Results 1 to 40 of 53
    Veteran Member Four Rings KryptoniK's Avatar
    Jan 29 2006
    08 RS4
    DIY: Aftermarket seats.. How to eliminate the AIRBAG WARNING LIGHT...
    For the past few years since I've owned the Euro RS4 Sport Seats I've been on a quest to eliminate my Airbag Warning Light. I get some hints and clues here and there but can never find one person to give a full description of how they were able to eliminate the light.
    So far I've done the following with no success...
    1) Sourced and installed official VAG yellow airbag resistors to connect in the floor panel under the driver and passenger seat.
    2) Sourced and installed a passenger seat occupancy sensor from a B7 A4 passenger seat I bought used but have not successfully connected it to the floor panel under the seat.
    3) Connected both driver and passenger seat belt sensors in the floor panels under the seats.
    What else am I missing? Can anyone chime in on the exact process they went through to successfully eliminate the airbag warning light with aftermarket seats? The RS4 community needs this badly.
    Much appreciated in advance..
    -Dave
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    What codes are you getting?
    Seat occupancy sensor open circuit and side airbag igniter open circuit?
    Jan 29 2006
    08 RS4
    Quote Originally Posted by JimmyBones View Post
    Forgot about posting that, figured most people knew the general codes. I'll get into the car tomorrow morning to scan the codes and I'll post exactly what I'm getting.
    Oct 12 2010
    Keswick, Virginia
    Dave,
    It sounds like you have it covered. use the below link to help get your occupancy sensor working (i had a shop do the install for me). other than this you will need those yellow resistors you have and you should be all good.
    http://nickscarblog.com/diy/how-to-i...-warning-light
    Tino is the best one stop shop i know...
    Sep 27 2011
    Tomatoes
    Eastern PA
    Quote Originally Posted by zmon View Post
    Dave,
    Exactly this. I have had my seats in my car for about a year with no error codes and the occupancy sensor working properly. As long as you have swapped all your US spec belts, and have your occupancy bladder in place you should be good to go once you work through the codes.
    Dave, you're close, I can come help you if needed, that is if your not gonna dodge me again
    Suzuka Gray 2015 S3 Thread
    Misano Red 2003 RS6 Thread
    IG: @Flying_Tomatoes
    Sep 27 2011
    Tomatoes
    Eastern PA
    Quote Originally Posted by KryptoniK View Post
    this one I would guess?
    01579 - Signal for Seat Occupied Sensor; Front Passenger Side (G128)
    Mar 11 2008
    B7RS4 & e46Ms
    FRRG AZ Ring
    Jan 25 2013
    Lafayette Indiana
    Im on board for this thread and getting an official DIY/procedure. It is needed badly for the audi community.
    I have had the Airbag light on in my car for going on 6 months now and would like it gone as well. I'll throw in my $.02 and what knowledge I have learned/gathered. Put it in a form that can be added to/ updated/ changed and maybe after a while and everyones input of what works and doesn't work we will end up with a DIY.
    I think it comes down to bypassing or modifying 5 things:
    1.) Drivers seat airbag circuit - no airbag is there anymore, so a resistor must be placed in that circuit to fool the computer into thinking that there still is an airbag. If I recall resistance needed is low... maybe 5.6 Ohms? Correct me if I'm wrong
    Action Needed: Wire resistor into yellow airbag plug circuit - resistance to be confirmed. 5.6 Ohms?
    2.) Passengers seat airbag circuit - no airbag is there anymore, so a resistor must be placed in that circuit to fool the computer into thinking that there still is an airbag. If I recall resistance needed is low... maybe 5.6 ohms? Correct me if I'm wrong
    3.) Drivers seat seat belt buckle circuit - this circuit tells the computer if your buckled in or not. I see two options here... you could wire your buckle leads into the appropriate pins on the floor and retain the OE functionality of the buckle. Or you can bypass this with a resistor as well. I took a meter to my buckle and if I remember correctly it goes from low resistance when no buckle present, to high resistance when a buckle present. A high value resistor between the two pins will tell the computer the seat belt is always buckled. This also eliminates the seat belt chime, which I know can be turned off in VCDS as well.
    Action Needed: Wire in resistor (think I used 100 ohm?) or wire into appropriate pins in floor to retain OE functionality
    4.) Passengers seat seat belt buckle - this circuit tells the computer if your passenger is buckled in or not. This buckle, oddly, is different than the drivers buckle. It contains a spring loaded mechanism that I'm guessing somehow combines sensing buckle present/not present with belt tension. I could not easily identify a resistor that I thought would bypass this buckle... I didn't mess with it too much though. Maybe just wiring it into the appropriate pins on the floor would be best to retain OE functionality.
