Originally Posted by
B8_Jim
I don't think I've seen audi say what the system does at the limit - but their press info for the B8 A4 release does quote the torque split "for normal driving conditions" :
"Both gasoline FSI engines are available with the quattro permanent all-wheel drive, which is optional on 2.0 TFSI or standard on 3.2 FSI. Under normal driving conditions, this distributes the forces at a ratio of 40:60 between the front and rear axle. This emphasis on the rear end perfectly harmonizes with the overall dynamic character of the new A4. If needed, the self-locking center differential transfers the majority of the torque to the axle with the better traction. As in the past with all North American models, all A4 Avant models always have quattro as standard equipment."
Don't confuse "at the limit" with going fast. I'm referring to the "limit" of available grip which can just as easily be exceeded at 5 MPH on ice.
As for the brochure quote, I invite you to check the link I'll provide below.
dscline
That is simply what Audi claims. I certainly have no way of measuring it. Though I can tell you after driving my B5 for over 14 years, and now my B8 for over 2, I can tell a difference. Like I said, with the B8 if you really get on it in a sharp corner, you might be able to break the rear lose a LITTLE if you really romp on it. I could never really sense the rear moving out any in that kind of situation with the B5. The B8 really does feel like it has some bias towards the rear vs. the B5. If it's less than the 60/40 ratio Audi claims, I'm not going to split hairs over it.
I'd be interested in seeing that documentation. I have a hard time believing they'd use a different center differential in the S4 vs. A4. To what end? Sure, the S4 has the OPTION for the sports differential in the rear, but why would they claim 60/40 on the A4/S4 models, then do something different?
I don't know how you've missed it, it's been mentioned quite a bit ever since they introduced it. It's listed in the
brochure, among other places, as 60/40 rear/front, with no differentiation between the A and S models.
I daresay that the difference between the B8 and B5 chassis weight distributions have more to do with your perception of a "difference" than any difference in the quattro torque split. The B8 has gotten much closer to the ideal 50/50 weight distribution than the old B5. Avants are almost dead even with the extra 250 lbs over the rear wheels.
Anyway, I, like you, hate B.S. so here's a link to Audi's B8 A4/S4 brochure (specifically the quattro section)
http://viewer.zmags.com/publication/...67#/70d55067/8
On page 9, you will find all the general advertising blather that you guys are quoting. But somehow you missed it...
at the end of the first sentence at the top of the second column, we find a notation (1). If you look at the small print at the bottom of page 8, you will find notation (1) where it states:
Torque split ratio will vary from model to model
I'd take the notations as more "true" than the advertising copy that raves on about all the "uberness" that is Audi... The notation was added by the lawyer that said "we can't be so liberal with the truth in the brochure without a disclaimer."
If you have a MT B8 A4/S4, then you can buy a center diff that actually gives a rear bias and is amazingly effective.
