Results 1 to 40 of 41
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    B7 pilot bearing removal
    Anyone on here ever removed this before?
    I looked around and people recommend using grease as a hydraulic to push it out from the rear. Others said to use a slide hammer, and Audi used a kukko extractor that is like $300. With that back plate I'm not sure grease will work.
    I was curious if anyone has had good luck with a generic tool I could just rent?
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Hmm not sure why it showed up so small
    Oct 16 2008
    South Florida - Ft Lauderdale
    What bearing is that Mec? Location?
    Phil
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Cut a slit in the bearing so you can fold it inwards to relieve the pressure and it will slide right out. Be careful to not cut into your crank though. (it is hardened steel so a slight scuff won't hurt it.
    Aug 31 2011
    Lathrop
    Phil
    It is the pilot bearing.
    Jan 03 2014
    AUDI A4 2.0T 2007 & BMW 323i 2011
    Quebec
    Quote Originally Posted by Jake@JHM View Post
    Location?
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Cut a slit in it? Using what? a dremmel wheel won't fit in there...
    Quote Originally Posted by diond View Post
    Location?
    End of crankshaft, holds the input shaft of the transmission
    Oct 04 2011
    Rochester, NY
    Hey mec, I haven't done this on an Audi but I did just do it on a Nissan Frontier. Use the "hydraulic" method. I used a small 1/4 in socket with an extension in it backwards (extension through other end of socket) you want a socket that just barely fits in the bearing. Fill the opening on the crank with grease, maybe quarter way. fit backwards socket in there and tap it out. Won't need too much force. It'll come out
    Aug 31 2011
    Lathrop
    A dremmel will fit in there if you have the right bits. Anything will work that you can fit in there to cut it and fold it inward. Even the saw on your swiss if you have the patience!
    Senior Member Two Rings BMT62688's Avatar
    Oct 12 2010
    2013 S5/2003 Vw Passat
    Pittsburgh
    I used a slide hammer bearing puller I got from harbor freight. http://m.harborfreight.com/automotiv...ler-95987.html
    2013 S5 Estoril Blue
    HR Sport Springs | USP RS5 Grille | APR Stage 2 Tune | ECS Boost Tap | 034 Motorsports Intake Tube | EUROCODE Aluminum Upper Diff Mount Insert |EUROCODE Aluminum Lower Diff Mount Insert | EUROCODE Aluminum Trans Mount Insert | BFI Alcantara shift knob | VIM Mod | APR 57.75mm Supercharger Pulley | APR 187mm Crank Pulley | Ported TB | Merc Racing Stacked Heat Exchanger + Divorced | ZKW-R Lens Swap | Eurocode Alu Kreuz
    Oct 12 2010
    Pittsburgh
    I tried the grease method and wet paper methods first and they wouldn't work for me
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by russkieA4 View Post
    I really don't want to do this...getting a grease gun just sounds like a pain but it sounds like it is the easiest method, I just hate working with grease.
    I just tried to drill through the thing with 12 different drill bits, masonry,woodworking, metal, step drill bits, nothing works..This thing is tough as diamonds
    Literally did not even scratch it...well it did scratch but surface, I didn't get through it even a bit.
    Quote Originally Posted by BMT62688 View Post
    I think this is step two....I borrowed a snap on slide hammer but it didn't work...
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Here's the tool I was lent from a shop.
    Oct 04 2011
    Rochester, NY
    You dont need much grease. I used a castle product called "Brake Life". Used to lubricate brakes pads and pins, its not as greasy as normal grease. But still works. Also heard someone use wet paper towels. Just crammed them in there and used the socket method to "push" the bearing out. Should be cleaner if you hate grease. It surprised me how easy this method was
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    But then you have to drill it out right? that small hole in the center doesn't have enough space to do much to fill through..and I can't drill it....shit is made of titaniumdiamonds
    Oct 04 2011
    Rochester, NY
    No drilling at all. The key is to find a socket that just barely fits. You want all the force to transfer through the grease, not squeeze out between the socket and bearing
    Oct 04 2011
    Rochester, NY
    Its hard to tell from the picture, are both ends of the bearing open?
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Just heard back from another guy who tried the bread and the grease trick on the audi, said it didn't work...I think I'm gonna try the HF tool first. that looks really solid. I appreciate your advice, I think I'm just being a little bitch about using grease...not sure why, just my concience is like nah don't do that, its gotta blow all over your face ( oh yeah engine is stilll in so I am working from underneath), pretty weird though I just don't want to...usually I'm like well lets do what will work...
    Oct 04 2011
    Rochester, NY
    Interesting. Let us know how you get it done. Seems like the slide hammer might be your best bet
    Dec 11 2008
    '08 A4 Avant SE, '99 4Runner
    Westminster, CO USA
    I failed miserably with a pilot bearing on a 4Runner not too long ago. Grease just blew thru the bearing seals and made a mess. No way I could split or drill it, way too hard of metal. The thing was stuck.