    Action Needed: Wire in resistor (have not identified appropriate resistor) or wire into appropriate pins in floor to retain OE functionality
    5.)Passenger seat occupancy sensor - This tells the computer if someone is sitting in the passenger seat or not which lets it determine if it should have the passenger seat airbag on or off. This is not a simple sensor and involves a bladder that takes pressure from weight being placed on it and applies it via a tube to the module. The module then outputs a variable voltage/resistance to pins in the floor to let the computer decide if the passenger is "large" enough to enable the airbag. I am pretty clueless on this one... I suppose the right resistance between the right pins might work to bypass the module but I have no clue how to figure that out. Most people with success have used some kind of donor occupancy module... but I will leave that up to them to describe how they implemented it.
    Action Needed: To be determined
    07 Misano Red RS4 - Stasis Motorsports - Hotckis Sways - JHM 380 front + LW rear Rotors - Stop Tech Pads - Stainless Lines - Enkei PF01 18 x 9.5 ET 15 - 255/40 Michelin PS/AS 3's November thru March - 275/35 Rivals April-October - JHM 93 Tune - Aux Rad/Sai Delete/Cold air feed - Magnaflow CB - Status Ring Gt seats - JHM shifter - Stainless JHM knurled knob - LED DRL's/Fogs/City - Clear corner with LED turn signals - Ziza full interior LED kit
    Veteran Member Three Rings OscarMeyer's Avatar
    Oct 01 2010
    VW/AUDI Only
    Burnaby
    Dave,
    so far from your list you have everything correct, but you don't need to swap the bladders, RS4 Recaro's never came with them, in Europe the airbag coding is different, you can either code It to run the airbags always, which if you get into an accident, the passenger airbag would go off even if no one is sitting there, or the other option is to get the input from the buckle, rather then weight on the seat. (I used this)
    I'm just at work but I should be able to get you the coding information by tonight, pretty simple just a couple of numbers need to be changed and the car will realize you have buckets.
    I also have a DIY half finished, I just need to take a few more photo's.
    07 RS4 - Projekt: Pandora
    Established Member Two Rings BorisTheBlade's Avatar
    Apr 04 2011
    '08 RS4, '16 SQ5
    Franklin Lakes, NJ
    Quote Originally Posted by OscarMeyer View Post
    Dave,
    Hey would you mind shooting that over to me too...in the same boat with the buckets...much appreciated
    Oct 01 2010
    VW/AUDI Only
    Burnaby
    BorisTheBlade, KryptoniK. PM'ed
    Established Member Two Rings c615586's Avatar
    Aug 10 2009
    2007 RS4, 2016 Volvo XC90 T8 Inscription Hybrid, 2013 Carrera 4S Cabrio
    Upper Arlington, OH
    Shoot. I'm still just working on sourcing some Euro B7 RS4 seats.
    Aug 10 2009
    Upper Arlington, OH
    Seats purchased! Should ship out from England on Wednesday.
    Oct 01 2010
    VW/AUDI Only
    Burnaby
    That's so awesome man! Your going to love them once they arrive!
    Nov 02 2010
    Quote Originally Posted by 07MisanoRed View Post
    I solved this issue without the need of a bladder. I tried buying a bladder from another seat, and it didn't work for me. I ended up having this guy build me a device that tricks the computer to think that there is always someone sitting in the passenger seat, and therefore will eliminate the airbag light. The only thing with this option, is that once you trick the system into thinking there is always someone in the seat, the seat belt light and chime will go on. I simply used a dummy seat belt clip and problem solved, but there may be a way to avoid this via the vag com, but I don't know.
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    Eliminating the seat belt chime is an easy one. Here you go.
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Aug 10 2009
    Upper Arlington, OH
    OscarMeyer, can you PM me your diy on how to get the seats in code-free? Now that the weather has hopefully warmed up for good, I'm itching to get these guys in my car!
    Jan 29 2006
    08 RS4
    Coincidence you revived this thread.. I just resolved the air bag light last night, ill post my own version of a DIY shortly. Thanks to everyone for the helpful tips and links. Now the pass seat functions like stock with the pass air a activating/deactivating when someone sits.
    Its been a long time since I've seen my cluster warning free, so beautiful.
    Oct 01 2010
    VW/AUDI Only
    Burnaby
    Quote Originally Posted by c615586 View Post
    Yes sir I can! I've been meaning to finish the day!
    So glad to hear! Did you vagcom the car to pick up the European settings?
    It's really just a matter of swapping a few numbers.
    Apr 04 2011
    '08 RS4, '16 SQ5
    Franklin Lakes, NJ
    I am doing mine in the next few days, so tired of staring at that light lol...i'll post once I do the euro settings...
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Bump. Can someone please share (either via post or PM) the coding used to eliminate the occupancy sensor?
    Quote Originally Posted by BorisTheBlade View Post
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Oct 01 2010
    VW/AUDI Only
    Burnaby
    http://*******************/forum/index.php?topic=2500.0
    (Audizine blocks Audi - Revolution . Net - but just go to the DiY section to find the coding needed.)
