.5 part is one letter different but also over 250 bucks compared to 40. Multiple dealers have refused to help me because they say it's a lifetime part and the only thing they're willing to do is swap out the whole fuel pump..... Nope.
    If anybody here can help me find the correct fuel filter for the B8.5 model I'd really appreciate it... Having issues finding it (unless the shop yesterday was wrong and this filter really does fit. They had the back seat off/ tank open and everything and said it didn't work
    I'm at just over 90,000 miles and have some high load hesitation going on so I'd like to swap it out
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by AllroadCorbin View Post
    Audi parts seems to think this is your part #.
    http://www.parts.audiusa.com/parts/2...7207&siteid=16
    http://www.audiusaparts.com/audi/all...omponents-scat
    $30 here
    http://www.rmeuropean.com/Products/8...1A-MFG114.aspx
    Your shop probably saw part 8K0201511TA, which looks like the filter with the flange on it.
    Lifetime part.... The resistance of my old one vs the replacement was pretty significant. If you've put around 4,000 gallons of gas through the thing, you would expect it to have filtered some contaminants and have lower flow than desired.
