Originally Posted by
SN95Audi87
I would like to hear more responses. Its either ECS or FCP. The gates racing belt is a plus, atleast you know it can go to 100k if need be.
It's not just the belt that can fail. The gates belt just ensures your belt won't lose a tooth or snap. But there is also the tensioner that can fail and the water pump (if the water pump is run by the timing belt) which isn't a good bet to expect to last another 100k miles! I believe most of the failing timing belts were cause by the tensioner too!
I think the only thing that needs to be replaced is the timing belt, tensioner, pulley, water pump, thermostat and the accessory belts. I didn't do the cam seals.