    I've been meaning to take more pictures for that DIY, but that should solve your issue's.
    One thing I forgot to list on the DiY is to use your stock North American buckles, as the European sensor/plug is on the driver side.
    Dec 10 2011
    CLT | MKE
    http://audirevolution.net/forum/index.php?topic=2500.0
    Thanks a lot, OscarMeyer. So this takes care of the occupancy sensor issue. It sounds like it may take care of the airbag issue as well. Is this correct, or will I still need to use resistors?
    -Hayden
    Veteran Member Four Rings MattboyR32's Avatar
    Nov 28 2006
    Orange County, CA, USA
    Sorry to revive an old thread. What did you all do for the seat belt sensor/wiring. I thought it could be as simple as undoing from the wiring loom under the seat. Seems not to be the case. So has everyone bought the connector (red one I think) and wired it up to the seat belt plug?
    thanks for the help
    B7 RS4 6MT Daytona Grey
    JHM 2.75" catback non-res, piggie pipes, 034 transmission, engine mounts, strut mounts & end links, Apikol diff mount, Hotchkis adjustable rsb, Escort 9500i (HW), JHM lightweight rotors, JHM intake manifold spacers, BC Racing coilovers,
    RIP: B7 S4 DTM 6MT Dolphin Grey
    JHM Tune, Corsa Catback, Piggie Pipes, Bilstein PSS9, RS4 Reps, Blackvue Car Blackbox (HW), Escort 9500i (HW)
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by MattboyR32 View Post
    thanks for the help
    Black plug is for the seat belt
    Nov 28 2006
    Seats are in finally. Still a little fine tuning on drivers side but all good. Sits higher than expected but definitely feels more connected and solid. Not sure if I can daily drive it but it's fun. Now for harness bar or roll cage and resistors. :)
    Senior Member Three Rings Gansel's Avatar
    Apr 09 2015
    Vancouver
    You really committed to the race car life. I dig it
    Im working hard now so my future daughter doesn’t have to sell protein powder on Instagram - 08 RS4 - Insta: @gansel
    Nov 28 2006
    LOL, sometimes it's a function of an idle mind. We also have a family friend racing in Blancpain GT series so I begin dreaming... ;)
    The accountant in me also managed a good deal for both seats :) That helps
    Nov 28 2006
    So I did the oscarmeyer recoding today. Cleared faults and this is the only fault left. Mind that I don't have resistors for the airbags yet.
    1 Fault Found:
    02511 - Control Module for Seat Occupied Recognition (J706)
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    Jul 28 2007
    V8's
    In an Audi
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    That is for the occupancy sensor.
    Apr 04 2011
    '08 RS4, '16 SQ5
    Franklin Lakes, NJ
    pretty sure there is no way to clear that one...Kryptonik and Flying Tomatoes both installed the occupancy sensor in the end...i think its the only way
    Veteran Member Three Rings mightemouce's Avatar
    Mar 12 2007
    01 S4
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Time Indication: 0
    I've run into this same issue following the coding on AR
    07 - RS4
    05.5 - 2.7t B7 -Sold
    Insta-Ste3v3_0
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    Unfortunately to this day I haven't found a solution to go around the occupancy sensor on North American models.
    The occupancy sensor is a larger gel filled pad that is in the factory seating. It has a pressure sensor and a control unit which sends data to the airbag controller.
    RS4, R8, etc owners that go the full aftermarket or European sport seat route can either disassemble the factory seat, get a used seat to take apart or purchase a new occupancy setup to either tuck away or place into the new seating.
    If anyone needs assistance with this or side airbag immobilizers as well I can always assist: [email protected]
    Cheers,
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Mar 12 2007
    01 S4
    I was doing some work on an old seat with the bladder module in yesterday, I may have a less invasive solution shortly.
    I'll report back with what I find.
    07 - RS4
    Insta-Ste3v3_0
    Mar 12 2007
    01 S4
    As I expected after my findings yesterday a separate pressure sensor can be spliced into the harness and poof no more airbag light and the airbag will be on without swapping the bladder
    07 - RS4
    Insta-Ste3v3_0
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by mightemouce View Post
    IIRC, the car needs to be calibrated to the bladder to recognize idle pressure vs. occupant in seat. By just connecting a bladder to the sensor and hiding it, the airbag would always be off.
    What kind of testing have you been doing?
    FRRG AZ Ring
    Mar 12 2007
    01 S4
    There's no bladder in the car anymore, I have a pressure sensor wired in to where the bladder would be and the car recognizes it as adult being in the seat with the airbag on
    07 - RS4
    Insta-Ste3v3_0
    Apr 04 2011
    '08 RS4, '16 SQ5
    Franklin Lakes, NJ
    I need this!!!!
    Nov 28 2006
    please tell me how you did this?
    Nov 28 2006
    bump for Mr Mightemouce response
