Results 1 to 40 of 41
    Registered User Four Rings
    Oct 27 2007
    NA
    OSRAM CBI (Cool Intense Blue) Finally Available!
    Hi AZ,
    After seeing high demand for Osram CBI D1S and D2S bulbs, we finally have them available.
    OSRAM CBI D1S bulb is 66144 CBI (5000K with up to 5500K color with up to 20% more light output) - $194.99
    OSRAM CBI D2S bulb is 66240 CBI (5000K with up to 5500K color with up to 20% more light output) - $178.99
    Use Free Shipping Coupon Code: FREEUS during checkout.
    We also have one set of D2S CBI bulbs that we opened up for taking product photos.
    If anyone wants, we are selling this set for just $160 shipped.
    Contact us for more detail.
    If you have any questions, please feel free to contact us via PM, email, or call us.
    Thank You,
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    I can't believe people still want ricer blue headlights... Too bad this fad won't die down especially considering having blue headlights lets you see less.
    Established Member Two Rings dingo7's Avatar
    Oct 02 2012
    Nashville
    Nothing beats the output of 4500k or 5000k white. I say just buy The retrofit source bulbs. I love mine and they are way less money
    Oct 12 2011
    WA
    Quote Originally Posted by NOTORIOUS VR View Post
    This.
    Let them stay blind... probably the same people who ghetto tint all exterior lights on their cars Personally, I love my 4300k
    01 Nogaro 605, AMD tuned with custom no-mod list signature.
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    5000K is NOT blue.
    Jan 07 2014
    01 B5 Santorin S4 Stage 2+
    Central NJ
    uhh...
    they not blue, they output more lumens than factory and are about as white as they get.
    Veteran Member Four Rings sqitis's Avatar
    Sep 03 2010
    B8.5 S4, B7 Avant S-Line, 8v A3 SLine
    Nashville, IN
    These bulbs are pretty kick ass and a little cheaper at TLS.
    | 2015 Ibis White S4 | Magma/Black | 6spd+SportsDiff | 034 MM | ECS DTI | Vag Com'd | CR-15 | BFI Shifter | 034 TB Boot
    | 2006 Ming Blue A4 Avant Sline | Auto | Vast Tuned | Milltek Exhaust | Need Suspension | Need Turbo | Need Wheels
    | 2012 Brilliant Red A3 S-Line | 6spd | SOLD |
    | 2002 Silver S4 Avant | Auto | SOLD | ===| 2002 Nogaro S4 | 6spd | SOLD ===| 2002 Black S4 | 6spd | SOLD ===| 2000 Imola S4 | 6spd | SOLD
    Sep 11 2009
    NE
    As other said, 5k is pure white. 4300k factory is a bit yellowish in comparison. Either one is a good choice for most light output.
    Jan 29 2009
    Quote Originally Posted by omeletduefromag View Post
    uhh...
    Uhh well maybe they should change their ricer advertising then... Because it clearly states cool blue with color up to 5500k. I find anything above 5000k to have a blueish hue from the light and not due to the reflector like most have when running OEM 4300k bulbs.
    Oct 13 2010
    colorado
    i was running 6000k and they were pretty blue now i have 5000k so much better
    17 Audi RS3(catalunya red): midpipes, hr lowering springs, 18x9.5 te37s, 034 front rotors
    01.5 Audi S4 2.7tt 6-Sp (Imola Yellow): Bagged, ko4s, recaro spg, AP rollbar, other bits
    Instagram: nerdiest_
    <<Flickr>>
    Jun 14 2007
    2000 S4
    Connecticut
    I have a sick set of 12ks on my S4. All about that purple life
    Dec 04 2012
    Arlington VA
    Any xenon light will gradually change it's color temperature as it ages. Bulb that started as 5000k going to became 5500k in couple of years, and even change to 6500K for a few days before it burns out, if you keep using it to the end of its life.
    Oct 12 2011
    WA
    Quote Originally Posted by V1nny View Post
    however, we are talking about getting 5500k from the get go, not in a couple years.
    Jun 14 2007
    2000 S4
    Connecticut
    Lets drop some Kelvin scale in here, for the hell of it.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by julex View Post
    What? I'm really not sure where you all learned your Kelvin light spectrum, but that is not true at all. 4,000k to 4,300k is pure white. The higher you go above 4,300k the more blue you get. Color temperatures over 5,000K are called cool colors (bluish white). Auto manufacturers go with 4,300k because that is true white light, if it wasn't why wouldn't they be using 5,000 or 5,500k instead?