    This tool did the job in 2 seconds. Hook is small and strong and you just put in in center of bearing and tap that peg sticking off the side in the opposite direction. I was able to borrow it from my brother luckily. He said snap-on sold it to him.
    http://www.sears.com/kd-tools-seal-a...a=00994179000P
    Oct 16 2008
    How about bread?
    Phil
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    How about bread?
    Phil
    I don't think so...We have a strange pilot bearing, it has a cap on the back side, with just the tiniest hole in the center, so bread wouldn't be able to go through the hole. If I'm not mistaken, the way that the grease trick works is that you pack out the area behind the pilot bearing and then apply air pressure using an air tight socket and a hammer,the air compresses whatever substance you are using, but since it has nowhere to go it pushes out on the rim of the pilot bearing. This would be very hard to do with our pilot bearing, most don't have a cap on the rear, but ours do so you would have to be quite skilled or get some kind of needle to shoot the grease behind the pilot bearing. The kit that BMT posted seems like what would work best.
    Luckily you don't ever have to deal with this bearing, being a tiptronic
    Oct 16 2008
    Good luck Man
    Phil
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Came out like butter! It's all about having the right tool.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    bump to make the tapatalk image bigger
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    This tool is the shit. So it's a slide hammer. and the tips are rings that flare. so you insert the tip into the bearing, you spin the tip of the black thing and what it does is it makes the metal screw part go into the flared section and it makes it expand. So once you can't go any further you get a wrench on it and max it out. Then you attached the slide hammer, spin it on with the nice T handle, then go to town, move that weight hard, and it comes right out, took like 5 taps of the hammer. Maybe with setup like 5 minutes to get it out...spent an hour yesterday trying to get it out with other tools.
    $80 at HF if anyone ever needs it.
    Thanks for the tip BMT62688
    Oct 23 2015
    Australia
    Necro bump absolutely....
    Wanted to share this with fellow 6mt 's wanting to upgrade your clutches and why wouldn't you....?
    When you come to the pilot bearing,its a real PITA to remove and is a necessary part of any clutch upgrade-First,I borrowed a (really top shelf ) puller..uh,oh didn't work,the rolled edge is just too small for a puller to grab it just tore out .Then I was going to try a 3/4 inch plug tap which would have worked but my easy solution today,a Sunday and the local hardware came to the rescue- Too easy...
    You 6mt's should lock this away in your memory banks for when you come to do it !
    Firstly with an old screwdriver mangle the needle bearings inside and remove,then screw in tight -Ramset Dynabolt DP16065GH , 16 by 60mm.
    Weld rod to M12 nut,screw onto end of dynabolt,vice grips other end then drive out bearing hitting vg's with dead blow...
    Forget all the posts above if you want an easy procedure.
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
    Mar 24 2013
    Oakdale, CT
    I drilled out the cap at the end of the bearing to 1/4" and used bread and a steel rod to pack it in. Took a little while but it came out pretty easily. The puller I bought was worthless (it was the spreading finger kind).
    -Adam
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Ringsby4 View Post
    tool fabricating
    Oct 23 2015
    Australia
    Wholemeal or soft white ? lol - to the power of hydraulics but reading all the posts re this method,I was thinking too that the pinhole would just have to be drilled...
    Quote Originally Posted by vce1232000 View Post
    tool fabricating
    Yea unlike my damnfangled camshaft holder,this worked
    Jun 17 2013
    jersey city nj
    We all learn to from trail & error ..........
    Oct 23 2015
    Australia
    for sure hopefully with less error ! Should be swinging engine in today..clutch on,find some O rings for heater connections and,then yes,hopefully no errors.....
    Mar 24 2013
    Oakdale, CT
    It was a regulation style hamburger bun
    -Adam
    Oct 23 2015
    Australia
    lol, I wouldve been worried about the sesame seeds jamming up the works....
    Are you on the lookout for another brink or concentrating on the powerhouse ?
    Mar 24 2013
    Oakdale, CT
    Concentrating on my car. The new engine is in place, but I discovered that I need a new hpfp. Mine apparently got bent when the intake valves hit the #4 piston.
    -Adam
    Oct 23 2015
    Australia
    tool fabricating
    How did that exactly happen,surely everything was still rotating when the piston got hit ?
    Mar 24 2013
    Oakdale, CT
    Not entirely sure but it also sheared the drive plate off the vacuum pump.
    -Adam
    Jun 17 2013
    jersey city nj
    Probably when the connecting rod separated from the crankshaft. This allowed the engine to over rev and caused related damages . Perpetual motion in effect until boom nothing else moves
    Mar 24 2013
    Oakdale, CT
    Don't think that was it. The engine was actually still running (very roughly) on 3 cylinders when I pulled to the side of the road. RPM never went above about 4k. I'll pull the blown motor apart and look for clues after the car is running again. I'll put together an autopsy report with anything I find in my build thread when I get time.
    -Adam
    Jun 17 2013
    jersey city nj
    Hmmm you got my curiosity going now