    Jun 14 2007
    2000 S4
    Connecticut
    Well, some auto manufacturers.. They definitely don't all use the same color temp bulbs. The S4's stock Xenons @ 4300k are definitely more yellow in comparison to say my Dad's Lexus which are more of a blue than even my 5k HID bulbs..
    Xenons used back when our cars were just released versus the xenons used today in cars are most certainly a more blue color.. Then you go to LED which is even more so.. So I would think the 5k range is more what they think is representative of daylight which they say is easier on your eyes which is why they do it in the first place.
    Also the Kelvin scales that are out there vary a bit. Look @ the one I posted against yours. Mine shows pure white around 5k.
    Jan 29 2009
    I've never seen any yellow in my S4's head lights or any of my friends B5 S4 headlights with OEM HID's using 4300k bulbs, so I'd suggest changing your ballasts and/or bulbs is that is the case.
    Other manufacturers might spec different color temps (but I doubt it), although I'm willing to bet the biggest difference is in the optics and possibly actual (not rated) output of the ballasts.
    Jun 14 2007
    2000 S4
    Connecticut
    I didn't mean yellow was visible, I meant just more yellow in comparison to the higher Kelvin scaled bulbs.
    Like, 5k would be more yellow than an actinic bulb over an aquarium.
    Srsly though, 12k is what you want for that illest look. Can't have a dapper sticker on your car without purple lights.
    Oct 12 2011
    WA
    Illest, Fatlace, stanced, dapper, super kawaii ...
    Oct 27 2007
    NA
    Bingo! This is correct.
    Jan 29 2009
    If the yellow isn't visible, how are they yellow lol
    Oct 27 2007
    NA
    Quote Originally Posted by Gaki View Post
    I guess that our ad confused some of you.
    By the spec sheet from Osram states that it's 5000K, up to 5500K.
    As all HID bulbs do discolor to become bluer and whiter over usage, it means that it will go up to 5500K just like how stock 4300K gets close to 5000K after years of usage.
    Oct 27 2007
    NA
    In most cases, different lighting output and color can be given although the same xenon bulbs were used because of different projector used or different design of the reflector bowl. For example, Acura TL (say 2004-05) uses the same Philips 4300K bulb as Audi B5 S4 but the lighting result (color/brightness) differs between them depends on what angle you see the light from.
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    Similar to many posts above, here's what I've gathered when i did some research on it:
    4k = yellowish and even if less bright, is recommended for low visibility conditions. most manufacturers use this range for stock
    5k = whitish, even if technically brighter, it does not increase visibility for most drivers in most conditions. only perfectly clear nights can you argue it's an improvement, but it's regarded as worse for low visibility situations
    anything over 6k is just for looks, and has no practical application.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    I like my 6000k with 55W ballasts.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Sep 11 2009
    NE
    I only state what I witnessed myself by using quality 4300 / 5000 bulbs in my own and spouse's car. I don't care for graphs, I am saying how they look to my eyes. Thanks for irrelevant graphs, or rather for proving my point. If you look at your second graph, it neatly explain why we see even very "blue" bulbs as only slightly blue due to our eyes color sensitivity... According to your graph even 4300K should be rather blue and it is not, it is perceived by a lot of people as slightly yellowish.
    Veteran Member Four Rings jpurre's Avatar
    Jun 11 2013
    2004 BMW 325i
    South Florida
    Quote Originally Posted by pipe7284 View Post
    Me too.. and I wish I had cool graphs like these other guys.
    2001 Silver F21 TIP (SOLD)
    Build thread--> http://www.audizine.com/forum/showth...ally-Happening
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    A 4300K bulb provides more lumens than a 5000K bulb (~3300 lumens vs. 2700 lumens). 5000K bulbs may look "brighter" because there is less yellow coloration in the light. However, 4300K bulbs provide the best illumination/most lumens.
    2005 Ferrari F430
    2007 RS4 Daytona Grey | 2008 RS4 Mugello w/Ti Package | 2007 RS4 Avus Silver (ex-Audi Corporate) | 2008 RS4 Avus Silver w/Exclusive Package
    B6 S4 Avant 6MT Dolphin Grey
    B5 S4 Avant 6MT Laser Red Stage 3+
    B5 S4 Sedan 6MT Silver Stage 1
    Sep 11 2009
    NE
    Quote Originally Posted by Fourplay View Post
    CBI is rated 3500 lumens 5000K and there is no other light matching its output at 4300K except for Philips 85122 +... so while you might be right from theoretical point of view when on considers the same exact powered lightbulb in two different warmth, we are discussing here a specific product that has no close competition that can match it at its color warmth (and matches highest output 4300K)... If you throw it into overdrive on 50-55W ballast (I;ve been running it like that for two years now), you gain additional brightness and bring the color back to about 4300K. If you do that with 4300K bulb, it will definitely become halogen like yellow.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by jpurre View Post
    I didn't choose the graph life, the graph life chose me.
    Thanks, that's what I was attempting to say and apparently couldn't verbalize it correctly.
    Jun 11 2013
    2004 BMW 325i
    South Florida
    The stock fresnel lenses make a difference as well with how the light is projected. I changed to clear lenses with my 6000k retrofit as well as 50w ballast. A more powerful ballast make a difference as well.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Try combining a better lens (Like the RSX lens from an Acura) with a 55W kit, that will blow your mind at how much light output you have.
    May 01 2010
    Atlanta
    so while you might be right from theoretical point of view.
    As an engineer, that's all I'm worried about, lol.
    Philips 85122+ is only rated at 3400 lumens at 4300K. Would be interesting to see what OSRAM could do with a 4300K bulb, but I guess people don't like the yellowish color, despite it being better for illumination.
    2005 Ferrari F430
    Feb 07 2012
    CO
    They already make one in 4200K, it's called the Xenarc Nightbreaker.
    http://www.theretrofitsource.com/com...l#.UuGC-vbn-iA
    2002 Silver S4 Avant 6MT Stage 3 - SOLD
    2012 Dark Flint Metallic Touareg TDI Exec - FOR SALE
    2010 Sapphire Blue Pearl Touareg TDI Lux Limited
    May 01 2010
    Atlanta
    Quote Originally Posted by philthyphil View Post
    There you go then. That's the highest lumen output bulb you can get.
    2005 Ferrari F430
    Sep 11 2009
    NE
    Schweet, I know what I am buying soon
    Edit: All lies actually since this bulbs color temp is "up to 4350K" which was proven by users to be close to halogen ~ 3500k once burned in... This immediately disqualified it at least for my purposes of overdriving it to 50-55w even further). Even per OSRAM its output is the same 3200 lumens.
    Comparison matrix:
    http://www.osram.com/appsinfo/pdc/co...&1390341679460
    OSRAM rates the output at the same 3200lumens as their OEM style bulb.
    May 01 2010
    Atlanta
    Comparison matrix:
    Boo. Someone needs to make a true 4300K bulb with the latest technology. 3700+ lumens would be amazing.
    2005 Ferrari F430
    Active Member Two Rings Doubleredrolex's Avatar
    Jan 08 2017
    2004 S4 slightly modified :)
    BC Canada
    The chart that gramcracker posted is totally incorrect. The first chart was very accurate. 4300k is not pure white. 5500k is pure white and about the same as the pure white emitted by new LED headlights. This is why things are changing and manufacturers are offering these new bulbs because they are closer to LED color output which is actually pure white. 4300k was all that was available when his lights came out 15 years ago. It's not that it was the "perfect" color, it's just that was what was available and yes it was better than the 3200k or whatever halogen lights were. You don't actually get into that ricer blue color until you get well over 6000k. 4300k is actually still in the yellow spectrum.
    Registered User Two Rings RS6Tuner's Avatar
    Feb 15 2017
    RS4 B5 TTE960 / 992 4S TTE740 / MINI COOPER S 200 / VW T6 4MOTION 210
    UK
    I Have xenarc nightbreakers and RTX clear lens in fresh new housings on my Rs4. Output is very good and makes fast night driving much more safe.
    I was surprised how bad the original reflectors was. Much of the chrome coating gone with just the copper base remaining.
    Have been looking into high output led main beams next.
    Jan 29 2009
    Quote Originally Posted by RS6Tuner View Post
    I put the Nightbreakers in my A8, and was very surprised of the difference compared to the bulbs that were in there. But I do not know how old they were. Unfortunately I was unable to open/clean my lenses so I'm sure I am still missing some output, but the lights in the A8 are very expensive and complicated and I didn't want to have to buy new ones.
